Old hardware giveaway thread.
Reply 920 of 1431, by cyclone3d
Now we have an Inspiron 530 with an E7300 CPU. Motherboard looks good. Only tested to POST.
The attachment Inspiron_530_Front.jpg is no longer available
The attachment Inspiron_530_Open.jpg is no longer available
The attachment Inspiron_530_Back.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 921 of 1431, by cyclone3d
Next is an Optiplex 780. CPU is a Pentium Dual Core. Motherboard looks fine. Only tested to POST.
The attachment Optiplex_780_Front.jpg is no longer available
The attachment Optiplex_780_Open.jpg is no longer available
The attachment Optiplex_780_Back.jpg is no longer available
YMF7x4 Guide
Reply 922 of 1431, by cyclone3d
Almost there:
Now we have an Optiplex GX620.
The attachment Optiplex_GX620_Front.jpg is no longer available
The attachment Optiplex_GX620_Open.jpg is no longer available
The attachment Optiplex_GX620_Back.jpg is no longer available
YMF7x4 Guide
Reply 923 of 1431, by cyclone3d
And lastly we have a Dell Optiplex 755 with a Core 2 Duo CPU. Motherboard looks fine. Only tested to POST.
The attachment Optiplex_755_Front.jpg is no longer available
The attachment Optiplex_755_Open.jpg is no longer available
The attachment Optiplex_755_Back.jpg is no longer available
YMF7x4 Guide
Reply 924 of 1431, by devius
I wouldn’t mind the first one but shipping costs would probably make it impractical, so good luck to everyone else 😀 The last dells are almost as new as my current main PC!
Reply 926 of 1431, by cyclone3d
Last bump for these computers before I part most of them out and stick the cases and boards out to the curb.
Check the previous page as well as some of them are there.
YMF7x4 Guide
Reply 927 of 1431, by debs3759
cyclone3d wrote on 2020-11-26, 07:33:
I would like this please, if shipping is affordable. I would be preparing it a gift for a friend who wants a media player PC
Reply 928 of 1431, by cyclone3d
debs3759 wrote on 2020-11-28, 20:03:
Just checked with USPS, UPS and Fedex. Cheapest was USPS at almost $100 US.
So most definitely not worth it to pay for shipping for one of these overseas. This little thing is heavy at 14.5 pounds and shipping weight would be around 16 pounds.
For shipping in the continental United States, my guess would be that most of them would be $25 - $35 to ship through Fedex or UPS.
YMF7x4 Guide
Reply 929 of 1431, by debs3759
You're right, that would be too much for me to pay. Thanks for checking.
Reply 930 of 1431, by cyclone3d
Ok, so the desktops are off the table. Sticking all but the Lenovo out by the road. Already pulled what I wanted from them.
Next up is hopefully some more interesting stuff that people will actually want.
Not limiting to only one per person. Again, you pay shipping.
First, some Apple cards.
Apple IIE 80COL/64K Memory Expansion with no memory chips:
The attachment APPLE2E_80col-64K_Memory_Expansion.jpg is no longer available
Power Macintosh 6100/60 NUBUS Adapter Card - this has a couple damaged traces on the back and a few legs of the big chip are bent as well as a few that have been disconnected from the board:
If somebody wants it, I should be able to repair it fairly quickly but I have no way to test it.
The attachment Power_Macintosh_6100-60_NUBUS_ADAPTER_CARD.jpg is no longer available
Compaq 003560-001 256KB cache module. I know somebody on here mentioned that these are terribly hard to find. I have no way to test it so if you have a system that can use it, have at it:
I will double check to make sure I don't have a board that this works in before sending it out.
The attachment Compaq_003560-001_256KB_cache.jpg is no longer available
Epson Equity I+ AGN-MT ISA board
The attachment Epson_Equity_I_Plus_AGN-MT_ISA_board.jpg is no longer available
Unknown board - It has a female 9-pin connector. Is this an MCA card? Anybody know what it is?
The attachment unknown_female_9-pin_port.jpg is no longer available
YMF7x4 Guide
Reply 931 of 1431, by cyclone3d
Now for some PC Jr boards. I've no way to test them.
The attachment PCjr-1.jpg is no longer available
The attachment PCjr-2.jpg is no longer available
The attachment PCjr-3.jpg is no longer available
YMF7x4 Guide
Reply 932 of 1431, by cyclone3d
Almost forgot... 3x Compaq 286 motherboards. Only 1 has BIOS chips but 2 of them do have CPUs - both 12Mhz. One intel and one AMD.
One has a bit of RAM.
Probably want to ship these all to the same person so they can at least get 1 going... maybe all of them.
The power supply for these is proprietary, but the boards have the voltages listed on the connectors so I think it should be possible to wire up a regular AT power supply:
The attachment 1-top.jpg is no longer available
The attachment 2-top.jpg is no longer available
The attachment 3-top.jpg is no longer available
YMF7x4 Guide
Reply 933 of 1431, by hwh
cyclone3d wrote on 2020-11-30, 05:46:
Wow, what is that? ISA or PCI?
Reply 934 of 1431, by cyclone3d
hwh wrote on 2020-11-30, 08:03:
Ya know what, it never even occurred to me that the other side could be ISA... Hmmm
Edit: Found it. It is a Wireless LAN adapter for MCA and ISA. The transmitter / receiver is supposed to plug into the 9-pin port on the back of the card
The attachment 61KfINedNwL._AC_SL1000_.jpg is no longer available
Here is some actual info:
http://ohlandl.ipv7.net/NIC/Wireless_LAN.html
YMF7x4 Guide
Reply 935 of 1431, by devius
Potentially interested in the Compaq cache module. I have a cache less ProLinea 5100e that could use it in case it’s compatible. I’ll check what it accepts and report back.
Reply 936 of 1431, by debs3759
Might be interested in the motherboards. I'm mostly interested in the CLCC board (the third one). Are you willing to use Parcel Monkey for shipping if it's cheaper than USPS (I think it is for that weight)?
Reply 937 of 1431, by devius
Seems like that cache module is for a Prosignia VS 486 PC, which I don't have unfortunately. However if no one else wants it and the alternative is to throw it away then I'll take it on the very remote chance I obtain a Compaq Prosignia VS some day.
Reply 938 of 1431, by cyclone3d
debs3759 wrote on 2020-11-30, 09:13:
Ok. So for all 3 shipped via Parcel Monkey, it looks like it would be $43.47 US - shipping weight for all 3 is 7 pounds.
For only one of them, it would probably be around $30-35. I would need to weigh a single boxed up.
YMF7x4 Guide
Reply 939 of 1431, by cyclone3d
devius wrote on 2020-11-30, 17:01:
Ok, I'll wait to see if anybody else wants it that has a machine that it will fit.
I wouldn't be throwing it away if nobody wants it. Not like that piece takes up much space.
YMF7x4 Guide
