Reply 35920 of 58560, by Predator99
imi wrote on 2020-09-11, 10:27:
appiah4 wrote on 2020-09-11, 09:20:
Predator99 wrote on 2020-09-11, 07:58:
IMG_1026r.jpg IMG_1028r.jpg […]
Somebody spots something else interesting on the overview photo? Think the remaining parts are standard/trash...
There is an Amiga accelerator in there, looks like an 020 or 030 for an A1200?
The rest is certainly not standard/trash either IMO..
there's this weird card on top that looks like a modem but has a simm-slot??
Yes, this seem sindeed to be a strange modem-card. With or without simm-slot without use. Can post a photo later...
Reply 35921 of 58560, by mkarcher
Predator99 wrote on 2020-09-11, 13:03:
I vaguely recall there were PC-based fax receiption solutions with its own fax buffer, so the fax receiption software didn't need to be running in background all the time to be able to receive fax documents. Maybe it's something like that.
Reply 35922 of 58560, by Predator99
mkarcher wrote on 2020-09-11, 13:43:
There it is
The attachment IMG_1035r.jpg is no longer available
Reply 35923 of 58560, by imi
hmm looks more like some kind of phone card, has an audio in or out too it seems, maybe to record voice messages or answering machine or something like that? ^^
Reply 35924 of 58560, by Shagittarius
Maybe part of a PBX setup?
Reply 35925 of 58560, by imi
or is that not an audio connector but a power input? seeing as there is a VRM up there next to it, for standby power/memory retention?
Reply 35926 of 58560, by chrismeyer6
Does that modem card have an FCC id we can try looking up?
Reply 35927 of 58560, by Predator99
Its this one (translate with google) 😉
PowerISDN A1 pro
BZT D130 698J
Gerdes Aktiengesellschaft Meckenheim
gerdes-ag.com
PowerISDN A1
Modernste DSP-Technik zum unglaublichen Preis
Eine Karte fuer alle Kommunikationsfaelle
Optionen fuer Datentransfer bei ausgeschaltetem PC
* PowerISDN A1 ist ein aktiver ISDN-Adapter, der ueber einen
Hochleistungsprozessor und Hochgeschwindigkeits-Speicher verfuegt. Der
Prozessor uebernimmt die Protokollverwaltung, Modem-Emulation und
Fax-Emulation. Der PC wird dadurch entlastet, schnelle
Modem-Emulationen (Kommunikation zu analogen Gegenstellen) werden
erm÷glicht.
* Dadurch, dass PowerISDN A1 nicht einen Standard-Modemchip verwendet,
steckt die Intelligenz der Karte in der Software, mit der der
integrierte Prozessor versorgt wird. So ist es moeglich, neue
Modem-Standards, Erweiterungen des Fax-Standards und andere
Verbesserungen durch Software-Updates durchzufuehren. PowerISDN A1
bleibt zukunftssicher.
* Vielfach fuehrt der Umstieg vom analogen Netz zu ISDN zu erheblichen
Problemen: Analoge Gegenstellen (Modems) koennen oft ueberhaupt nicht
mehr angerufen werden, Fax-Verbindungen koennen mit passiven Adaptern
zum Gluecksspiel werden, wenn sie ueberhaupt mit der normalen
Fax-Geschwindigkeit arbeiten usw. Den meisten Benutzern bleibt nichts
anderes uebrig, als Analog-Adapter oder Telefonanlagen zu erwerben, nur
um den bisherigen Stand wieder zu erreichen. PowerISDN A1 schafft hier
Abhilfe. Modem-Verbindungen bis V.34+ (33.600 Bit/s), Faxverbindungen
bis 14.400 Bit/s sind problemlos moeglich.
* PowerISDN A1 ist selbstverstaendlich ein Plug & Play Adapter.
Einstecken, Windows starten, die Software wird automatisch
installiert. Die Karte installiert eine neue serielle Schnittstelle
mit FIFO-Baustein, die bis zu 230.400 KBit/s uebertraegt. PowerISDN A1
verhaelt sich ueber diese Schnittstelle wie ein ganz normales V.34+
Modem. Vielfach liebgewonnene Modem- oder Fax-Software kann dadurch
einfach weiterverwendet werden.
* Ueber die echte serielle Schnittstelle steht PowerISDN A1 ohne
zusaetzliche Port-Treiber, Subsysteme oder Fossil-Treiber direkt als
Modem zur Verfuegung. Internet, T-Online, AOL, CompuServe, DFUe-Netzwerk
usw. koennen sofort angesprochen werden. Das fuer mehrere Online-Dienste
noetige Protokoll V.110 wird selbstverstaendlich unterstuetzt.
