First post, by Rarsonic
As a project of mine I've been trying to piece together a machine that can run software in a time bracket from 1997 to 2002. My biggest stumbling block so far is that, as the title indicates, I can't get sound working in DOS applications because they do not detect the Sound Blaster 16 emulated by the drivers, neither in Win98 nor in DOS mode. I'm using the driver set that I got from Phil's Computer Lab, although I have also attempted to use the Live!Ware 3.0 CD image from the Vogons repository but the installers don't work, at least not from a virtual drive (I get no disk space errors in most of them even though I got plenty of it).
I have looked at more information on this topic here on Vogons and elsewhere, with no avail, I guess because every build is its own case. I hope it's not some kind of inherent incompatibility, such as an uncooperative chipset, as I've got a Via Apollo Pro Plus one.
The SBLive model I have is the SB0100.
Here is a report of my computer's hardware.
Here's an image album containing photos of my BIOS' settings.
Also find attached in an archive file my autoexec.bat and config.sys.
Edit 1: Forgot to add model of SBLive card.
Reply 1 of 5, by Joseph_Joestar
Try my guide.
It should work on all SBLive versions except the Dell branded SB0200 which is a SBLive in name only.
My retro stuff
Reply 3 of 5, by Rarsonic
cyclone3d wrote on 2020-08-15, 16:36:
What are the specs of the rest of your system?
What kind of specs? They should all be in the report.
In any case:
  • MoBo: Soltek SL-67EV
  • Chipset: Via Apollo Pro Plus (NB VT82C693, SB VT82C596B
  • CPU: Pentium III 450
  • RAM: 512 MB PC133
  • GPU: ATi Radeon 7200, 64 MB VRAM
  • Sound: Creative Sound Blaster Live! 5.1 SB0100
  • HDDs: 1x 40 GB, 1x 20 GB
  • 2x DVD drives
  • OS: WIndows 98 SE
Reply 4 of 5, by Rarsonic
Joseph_Joestar wrote on 2020-08-15, 13:13:
Try my guide.
Holy fucking hell, it actually worked! Just as a note to possible future readers, I had to do a fresh Win98 install, including a drive format.
Reply 5 of 5, by cyclone3d
Glad you got it working.
Reason I asked for specs is because it is much easier for people trying to help instead of having to download an attached report and look through it.
A lot of posters ask for help and provide absolutely no information about the rest of their system or what they have tried.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
