Reply 320 of 794, by superfury
UniPCemu has a serial modem on the COM2(port base 2F8) port. The COM1 port has a serial mouse connected when the PS/2 mouse isn't available(on all Compaq Deskpro 386 and earlier architectures).
The i430fx/i440fx has a dummy port there, without any device plugged in.
Do you know how to make Minix use said COM2 serial modem dialling in(which establishes a TCP connection to telnet when it's answered using the AT command)? Telnet should be able to dial it.
The main issue is telling Minix to use the COM2 serial modem in autoanswer mode?
Any idea how to pass it these boot parameters?
I have no idea how things like the "edit" command actually works, what parameters to pass through it etc. ?
https://wiki.minix3.org/doku.php?id=usersguid … x3_boot_options
UniPCemu Git repository
