Tomb Raider 1 crash
Reply 40 of 49, by TFMF
I see - i might try the Catalyst drivers instead then
However - i'd still like to know - is there an FMV at the end of Natla's Mines?
Reply 41 of 49, by IveAnAlienInsideMe
I guess as it's not been suggested it can't be done, but is there not a way to copy the entire CD contents to the HDD and run it from there ruling out the CD / DVD rom drive and CD? (assuming of course it's not corrupting the files during the copy...).
I've had this on and off but mostly first time the FMV / Cut scene plays. when I restart the game from a previous save and try again the FMV / Cut scene plays Ok. The lead in titles crashed first time also, always seems to be first time as if the drive or something can't keep up and second time it's as if it's managed to cache enough of it the previous time to work...
(Shouldn't be a pc unable to keep up in my case as it's virtually a top end system..........)
Reply 42 of 49, by Glidos
Have you tried editing glidos.ini, and changing
VESASupport: Yes
to
VESASuport: No
Reply 43 of 49, by TFMF
Yes i've tried changing the VESASupport to No but that didn't seem to make a difference
The cut scenes seem to cause the game to crash every time - not just once or twice - i've tried getting it to work many times with no success...
It is probably my laptop - i will see if it can work on my desktop
Reply 44 of 49, by thebulgd
I am having this problem also, The FMV after Tomb of Tihocan didn't seem to play all of it and the game crashes when the FMV is supossed to start after the Santuary of the Scion. In the Glidos server message box it says Winclose, then Glidos shutdown on the next line.
Number of color buffers = 2
Number of aux buffers = 1
Resolution = 640x480
Refresh rate = 60Hz
Color format = ARGB
WinClose
GlideShutdown
Was this ever resolved?
added info
athlon 64 3200
A8N-E
1GB Corsair
GF6600 91.33 drivers
SB Gamer Audio
Win XP
VDMS 210
Reply 45 of 49, by Glidos
Are you using the Audio pack?
Reply 46 of 49, by thebulgd
Not using the audio pack. I have my disc from back in '96. I tried the vesa yes/no thing, didn't work. I tried some older video drivers, didn't werk, even tried an older glidos, that didnt work. I'm out of idea's, not that I knew alot to begin with.
Reply 47 of 49, by Glidos
Try turning off redbook support.
Reply 48 of 49, by thebulgd
that did it, thanks for the help.
Reply 49 of 49, by Glidos
Yeah, but now you have no background sounds. You could try installing the audio pack.
