Reply 1 of 23, by konc
- l33t
I can't help you much but judging from the naming of the pins in the jumper block I'd say that this card is a dual Hercules/CGA.
M/C should be mono/color, PTR should configure the parallel port (enable/disable/address).
From there on I can only guess that CG might enable/disable CGA and EMU could be emulating the CGA while in Hercules mode (like ATI small wonder does through software)
I have no clue about the dip sockets, except that 2764 should be an EPROM
Edit: Have a look at this card: https://arvutimuuseum.ee/th99/v/P-R/50414.htm
Reply 2 of 23, by debs3759
- Oldbie
M/C = MonoChrome
P = ?
TR = ?
CG = CGA
EMU = (Hercules?) EMUlation
It's not a Hercules card, it is a Hercules Emulator
Reply 3 of 23, by Horun
- l33t++
konc wrote on 2020-10-24, 15:17:Edit: Have a look at this card: https://arvutimuuseum.ee/th99/v/P-R/50414.htm
Yes very close to the card and settings should be similar
The sockets are for a BIOS chip and Octal latch. Those would add CGA capability if not included in the motherboard iirc.
The jumpers are for setting the video Mono/CGA, LPT port (LPT1, 2, 3 or 4) and video emulation for MDA, Mono CGA, Color CGA.
I have a similar card Everex Edge II but luckily has the jumpers silkscreened....
Reply 4 of 23, by Grzyb
- l33t
EXT C G = EXTernal Character Generator
You can install there a 2764 ROM chip with some font, eg. one with national characters.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 5 of 23, by Horun
- l33t++
Grzyb wrote on 2020-10-24, 16:01:EXT C G = EXTernal Character Generator
Thanks ! I have one MDA/CGA card with a ROM chip and a few with empty socket and never really figured out why only the one has one...
Should remove it and see what difference it makes in FONT or charactor type.
Reply 6 of 23, by muon
You guys are a well of wisdom
Thanks a lot
What kind of IC I can Use for the 2764 ROM? I have a Minipro programmer. Where can I get a set of font for the ROM?
Horun wrote on 2020-10-24, 15:23:The sockets are for a BIOS chip and Octal latch. Those would add CGA capability if not included in the motherboard iirc.
Where I can get that IC ( Octal latch)?
Best regards
Reply 7 of 23, by mkarcher
muon wrote on 2020-10-24, 17:06:Grzyb wrote on 2020-10-24, 16:01:EXT C G = EXTernal Character Generator
You can install there a 2764 ROM chip with some font, eg. one with national characters.What kind of IC I can Use for the 2764 ROM? I have a Minipro programmer. Where can I get a set of font for the ROM?
You use a 2764 or a 27c64. An 2864 or 28c64 should be compatible. Check you MiniPro documentation for chips with numbers like that. "27" means you need a UV lamp to erase the chip, and the cheapest 27-type chips don't have the window, so you can't erase them at all. "28" means you can electrically erase them within seconds, you just need the minipro to reprogram the device. Any 27-type chip you buy from factory is already erased, so for a single programming process you don't need any erasure.
I don't know what layout the font has to have. If the external font is applicable for the MDA mode, you need 256 characters of 16 bytes each (14 bytes make up the image, and two bytes are wasted, to make the size per character a power of two). This will only use 4K of the 8K of the ROM, so it is likely that they might use the same ROM memory layout as the original MDA and CGA cards (but they use a different pinout!). The original MDA/CGA ROM has two CGA character sets of 2K each (8x8 pixels, one with thick and one with thin vertical lines) and one MDA character set (8x14 pixels). which nicely fits in the 8K you can store in a 2764-type programmable memory.
I don't know good sources for ROM contents, but this thread on Vogons discusses greek CGA/MDA font ROMs.
muon wrote on 2020-10-24, 17:06:Horun wrote on 2020-10-24, 15:23:The sockets are for a BIOS chip and Octal latch. Those would add CGA capability if not included in the motherboard iirc.
I have a similar card Everex Edge II but luckily has the jumpers silkscreened....Where I can get that IC ( Octal latch)?
Anywhere you can buy electronic components. The useful options depend on your location. The chip you need is named "74LS374". The card already says "LS374" on the silkscreen, and the 74 was supposed to be obvious to anyone into digital electronics. There are more modern variants of this chip that should be 100% compatible, like the "74HCT374". The "T" is important for full compatibility, but most likely, any "74...374" chip you can obtain will do.
I suppose the CG jumper is not about "CGA" though, as other posters guessed, but is used to switch between the internal character set and the external character generator ROM.
