VOGONS Driver Library
Reply 981 of 1221, by SquallStrife
https://archive.org/details/vogons-drivers-snapshot-20200627
ZIP with every file, and a CSV with a filename -> entry name mapping.
Archive.org has got to have the worst UI I've ever seen for trying to deal with "collections" or get in touch with people. UGH!!
Anybody here more familiar with archive.org got any suggestions?
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 982 of 1221, by Paralel
Thank you for doing this, SS. It helps to ensure that in the event of some horrifying catastrophe, all the effort you and the contributors have put into the archive will likely survive (except in maybe an end-of-the-world scenario, but, if that happened, the loss of vintage drivers will likely be the least of our problems)
Reply 983 of 1221, by Horun
SquallStrife wrote on 2020-07-03, 07:48:
https://archive.org/details/vogons-drivers-snapshot-20200627 […]
I noticed about 2 weeks ago or so they changed some of their web formatting, have only uploaded one item since and had no issue but it was small. Before that upped 30+ items and did not have any issues.
I think there is an upload max size that is not stated. Have you tried breaking your archive into parts (assuming you are trying to up one big .tar, zip, rar, etc) ?
edit: fixed a quirk
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 984 of 1221, by cyclone3d
The file size limit is 4GB per file for archive.org. At least that is what I had to break it up into when I uploaded the Sony Vaio ftp backup.
Yamaha YMF7x4 Guide
Reply 985 of 1221, by bjwil1991
Well, that's good to know. They must be using FAT32 partitions for storing files. Jk, however, the Windows 9x FAT32 had a limit to 4GB, so...
Reply 986 of 1221, by luckarusky
And download process begun! Like others have said, this is going to mean a lot down the road. Thanks again!
Reply 987 of 1221, by SquallStrife
Horun wrote on 2020-07-04, 02:06:
edit: fixed a quirk
The problem wasn't uploading the file, it was putting it into the right collection. As a new user you can only choose "Community Texts", "Community Software" and a few other generic collections, to which this collection doesn't apply.
I posted in the forums (which weren't easy to find) to request it to be moved into a Vintage Computing category I found, and one of the site admins did it no problem.
I don't know why that process had to be so manual, but 'tis what 'tis. All sorted now! 😀
Reply 988 of 1221, by jheronimus
Here are the drivers for Hornet Technology VL-200 cached IDE controller. Not a very common card, and as far as I know, there are no drivers/information available online:
Dropbox link
The folder has scans of the manual (with all the jumper settings), drivers for DOS, Win3.1, WinNT and Novell Netware.
Pentium 100, 32 MB RAM, Ark Logic ARK1000VL, Tekram DC-680C, Turtle Beach Tropez, Gravis Ultrasound Max
Pentium III 1000, 256 MB RAM, Matrox G400 MAX, Adaptec 19160, Yamaha YMF740B
Reply 989 of 1221, by Horun
jheronimus wrote on 2020-07-04, 15:42:
Here are the drivers for Hornet Technology VL-200 cached IDE controller. Not a very common card, and as far as I know, there are […]
Dropbox link
Great ! Will up to our library soon as I have time.
Reply 990 of 1221, by Jonas-fr
All credit for incanus for these new utilities !
Here are 3 utilities for Cirrcus Logic GD610/620 VGA cards (with flat panel controllers)
Eagle.com v4.01 which is compatible with VGA BIOS <3.0 (on the site there's an newer version of it, 5.03 to be exact which isn't compatible with VGA BIOS <3.0)
Switch.com (TSR utility to change video settings on the fly like switching from internal LCD panel to external display...)
Vscreen.com (not sure of its abilities but could be used by the other two tools)
PS: I'll dump BIOS for my retro computers (90's industrial hardware mostly) so I'll be down to have an account on vogonsdrivers if that's possible : )
Reply 991 of 1221, by Horun
Jonas-fr wrote on 2020-07-10, 22:43:
All credit for incanus for these new utilities ! […]
Great ! Can you find any docu's to go with the utils ? Will up them but would like to include any documentation if possible.
If you PM SquallStrife he may give you a login.
Reply 992 of 1221, by Horun
Dropbox link
I upped the file, can you check to make sure it reads and downloads as you intended ? Thanks.
http://www.vogonsdrivers.com/getfile.php?file … 696&menustate=0
Reply 993 of 1221, by luckarusky
The download was a success! You have my thanks good sir.
Reply 994 of 1221, by Jonas-fr
Horun wrote on 2020-07-11, 00:50:
Infortunately I've got no documentation and I believe incanus doesn't got any either. I'm currently trying to save an hold HDD for a machine with a GD610 so I might get more doc/utilities there in the next few weeks !
Reply 995 of 1221, by jheronimus
Horun wrote on 2020-07-11, 02:12:
Yes, looks fine
Reply 996 of 1221, by incanus
Correct, no docs for the Cirrus Logic drivers mentioned by Jonas-fr above. I recently obtained this 386 luggable and although it has paper manuals for the motherboard and peripherals, there is nothing about the CL card except for some penciled-in DIP switch settings and two 3.5” and one 5.25” floppy containing (among other things) the drivers. I will actually double-check the versions; I may have more than one. But no docs on them.
Reply 997 of 1221, by Horun
incanus wrote on 2020-07-11, 16:44:
Ok, thanks. I did find the Cirrus GD-610/620 datasheet and was able to list out some of the commands to .txt from the utils. Guess I will have to make up some docs it you do not find anything. Google was useless of course 😀
Reply 998 of 1221, by sp33dyS
Horun wrote on 2020-06-18, 02:07:
I will be happy to upload the XP driver here if you can Winimage it !
I've finally managed to upload XP driver for Cyborg 3D - https://mega.nz/file/bxMxlKST#haj4xsaelvmu65z … 2EF3Xiu3pD1Qx8I
It's just registry entry, nothing more.
Main: Ryzen 7 2700X, Gigabyte X470 AORUS GAMING 5 WIFI, HyperX 16GB DDR4, MSI GF RTX 2070 GAMING Z
Retro: Pentium III 1GHz, ASUS CUSL2-C, 512MB SDRAM, GF 4 Ti 4200
Retro wannabe: Athlon XP 2500+, ABIT NF7-S2, 1.5GB RAM, GF 6800GT
Reply 999 of 1221, by Horun
sp33dyS wrote on 2020-07-12, 21:02:
ahh it contains the hardware ID. So XP must have basic drivers that support it as long the ID is regged.
