Reply 340 of 381, by matze79
No unless some one is patching the driver or port ReactOS Driver over.
Co2 - for a endless Summer
Reply 342 of 381, by matze79
yes why not ? it works also with Windows 10. But only in 1200 Baud unless someone comes up with a patched Serial Mouse Driver for it.
I also used it already on Sun Ultra 10 on Solaris (Sparc Platform)
it works with Microsoft Mouse and Logitech Protocol.
There is Software to setup the Protocol and the Speed.
177.98 KiB
(Translation to English is coming soon)
Tracking Speed is great, as i play mostly FPS Games on DOS its really an Improvement over RS232 Mice with Ball.
I like to play with optical Serial Mouse 😀
Reply 344 of 381, by matze79
Yes just drop me a PM.
Reply 346 of 381, by matze79
212.17 KiB
GPL-2.0-or-later
219.58 KiB
GPL-2.0-or-later
A new Edition by Serdaco / Serdashop updated by Dreamblaster to even smaller Version.
Reply 348 of 381, by ruthan
Its just kit for soldering, or ready to use device (i prefer this)?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 351 of 381, by matze79
https://www.serdashop.com/PS2TOSERIAL
Official buyable now 😀
Reply 352 of 381, by ruthan
Some basic cheap 3D printer case would be nice, i not like these open PCBs..
Reply 353 of 381, by maxtherabbit
did anything ever become of the effort to modify the firmware to support the logitech baud rate switch command to allow for 9600 baud with unmodified logitech drivers?
ETA: is the a BOM for the new SMD version anywhere? I'd like to build one
Reply 354 of 381, by MJay99
maxtherabbit wrote on 2020-11-18, 04:40:
Here's the fab list including positions, listed in millimeters (X/ Y/ orientation - which is very helpful, as the board doesn't have markings for all parts):
C1	31.12	23.50	0.00	10uF	0805
C3 16.51 17.78 90.00 10uF 0805
C4 19.05 17.78 90.00 10uF 0805
C5 21.59 17.78 270.00 10uF 0805
C6 13.97 17.78 270.00 10uF 0805
C8 12.70 30.48 0.00 100nf C0805K
C9 18.41 41.91 0.00 100nf C0805K
F1 34.93 23.50 180.00 1206L012 1206L
IC2 22.86 34.56 0.00 AT90S2313S SO20L
IC3 17.78 24.13 0.00 MAX232CSE SO16
LED1 29.21 15.88 180.00 CHIPLED_0805
LED2 32.38 15.88 180.00 CHIPLED_0805
LED3 26.04 15.88 180.00 CHIPLED_0805
R1 26.04 19.69 270.00 220 R0805
R2 32.38 19.69 270.00 220 R0805
R3 13.34 33.66 0.00 10k R1206
R4 29.21 19.69 270.00 220 R0805
R5 31.12 26.04 180.00 2k2 R1206
R6 26.67 41.91 180.00 2k2 R1206
Y1 25.40 25.40 90.00 OSCILLATORSMD-5X3 OSCILLATOR-SMD-5X3.2
And here is the full listing from the exported CSV:
Qty Value                        Device                       Package              Parts              Description                MF         MPN      OC_FARNELL OC_NEWARK POPULARITY PROD_ID   SPICEPREFIX VALUE
3 LEDCHIPLED_0805 CHIPLED_0805 LED1, LED2, LED3 LED
2 100nf C-EUC0805K C0805K C8, C9 CAPACITOR, European symbol 52 C
1 10k R-EU_R1206 R1206 R3 RESISTOR, European symbol
5 10uF 10UF-0805-25V-10% 0805 C1, C3, C4, C5, C6 10.0µF ceramic capacitors CAP-14259 10uF
1 1206L012 1206L012 1206L F1 Polyfuse Resettable PTC Littelfuse 1206L012 1596988 05M2298
3 220 R-EU_R0805 R0805 R1, R2, R4 RESISTOR, European symbol 86 R
2 2k2 R-EU_R1206 R1206 R5, R6 RESISTOR, European symbol
1 AT90S2313S AT90S2313S SO20L IC2 MICROCONTROLLER unknown unknown
1 AVRISP6PINHEADER AVRISP6PINHEADER 6PINHEADER X1
1 MAX232CSE MAX232CSE SO16 IC3 RS232 TRANSEIVER
1 MINI-USB_SHIELD5P2-32005-601 MINI-USB_SHIELD5P2-32005-601 32005-601 X2 MINI USB-B R/A DIP 5pol. unknown unknown
1 Mouse MINI_DIN_6 M_DIN6 X3
1 OSCILLATORSMD-5X3 OSCILLATORSMD-5X3 OSCILLATOR-SMD-5X3.2 Y1 Oscillators (Generic)
1 RS232 F09HP F09HP COM SUB-D unknown unknown
I just finished one of the v6 boards yesterday: it works nicely for me.
