First post, by edwardo78
hellow i have bought hp xu 4100 workstation
and that card is inside it
do any one know what is it for
Reply 1 of 9, by Vynix
Looks like some kind of a Raid card with cache memory
Reply 2 of 9, by The Serpent Rider
Quick search for Altera Apex reveals that it's a development board from Intel.
Reply 3 of 9, by dr.ido
Altera Apex are FPGAs - programmed for a specific product by the manufacturer, so identifying the FPGA doesn't indentify the card. Have the markings on the Intel looking IC been removed? The connector is a 5W2. I've seen them on lab equipment and RF gear, but I can't find anything else identifiable in the picture - any markings on the back of the card? The software on the HDD (if it's still intact) will propably identify it.
Reply 4 of 9, by Grzyb
Looks like some Zero Channel RAID, which provides RAID and cache functionality to the onboard SCSI interface.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 5 of 9, by jokker
Certainly does have the look of a hardware development board with the FPGA's, what looks like an output to an analyzer and onboard RAM. That unmarked IC with possible debug points looks very much like an unmarked Intel CPU (486/Pentium era maybe?)
So maybe a CPU development board?
Reply 6 of 9, by cyclone3d
I don't think it is a CPU development board.
1. That is a PCI-X card..so way newer.
2. The Altera chips don't mean it is a development board.
3. The big chip that look like a CPU is pretty common... such as in old raid cards.
4. If it was a CPU development board, the CPU would 100% not be soldered on.
From the plug, it looks like some sort of video processing or capture card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 9, by debs3759
Whether or not it's a RAID card, it's definitely an i/o card of some sort, as the connector on the bottom right of the lower image says RS232, which makes it a COM port connector. As dr.ido asked, can you post a pic of the reverse of the card? That might help narrow it down.
Reply 8 of 9, by debs3759
Also, what is the rear panel connector?
Reply 9 of 9, by mdog69
Look for a HP product code - usually in the form of A1234 or A1244B (thats letter+4 digits or letter+4 digits+letter) Might yield something.
By the way the connector on the left is a "5W2" (compare with a 13w3 sgi/sun video connector if you want to know what one looks like)
