First post, by 65C02
Hey guys,
I copied my GOG version of Incoming to a Windows 98 PC with a Voodoo 3000 video card, but I can't seem to find the rendering mode options. I was playing it on a Windows XP PC with a Geforce 6600 before, so I think it was using Direct 3D or maybe OpenGL on that system. I basically just copied the game folder over to the 98 PC, so I believe it is using still using Direct 3D (the 3DFX logo doesn't appear when I run the game).
I can't find any in-game option or setup program to switch the game to Glide. Is there some extension or patch I have to run? Does the GOG version even support it?
Thanks!
Reply 1 of 7, by leileilol
Incoming is Direct3D only.
Reply 2 of 7, by kolderman
I thought Phil always used Incoming to show off glide games. Or maybe I am misremembering.
Reply 3 of 7, by 65C02
leileilol wrote on 2020-09-06, 23:55:
Hmm, looks like you're right. I saw Incoming on the Windows Glide Game List, but upon further inspection it looks like only the version that shipped with Voodoo2 cards run in Glide mode. Bummer. Guess I'll continue running it on my XP PC then.
Thanks
Reply 4 of 7, by kolderman
65C02 wrote on 2020-09-08, 21:32:
Thanks
Err....if there exists a version with Glide support it can be said the game supports Glide. Just find a copy of the Glide version!
Reply 5 of 7, by leileilol
The earlier Voodoo2 OEM versions (that are explicitly Voodoo2 marked and "requires Voodoo2") are also Direct3D only.
Reply 6 of 7, by kjliew
Rage Incoming works on QEMU VM on modern systems with WineD3D. Even on an old laptop based on Intel HD 4400 (Haswell GT2), it exceeds the performance of Voodoo2 running on retro PCs.
