Reply 16780 of 29975, by bjwil1991
For free? Dude, you are the luckiest guy in the world. Wish I could find free computers. Haven't gotten a free one since 2015.
Reply 16781 of 29975, by wiretap
Yes, free. He said he was just happy to get his closet space back since it has been there since the early 90's. Now comes all the testing. I didn't have time to power any of it up while I was there, but he said it was all put away in working condition. I had my wife and 3yr old with me, and it was about a 4hr one way trip to get there. He said he goes to auctions and estate sales all the time and he would keep an eye out for any pre-2000 computer stuff for me. He said last year he was at an estate sale where 3 Commodore Amiga computers went for $10 each, but he didn't know at that time I would have wanted them. So, I feel this is just a good route to go, letting family members know what I'm looking for so I just get random hardware to sort through whenever they call me with stuff.
My Github
Circuit Board Repair Manuals
Reply 16782 of 29975, by kdr
SodaSuccubus wrote on 2020-09-27, 22:30:
That Is a suprisingly clean and modern look for a board made in the 80s. Well done to the folks in the factory that day!
Great find 😀
If you look carefully you can see the blown tantalum on the +12V rail [that miraculously didn't short], which is the reason I had the board out of the case.
Reply 16783 of 29975, by wiretap
Unpacked everything between the rain storms today. It all needs a good cleaning. Some of it was in his climate controlled workshop, but it looks like 20+ years of dust, sawdust, ladybugs, spiders, etc have deposited quite a bit of grime. Physical condition of the stuff varies, but overall it appears that it will clean up pretty nice. One of the C64 keycap stems (middle C64 key #6) got busted on the 4hr Michigan pothole filled drive home, but I already ordered a set of replacement plungers for $2. Also, I underestimated the amount of floppies he gave me.. it is at least 150 of them. 🤣
My Github
Reply 16784 of 29975, by chrismeyer6
Wow that is quite the impressive haul
Reply 16785 of 29975, by Cyrix200+
That's a nice collection!
Don't forget to check the floppies for mould, you might damage the drives.
1982 to 2001
Reply 16786 of 29975, by xcomcmdr
I damaged an internal laptop floppy drive with mould indeed, can I recover it ?
(I'd prefer not to disassemble it)
I already tried a floppy drive cleaner kit, it did nothing at all.
Reply 16787 of 29975, by badmojo
wiretap wrote on 2020-09-28, 02:37:
Great haul! The usual suggestion is to be careful of the original power supplies, they can do damage if they fail. The internets are full of replacement options and the original's are easy to test out with a multimeter - I wouldn't trust one long term though.
Classic machines, good times.
Reply 16788 of 29975, by wiretap
Yea I checked the power supplies. 3 are good, one is bad. I fired up just the C64 machines.. two work fine, one just outputs a red or blue screen. Looks like I have some repairs to do. 😄 But, I'll be ordering a newly manufactured power supply to ensure the machines will recieve good power for years to come.
My Github
Reply 16789 of 29975, by astonsmith
xcomcmdr wrote on 2020-09-29, 08:38:
It might be worth trying the kit in conjunction with the drive cleaning option in ImageDisk. Otherwise, I think you might not have any other choice but to disassemble it and clean manually.
Reply 16790 of 29975, by xcomcmdr
Thanks !
I'll try that.
Reply 16791 of 29975, by Cyrix200+
wiretap wrote on 2020-09-29, 12:22:
Still, be careful with those old power supplies. Because of the way they are designed, one of their failure modes is a too high 5V rail.
https://www.c64-wiki.com/wiki/Power_Supply#Po … he_Commodore_64
Owners of a C64 using an original power supply should regularly (for example, once a year) check the 5V DC function of their power supplies, as they tend to produce higher voltages as they wear out. Because the C64 almost directly uses the 5V to power its chips, higher voltages can become dangerous for the Commodore 64. If you measure the voltage of your power supply, you should interpret this as follows:
1982 to 2001
Reply 16792 of 29975, by PD2JK
Not really retro. Yet.
Installing Vista on a Asus P5N32-E SLI Plus / QX6850 / Radeon HD 2900XT.
It draws a staggering 200 Watts from the socket when idling. Good thing to see lower readings with contemporary hardware.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 16793 of 29975, by assasincz
After moving to a new house and finally settling in, I was reviewing my retro HW inventory and making a list of components - CPUs, Mobos, RAM sticks, GPUs anf sound cards - that I dont have use for in order to sell off, and deciding which of those to use to build complete Socket 7 systems into three old battered to-be-restored AT cases to also sell off. Long winter nights are closing in, I quite look forwards to building a few retro PCs.
Reply 16794 of 29975, by SodaSuccubus
It honestly surprises me how long some 5.25" floppy disks survive these days. Like, prior to this hobby, I honestly thought most woulda been dead by now 2020.
I understand it was pretty RNG, even back in the day.
Reply 16795 of 29975, by pan069
I'm rearranging a bunch of stuff and dug out my 386SX-20 based system. It's some no name OPTi based motherboard with an Intel i386SX-20 and an IIT 3C87X FPU, 4 megs of ram, a no name IO controller, a Trident TVGA9000C with 512kb and a Pro Audio Spectrum 16 (650-0060-53).
I love the case. I'm using one of those Startech front loading CF/IDE trays. It matches well with the other black elements on the case. The left digit on the turbo display has a doggy segment (I can live with it, adds to the charm).
My favorite is the case badge that simply says "Computer". 😀
The attachment PXL_20200930_000954618.jpg is no longer available
The attachment PXL_20200930_001059061.jpg is no longer available
Reply 16796 of 29975, by aha2940
I've been playing "No one lives forever GOTY". Very fun game, too bad a re-release seems not to be possible now.
Reply 16797 of 29975, by kolderman
aha2940 wrote on 2020-09-30, 00:34:
Interesting situation that is.
Reply 16798 of 29975, by TheMobRules
SodaSuccubus wrote on 2020-09-29, 22:35:
I've always felt like 5.25'' floppies are way more reliable than the 3.5'' ones, even back in the day. I don't know if it's just luck but pretty much all my 5.25'' disks work to this day, both original games and old boxes of disks I purchased long ago. With the 1.44MB 3.5'' floppies however it's failures galore.
Reply 16799 of 29975, by bjwil1991
I've had luck with 5.25" floppy drives in a matter of speaking. Had to lubricate everything so that the drives would operate quietly and efficiently. Had 1 diskette go bad on me and the other one just had a data read error, but I was lucky to have backups of the files to be safe.
