First post, by xenatds
bug on windows xp with update drive info while pressing Ctrl F4 it doesnt do anything.
On windows xp this will not update drives to refresh say I put a disk in drive a: then mount it. Once I remove it put 2nd disk will not grab the info off the next disk. On windows 98 program works great but on xp it doesnt work correctly.
I was trying to restore old ms-dos backup disks on xp would never let me go 2nd or 3rd disk to restore because mounted drive wouldnt refresh when I pressed the button. Then I tryed on windows98 and it worked fine something bugy there on xp.
I even tryed tell dosbox to emulate under windows98 on xp that didnt get the key to work also it doesnt like xp 🤣.
Maybe have a auto refresh mounted drives on xp for program since Ctrl F4 key is not working on xp systems.
Thx again keep up the good work the program is great on windows98 only so far.... hehehe