Reply 355 of 381, by MJay99
And here is a BOM I just quickly created from my Digikey order (please verify before ordering - there might also be cheaper parts available. Apart from the resistors, which came from my own stack, this is just what I picked):
"Manufacturer","Digi-Key Part Number","Packaging","Quantity","Unit Price","Extended Price","Description"
"Maxim Integrated","MAX232CSE+-ND","Tube","1","2,34000","2,34 €","IC TRANSCEIVER FULL 2/2 16SOIC"
"CUI Devices","CP-2260-ND","Tray","1","1,64000","1,64 €","CONN RCPT FMALE MINI DIN 6P SLDR"
"OSRAM Opto Semiconductors Inc.","475-1410-1-ND","Cut Tape (CT)","1","0,21000","0,21 €","LED GREEN DIFFUSED 0805 SMD"
"OSRAM Opto Semiconductors Inc.","475-1278-1-ND","Cut Tape (CT)","1","0,23000","0,23 €","LED RED DIFFUSED 0805 SMD"
"OSRAM Opto Semiconductors Inc.","475-2488-1-ND","Cut Tape (CT)","1","0,23000","0,23 €","LED ORANGE DIFFUSED 0805 SMD"
"TE Connectivity AMP Connectors","A135698-ND","Tray","1","0,79000","0,79 €","CONN RCPT USB2.0 MINI B 5P R/A"
"Microchip Technology","ATTINY2313A-SU-ND","Tube","1","0,92000","0,92 €","IC MCU 8BIT 2KB FLASH 20SOIC"
"ECS Inc.","XC1897CT-ND","Cut Tape (CT)","1","1,88000","1,88 €","XTAL OSC XO 8.0000MHZ HCMOS SMD"
"Samsung Electro-Mechanics","1276-6455-1-ND","Cut Tape (CT)","5","0,09000","0,45 €","CAP CER 10UF 16V X5R 0805"
"TDK Corporation","445-7534-1-ND","Cut Tape (CT)","2","0,13000","0,26 €","CAP CER 0.1UF 50V X7R 0805"
"Stackpole Electronics Inc","RMCF1206FT2K20CT-ND","Cut Tape (CT)","2","0,08000","0,16 €","RES 2.2K OHM 1% 1/4W 1206"
"Stackpole Electronics Inc","RMCF1206FT10K0CT-ND","Cut Tape (CT)","3","0,08000","0,24 €","RES 10K OHM 1% 1/4W 1206"
"Littelfuse Inc.","F2864CT-ND","Cut Tape (CT)","1","0,39000","0,39 €","PTC RESET FUSE 30V 125MA 1206"
"KOA Speer Electronics, Inc.","2019-RK73H2ATTD2200FCT-ND","Cut Tape (CT)","3","0,08000","0,24 €","RES 220 OHM 1% 1/4W 0805"
Just remembered that I didn't include the 6 Pin header - you can use e.g. this or any one other one and break off what you need: S2011EC-20-ND
Reply 356 of 381, by MJay99
Oh, and one more thing: you can't use the TL866II plus's ICSP port to program the ATTINY2313A on board, mine only knows it through the ZIF socket, so you need a 20 pin SOIC to DIP adapter for it (and only solder it afterwards). Or, of course, the AVRISP mk2 and ATMEL studio, which is what I ended up using to program the already soldered chip through the pin headers.
Reply 358 of 381, by SmooBandit
matze79 wrote on 2020-11-12, 14:58:
And bought one I have. Very nice product - works right out of the box.
I am curious, though, about the D1-D3 and J1 parts of the board. I can't seem to find any documentation for this particular version of the board. Any hints?
Thanks,
Reply 359 of 381, by matze79
This is just ISP Programming Header, there should be none onboard.
Don`t be confused.
