Reply 180 of 826, by root42
- l33t
JazeFox wrote on 2020-07-17, 19:36:The version is 0.72b, I made a mistake editing the post title. […]
root42 wrote on 2020-07-17, 19:21:I tried using Unisound with my GUSar light, which works fine with IWINIT, but it keeps failing. Says no PnP cards are detected. Any ideas? I downloaded the 0.72b from the first post -- the header says 0.72c, but can't seem to find that one...?
Any help is appreciated!
The card should be detected, but only if it has the EEPROM written and if its contents are OK. If there are corruptions in the header zone and the checksum does not match, it won't be detected.
Does Intel ICU (or other PnP manager software) detect the card properly?
The only software I have is the one from the GUS PnP, so IWINIT, which works fine. I can stick with that, but I thought I could switch to UNISOUND and get rid of EMU386S. What's Intel ICU and where can I find it?