Reply 8 of 23, by Jo22
- l33t++
mkarcher wrote on 2020-10-24, 17:27:I suppose the CG jumper is not about "CGA" though, as other posters guessed, but is used to switch between the internal character set and the external character generator ROM.
I think the same. The card's IC likely contains the standard CP437 code page already.
The EPROM is meant to hold a copy of a foreign/national character set.
Say, Greek or French. For other languages (German etc) the ordinary CP437 may also suffice.
Reply 9 of 23, by Grzyb
- l33t
Horun wrote on 2020-10-24, 16:35:Should remove it and see what difference it makes in FONT or charactor type.
No need to remove the ROM - as others already stated, there should be a jumper to select internal/external CG.
Reply 10 of 23, by mkarcher
Horun wrote on 2020-10-24, 16:35:Thanks ! I have one MDA/CGA card with a ROM chip and a few with empty socket and never really figured out why only the one has one...
If your card has a ROM chip and displays the normal extended IBM ASCII characters (code page 437), it is very likely that that card uses an older, not that highly integrated controller chip that doesn't have an integrated ROM. In fact, I did not realize until now that there were MDA/CGA controller chips that integrate the character ROM. On those late low-cost cards, no one would put an expensive ROM on the card if it could do without...
On the other hand, if the card with the ROM installed indeed has special characters (cyrillic, greek, hebrew), it might be that it can be switched to an internal CP437 font.
Reply 11 of 23, by Horun
- l33t++
mkarcher wrote on 2020-10-24, 19:14:Horun wrote on 2020-10-24, 16:35:Thanks ! I have one MDA/CGA card with a ROM chip and a few with empty socket and never really figured out why only the one has one...
Should remove it and see what difference it makes in FONT or charactor type.If your card has a ROM chip and displays the normal extended IBM ASCII characters (code page 437), it is very likely that that card uses an older, not that highly integrated controller chip that doesn't have an integrated ROM. In fact, I did not realize until now that there were MDA/CGA controller chips that integrate the character ROM. On those late low-cost cards, no one would put an expensive ROM on the card if it could do without...
Here is one MDA card with a soldered ROM, a Kouwell KW-526K. The other with a socketed ROM one is in my Luggable.
Reply 12 of 23, by mkarcher
Horun wrote on 2020-10-24, 19:40:Here is one MDA card with a soldered ROM, a Kouwell KW-526K. The other with a socketed ROM one is in my Luggable.
I also have a card with that TD3088 controller chip. My card also has a ROM soldered on it. I am very confident this card needs the ROM to operate properly. Cards without a ROM only work because a part of the controller chip (which will not be a TD3088) contains a copy what our cards have in the external ROM. Maybe we just misunderstood what you were trying to do. It doesn't seem to make sense to operate a card like that Kouwell KW-526K without any ROM at all. On the other hand, swapping the ROMs between two cards might make sense to find out if their ROM memory layout is compatible, or if they have different fonts and you prefer one font over another. I'd guess most CGA/MDA cards just have a (unlicensed?) copy of the original IBM MDA/CGA font ROM, though.
Reply 13 of 23, by Grzyb
- l33t
That TD3088A card seems to support 2732 ROM as well, ie. 4 KB, ie. not enough for the entire MDA/CGA set of 8x14+8x8thin+8x8thick.
Must be 8x14 only.
Reply 14 of 23, by muon
mkarcher wrote on 2020-10-24, 17:27:You use a 2764 or a 27c64. An 2864 or 28c64 should be compatible. Check you MiniPro documentation for chips with numbers like th […]
Hi again!!
Then Can I use this SN74HCT374N IC? link
and this eeprom AT28C64B-12PC? link
Reply 15 of 23, by mkarcher
muon wrote on 2020-10-25, 07:10:mkarcher wrote on 2020-10-24, 17:27:You use a 2764 or a 27c64. An 2864 or 28c64 should be compatible.
Yes. That chips should work perfectly in your card.
Reply 16 of 23, by muon
Thanks a lot
Reply 17 of 23, by Miphee
- Oldbie
Hi, could you identify this logo? It's on a generic-looking hercules card. No FCC, nothing on the back. Thanks.
Reply 18 of 23, by Miphee
- Oldbie
Another one on a generic hercules card:
Reply 19 of 23, by darry
Miphee wrote on 2022-11-01, 18:00:Hi, could you identify this logo? It's on a generic-looking hercules card. No FCC, nothing on the back. Thanks.
Dumping that EPROM and looking for text strings might provide a hint .
