Reply 35040 of 60043, by imi
Predator99 wrote on 2020-07-09, 10:27:
Next
that Tseng I/O combo card is lovely :3
so much nice stuff
@CMB75 that gold 2C87 is so nice 😁 I'm jelly :p
the corrosion looks repairable.
Reply 35041 of 60043, by bjwil1991
Man, those batteries. I cannot tell you how lucky I was twice when I received a Soyo SY-4SAW2 board that also had a leaking battery and only had 3 traces that needed to get repaired, but no other damage and the 386/486DLC board also had a battery leakage, but minimal damage.
On your board, looks like a lot of grounding layer has been destroyed and only 2 pins on the 8-bit slot have corrosion, but the rest of the board looks pretty good.
Reply 35042 of 60043, by imi
got these out of my last scrap lot a while ago... the seller was very apologetic when I told them that I didn't want it for scrap but try to restore and use them and that they wouldn't have removed all the metal bits if they'd known... but oh well they were very nice and packed the cards well even though all of them had most metal parts removed and some of them were outright destroyed (connectors ripped off etc.)
luckily the ones I was after most seem to have survived more or less unscathed with just a few parts missing.
miroCRYSTAL 20SV VL, S3 Vision964
just missing a bracket
The attachment hardware39_19.jpg is no longer available
miroHISCORE² 3D, Voodoo2 12MB
that bracket is unfortunately a bit harder to come by, also there were heatsinks mounted apparently, but chips seem to have survived.
The attachment hardware39_20.jpg is no longer available
Creative CT6670, Voodoo2 12MB
also missing bracket and one VGA connector shield, a few scratches but looks fine, idk what the bright spot on one of the vias near the PCI connector is though?
The attachment hardware39_21.jpg is no longer available
3Dfx Voodoo 3 2000? PCI! with 5.5ns SGRAM :3
not only the bracket and heatsink removed, but even the VRM heatsink, though no scratches on the PCB, which is suprising seeing in what state other cards were in, got removed carefully apparently
a few bent pins but chip looks fine, need to test all of them still.
The attachment hardware39_22.jpg is no longer available
and some RDRAM
The attachment hardware39_23.jpg is no longer available
Reply 35043 of 60043, by appiah4
Predator99 wrote on 2020-07-09, 10:26:
Boxes arrived, 1st one processed. What I am going to keep for the 1st run..dont think it needs to be commented. One of the NICs […]
Predator99 wrote on 2020-07-02, 20:14:
Hups...I agreed on an acceptable price for 3 boxes with more than 30 kg in total... 😒 There was at least one interesting card in each, therefore I will take only some few items and sell the remaining parts again asap. 1 sellers pic of each box...
Boxes arrived, 1st one processed. What I am going to keep for the 1st run..dont think it needs to be commented. One of the NICs is a ISA 100 MBit!
Nice. I have an ASUS PVI-486SP3 in the mail as well 😀
Reply 35044 of 60043, by CMB75
bjwil1991 wrote on 2020-07-09, 12:07:
The lower side is worse, after all it is a Desktop case. But I do think it’s repairable.
Reply 35045 of 60043, by Wolfus
Behold! My first 286! Bought as never used from new old stock shop with warranty!
Reply 35046 of 60043, by imi
more gold 287
:0
Reply 35047 of 60043, by devius
That's amazing Wolfus! Nice 287 as well.
Retro Coisas no YouTube
Reply 35048 of 60043, by Intel486dx33
CMB75 wrote on 2020-07-09, 12:01:
Picked up my ASI 286 PC today. Someone at Hermes logistics did have a go at several attempts to answer the question “How far can […]
Picked up my ASI 286 PC today. Someone at Hermes logistics did have a go at several attempts to answer the question “How far can one throw a box with a computer inside?”
Fortunately the seller did a good job at packing the system, the guys at handling did only punch through two of three layers of plastic air cushions. But he also did a good job of not displaying or mentioning the damn Varta battery leaking all over the place (had to grind the corrosion down with a Dremel to get the board out of the case).
Apart from that, some pretty interesting components.
(I will switch to the retro activities thread for repairs … right now the board is in the dish washer after ethanoic acid treatment …)
I am working on a corroded 386 motherboard right now. I let it soak in vinegar for 2 days and that cleaned up all the corrosion.
Cut off the barrel battery of course.
Reply 35049 of 60043, by Predator99
Very nice system! Corrosion doesnt look that bad.
imi wrote on 2020-07-09, 12:34:
Also nice cards Imi! Hope they work...
Reply 35050 of 60043, by CMB75
Predator99 wrote on 2020-07-09, 18:34:
You’re right, it’s already repaired (bodge wires) and those ZERO WAIT mainboards are becoming rare, so definitely worth repairing.
Reply 35051 of 60043, by MMaximus
Great haul as usual! Your pictures look really good now, have you changed your setup? 😀
Hard Disk Sounds
Reply 35052 of 60043, by Deksor
I found your motherboard :
https://arvutimuuseum.ee/th99/m/U-Z/30524.htm
Now if you can dump the bios or show us a POST string (if you ever get it to work ^^) that'd be great 😁
Reply 35053 of 60043, by Artex
Gravis Ultra Sound Extreme - Gravis Ultra Sound Extreme Rev. 3.0 (3400-1) 1MB ISA (Boxed) (1996)
Reply 35054 of 60043, by chrismeyer6
Wow that is a nice find Artex.
Reply 35055 of 60043, by CMB75
Deksor wrote on 2020-07-09, 20:38:
I found your motherboard : https://arvutimuuseum.ee/th99/m/U-Z/30524.htm […]
Yes, that's it - here is another link to a similar board http://www.amoretro.de/2017/08/ham-12-ti-286- … -10mhz-fpu.html
By the way - it already works. I've posted some details in the retro activity thread at: Re: What retro activity did you get up to today?
Reply 35057 of 60043, by Predator99
MMaximus wrote on 2020-07-09, 20:32:
Hehe, thanks! Have my pictures been that bad before..? Maybe if I took my mobile for it. Its a 6D mark 3 with ext. Flash. Yours are still looking better, think you take more time for it and care more about the background 😉
Pictures of the other 2 boxes will follow later...
Reply 35058 of 60043, by babtras
Not a computer, but the evolution of calculators and adding machines led directly to the advent of microprocessors so I consider them a part of the computer heritage.
Thrift store for $5. Funny bit is, I originally saw it on a Facebook auction page. Someone else wanted it more than I did and bid it beyond what I wanted to pay. 3 weeks later the same unit is at the thrift store for $5. It seems someone thought it was something else.
Reply 35059 of 60043, by Predator99
Boxes 2 + 3:
The attachment IMG_9665r.jpg is no longer available
The attachment IMG_9666r.jpg is no longer available
The attachment IMG_9667r.jpg is no longer available
The attachment IMG_9668r.jpg is no longer available
The attachment IMG_9669r.jpg is no longer available
