Bought this (Modern) hardware today
Reply 1080 of 2261, by luckybob
There are a GLUT of supermicro motherboards on ebay that are micro atx in size and have 6x 10g & 2x 1g ports. Going to make a pfsense box out of that.
Im going to try to just wire things directly to each other and see if that works out. If not i see 24port 10g switches on ebay cheap
Reply 1081 of 2261, by chrismeyer6
Nice those will make a nice pfsence box. I can't wait untill 10gig stuff really starts to drop in price.
Reply 1082 of 2261, by martinot
Got this spanking new toy in todays UPS delivery
Reply 1083 of 2261, by imi
that's a very expensive toy 😁
I didn't know they made 'em in black too
Reply 1084 of 2261, by chrismeyer6
That is a beautiful scope. Hopefully it can aid in saving retro gear
Reply 1085 of 2261, by martinot
Thanks. It will be put into good usage in saving retro things!
Reply 1086 of 2261, by chrismeyer6
Excellent! Happy repairs.
Reply 1087 of 2261, by darry
luckybob wrote on 2020-06-26, 03:41:
You could get 2 boards and run Linux with Openvswitch on one of them to get a 6 port 10GB switch .
Reply 1088 of 2261, by wirerogue
since the first three 8800 ultra cards i tried were all dead, i got 2 of these instead. evga 8800 gtx ko acs3
they were absolutely filthy and covered in some kind of black greasy gunk. water would not remove it.
lots of 99% isopropyl alcohol and even acetone on the metal parts (since isopropyl is ridiculously expensive right now.)
here's one of them running good as new after complete disassembly, detailed cleaning, new thermal pads and tim.
The attachment evga.8800.gtx.ko.acs3.a.jpg is no longer available
nice fat heatsink on the back of the card
The attachment evga.8800.gtx.ko.acs3.b.jpg is no longer available
Reply 1089 of 2261, by luckybob
So I've had a 4-drive array in my main rig since 2007 ish. Based on WD Black drive at 640gb a pop. I've used them almost 24/7 since then. My onboard raid controller started throwing errors at me the other day. (drive smart failure) @ out of the 4 drives are tossing SMART errors.
I decided to rectify the issue:
4TB total with a theoretical max of ~12,000 MB/s. The 4-way PCIe card I need is still a few days away. I'll post a few benchmarks.
Reply 1091 of 2261, by appiah4
luckybob wrote on 2020-07-03, 04:50:
So I've had a 4-drive array in my main rig since 2007 ish. Based on WD Black drive at 640gb a pop. I've used them almost 24/7 […]
That's insane. What motherboard/platform are you using? Do you have enough PCIe lanes for this setup to work effectively?
Reply 1092 of 2261, by luckybob
appiah4 wrote on 2020-07-03, 07:36:
It was pretty cheap too. https://www.supermicro.com/products/motherboa … /C600/X9DAE.cfm
In the next year or so, V3/V4 xeons will fall in price and i'll upgrade to https://www.supermicro.com/en/products/motherboard/X10DAX
I had to mod the bios to enable booting from NVME. Not to mention add a nvme/pcie card. I have 2 16x slots, so if I really wanted to, I could add another 4 drives. ^.^
Reply 1093 of 2261, by chrismeyer6
Wow that system will fly with the new nvme drives. Please post some throughput benchmarks.
Reply 1094 of 2261, by bestemor
Re supermicro xeons, I assume this system will not work with windows 7 ?
What OS'es are supported, I wonder ?
..and, what would be considered 'cheap' for these mobos ? 🤔
Reply 1095 of 2261, by Intel486dx33
Xeon 2690 ( 8-core ) for my HP z420.
Reply 1096 of 2261, by ODwilly
Picking up a Radeon 5700xt XFX DD for $240 on Monday. Should make for a solid upgrade over the rx 480 and give me an excuse to finally upgrade to 1440p.
Reply 1097 of 2261, by appiah4
ODwilly wrote on 2020-07-05, 08:34:
Please post your impressions, I'm still on an 8GB RX480 and TBH I find it hard to make a case for upgrading. I'm still at 1080p and don't intend to go to 1440p anytime soon.
Reply 1098 of 2261, by imi
appiah4 wrote on 2020-07-05, 08:49:
well you just made your case for not upgrading 😉
Reply 1099 of 2261, by luckybob
Silly people. Now is the WORST time to buy a GPU. Both teams are about to launch cards at the same time. Its going to be a bloodbath.
I'm saving myself for whichever team drops the best 4K card before CP2077 drops. (insert CP2077 delay joke here)
I too own a RX480 and for the games I play, it does just fine at 4K. (WOW and Civ6)