* PowerISDN A1 wird mit Dual-Mode CAPI's fuer Windows 3.1, Windows 3.11,
Windows 95 und Windows NT 4.0 ausgeliefert. Dieses CAPI enthaelt auch
direkt virtuelle Modems fuer Windows 95 und Windows NT 4.0. Ein
NDIS-MiniWAN-Treiber sorgt fuer Zukunfssicherheit fuer neue
Anwendungsprogramme.
* Auslieferung erfolgt grundsaetzlich mit Mini-a/b-Adapter und
Telefonhoerer. Durch die mitgelieferte Software steht so ein
leistungsstarkes Digital-Telefon mit allen ISDN-Merkmalen zur
Verfuegung, das seinesgleichen sucht.
* Modernste Fertigung in SMD-Technik nach ISO 9000, made in Germany.
Trotz umfangreicher Zusatzoptionen ist die Karte sehr kompakt und kann
in jedem freien ISA-16 Bit Slot betrieben werden.
* Umfassendes Software-Paket "PowerPack/32" in Vollversion inklusive.
Echte 32-Bit Anwendungen fuer Windows 95 und Windows NT 4.0 im neuen
Windows 95 Design fuer volle Rechnerausnutzung. Integrierte Oberflaeche
fuer G3-Fax, T-Online-Betrieb, Terminal-Emulation, EuroFileTransfer,
X.75 ANSI-Mailbox, Anrufbeantworter, Dokumenten-Konferenz (Option) und
Video-Konferenz (Option). Einheitliches Telefonbuch, neue
Gebuehrenkontrolle, Farbfax uvm. Die Installation ist denkbar einfach
im neuen Assistenten-Design von Windows 95 gehalten. Guenstige Updates
fuer die Erweiterungen, Pro- und Netzwerk-Versionen.
* Zusatzoption Speicherempfang, externe Stromversorgung, Signalgeber
(PowerISDN A1 PRO): In einem auf der Karte befindlichen und durch
groessere Module austauschbaren PS/2 Speichermodul koennen durch die
mitgelieferte Spezialsoftware eingehende Faxe und Sprachnachrichten
oder Faxe zur Versendung z.B. nachts ab 2 Uhr gespeichert werden.
Durch die externe Stromversorgung bleibt PowerISDN A1 aktiv, auch wenn
der PC ausgeschaltet wird. Dadurch wird die Karte zum extrem sparsamen
Faxgeraet und digitalem Anrufbeantworter. Ueber einen akustischen
Signalgeber kann PowerISDN A1 auf Wunsch darueber informieren, ob es
sich lohnt, den PC einzuschalten. Sprachnachrichten koennen direkt ueber
den mitgelieferten Telefonhoerer abgehoert werden, ohne den PC
einzuschalten. In der Grundausstattung reicht der Speicher fuer ca. 110
Faxseiten oder 16 Minuten Sprachaufzeichnung, bis der PC wieder
gestartet werden muss.
* Zusatzoption PC-Switch (PowerISDN A1 PRO): Auf der Platine ist ein
Lastrelais (10 A) integriert, das zum Schalten von Verbrauchern
benutzt werden kann, die per Anruf ein- und ausgeschaltet werden
sollen. Wenn Sie Ihre PC-Stromversorgung - aus Sicherheitsgruenden
unbedingt ueber einen geeigneten Adapter - durch dieses Relais schalten
lassen, kann man per Anruf den PC einschalten, um z.B. ueber das
Windows 95 DFUe-Netzwerk an wichtige Daten zu gelangen. Sonst muesste der
PC - nur fuer den Fall der Faelle - rund um die Uhr eingeschaltet
bleiben, um den gleichen Zugriff zu ermoeglichen.
* BZT-Zulassung. D-Kanal-Protokolle: LAP-D, DSS1 (EuroISDN) und 1TR6
(nationales ISDN) B-Kanal-Protokolle: Transparent, HDLC, V.110;
Bit-Transparent, X.75; Transparent, T.70NL, ISO 8208
* PowerISDN A1 Komplettpaket DM 399,-
PowerISDN A1 PRO, 4 MB Speicher, ext. Stromversorgung, Schaltrelais DM
599,-
Kurze Beschreibung
SystemvoraussetzungenPC ab 486 DX 33 MHz
Installationsart Plug & Play
Betriebssysteme Windows 3.1, Windows 3.11, Windows 95, Windows NT
4.0, andere
Slot 16 Bit Datenbus, halbe Baulaenge
ISDN-Karte, ISDN-Anschlusskabel, Mini-a/b Port,
Telefonhoerer, Diskette oder CD mit Treibersoftware,
Software-Paket PowerPack/32, Zugangssoftware zu
Lieferumfang T-Online, Microsoft Network (MSN), AOL und
CompuServe. Bei PowerISDN A1 Pro zusaetzlich 4 MB
Speichermodul, externe Stromversorgung,
Schaltrelais, Signalgeber.
