Reply 15880 of 30429, by CMB75
- Member
luckybob wrote on 2020-06-16, 10:08:I'm the opposite, 3com or Intel network cards are my go-to means of working on these machines. I even have cards that can boot into windows over the network.
I'd try a 2 port usb card and see if that helps you.
Yes, that's what I usually did back in the day with tfpt and pxe boot servers, but I'm just fiddling around and play with these things (also not a permanent setup).
Thanks for the hint - will by a 2 port card and see for myself...