Dokumentation Anleitung im Acrobat-Format (PDF). Gedruckte
Installationsanweisung
Service ServiceLine (kostenlos)
Updates CAPI-Updates kostenlos auf Lebenszeit aus
Service-Mailboxen
Lieferbar ab Anfang Februar '97
Hier klicken zum Abruf des Komplettinfos im PDF-Format.
Preise
B-Nr. Preis Beschreibung
DM 399,- PowerISDN A1 Komplettpaket
DM 599,- PowerISDN A1 Pro Komplettpaket
DM 249,- Treueaktion. Sie schicken uns Ihre alte PowerISDN Karte ein
und erhalten im Austausch PowerISDN A1 Komplettpaket
DM 449,- Treueaktion. Sie schicken uns Ihre alte PowerISDN Karte ein
und erhalten im Austausch PowerISDN A1 Pro Komplettpaket
Aufraeumaktion. Sie schicken uns jeden beliebigen anderen
DM 299,- ISDN-Adapter zu und erhalten im Austausch ein PowerISDN A1
Komplettpaket
DM 499,- ISDN-Adapter zu und erhalten im Austausch ein PowerISDN A1
Pro Komplettpaket
Copyright (c) 1996 Gerdes AG. Alle Rechte vorbehalten.
Stand: 21. January 1997.
Reply 35928 of 58560, by imi
cool, pretty useless, but cool ^^
Reply 35929 of 58560, by bjwil1991
Almost got a MacBook from 2006-2007, but the price was insane ($199 + tax) and almost got an iMac G5/1.8 20-inch IOB, but the price is too much for me ($126 + tax). Darn these bills.
Reply 35930 of 58560, by PD2JK
On the left there is a nice Mach64 with separate DAC. 😁
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 35931 of 58560, by yawetaG
Just besides the left corner of the motherboard in the top left: PCI SCSI controller?
Just left of the middle of the picture is a card that looks like it has RCA audio connectors and a large internal ribbon connector...wonder what that is...
At the right of the middle area appears to be a double VGA out video card.
In the bottom right area there is what appears to be a slot mounted card with an external power connector that looks like an internal power connector and another internal power connector.
In that same area, but entirely at the right there's an ISA card that looks like a sound card, but with an indent for some add on.
Just above it is something that looks like a Wifi card
Lots of audio/video cards/ISDN modems etc.
Reply 35932 of 58560, by imi
yawetaG wrote on 2020-09-12, 07:11:
Just left of the middle of the picture is a card that looks like it has RCA audio connectors and a large internal ribbon connect […]
Mitsumi CD-Rom Controller (RCAs are for CD audio out)
Matrox G450
sata/power slot adapter (to connect hard drives externally)
IBM Mwave with the modem part ripped out
Reply 35933 of 58560, by dionb
imi wrote on 2020-09-12, 09:41:
Almost worth sticking in a Win98 system to see if the audio part still works after that abuse...
Reply 35934 of 58560, by Predator99
Predator99 wrote on 2020-09-08, 19:12:
Saved in cooperation with imi (THANKS again!). Who spots the most valuable item? Sellers pics. s-l1600 (3).jpg s-l1600 (1).jpg […]
Sellers pics.
Box2 arrived.
Sellers pic:
The attachment s-l1600 (3) (1).jpg is no longer available
Non Amiga boards to keep:
The attachment IMG_1042r.jpg is no longer available
The attachment IMG_1043r.jpg is no longer available
Reply 35935 of 58560, by Predator99
Amiga boards:
The attachment IMG_1036r.jpg is no longer available
The attachment IMG_1037r.jpg is no longer available
The attachment IMG_1038r.jpg is no longer available
The attachment IMG_1039r.jpg is no longer available
The attachment IMG_1040r.jpg is no longer available
Reply 35936 of 58560, by imi
phew... looking good, only minimal damage ^^
that poor A2000 though 🙁
Reply 35937 of 58560, by SilverHawk
Nice haul! My no name slocket, or slotket if you prefer, arrived yesterday. Confirmed that it works with my celemine 700. Sadly, it performs worse than the overclocked 300A. At least in Quake demo1 with TnT. The 100FSB seems to make all the difference. Tried a mild overclock on the Celeron 700 going to 75Mhz frontside, but would not even complete 3DMark99Max at 1024x768 16bit. Tried a few tweaks, but wasn't happy. Time for a cheap 370 PIII and call it good.
Reply 35938 of 58560, by Miphee
Looking at all those nice boards makes me think of throwing out my miserable collection. 😁
So jealous!
Reply 35939 of 58560, by dionb
Predator99 wrote on 2020-09-12, 14:17:
Box2 arrived. […]
Sellers pics.
Box2 arrived.
Sellers pic:
Wow again.
One board you've not listed among non-Amiga keepers or Amiga stuff is intriguing me, the second from bottom on the left with those two black connectors on it. It almost looks like SBus - but the board doesn't look like any Sun Sparcstation I'm familiar with...
