IBM(CyriX) 6x86 quary.
First post, by Caluser2000
Just pulled out a Socket 7 MSI P54C TR6 from storage. On it is an IBM 6x86. Model no.IBM26 6x86-2V212*** cpu on it. I've done a internet search and can not find much at all about this cpu other than it was made by Cyix for IBM.
Reply 1 of 18, by Nemo1985
There is not much to say, it's a cyrix rebranded, usually ibm cpus were a little more overclockable compared to cyrix ones but that's the only difference.
Reply 2 of 18, by Caluser2000
6x86-2V212***are not listed in cpu pages about any of the IBM or Cyrix 6x86 cpus. Hence the reason for OP....
Reply 3 of 18, by rmay635703
All my Cyrix chips were ibm branded and that one appears to be missing a line of text
I would fire it up on a super 7 board with a low voltage, multipler and bus and see if you can run any diagnostics, earlier chips didn’t have any cpuid but still worth a try.
Reply 4 of 18, by Horun
Caluser2000 wrote on 2020-12-31, 23:29:
I think yours is a IBM26 6x86-2V2120GB, like the one here: http://www.cpu-galerie.de/html/ibm6x86.html
and here: https://www.cpu-world.com/CPUs/6x86/IBM-6x86-2V2120GB.html
Reply 5 of 18, by Caluser2000
There is no indication at all the any text apart from the IBM26 line. Underneath it is perfectly clear.
Reply 6 of 18, by Caluser2000
Horun wrote on 2020-12-31, 23:43:
AWESOME Horun. Thank you for looking for it.
The mobo has 64megs of ram of 4x16meg 72 pin FP simms. Fairly high for the time. I wonder what OS it was running?
Reply 7 of 18, by debs3759
That's the only part number which fits what we can see.
Reply 8 of 18, by Horun
You may be able to verify that by checking the last number on the bottom, should be a ##H#### and compare to this list:
http://www.cpu-galerie.de/html/ibm5x86-fru.html
If there are no numbers on the bottom between the pins then that is as good a guess as I can make 😀
Reply 9 of 18, by Anonymous Coward
Cyrix was fabless. During the early days of 6x86, all of their chips were produced by IBM and ST *for* Cyrix, not the other way around. As part of the deal, IBM and ST were allowed to sell the Cyrix chips under their own name.
What you have is a very early example of an IBM branded 6x86 that pre-dates the P or PR system. This chip should be pretty much identical to a P150+
I really liked the look of these earlier specimens. In my opinion when they switched to the MS-comic font, it really gave it a cheap look.
Reply 10 of 18, by Caluser2000
Under the chip is:
COPYRIGHT USA
1995 CYRIX
IBM9314 Q14039
75H1233 QH
Thanks everyone who supplied useful info. 😉
Reply 11 of 18, by Horun
Cannot tell what OS it would have been running, maybe OS2 2.1 or maybe upgraded to Win95, both can handle 64Mb.
I do not find many references to MSI P54C TR6 (MS-5137 ?) from a quick search and it is missing from TH99 if I got the MS# correct .
Can you take a good picture of the motherboard ? and maybe save the BIOS ?
Should be a Intel 82437VX based (if my quick search is good) and a good board but there is very little info on it.
Reply 12 of 18, by Caluser2000
Here you go...
Reply 13 of 18, by pshipkov
Anonymous Coward wrote on 2021-01-01, 00:24:
Cyrix was fabless.
Interesting point that got me thinking.
From today's point of view and through the prism of time - yes, that is true.
But back in the day nobody was bragging about getting a new Cyrix cpu.
Or were they ? Certainly not in the space I had visibility into.
Wonder if perception was different elsewhere ?
retro bits and bytes | DOS media library
Reply 14 of 18, by Caluser2000
I think at the time at the same clock speed 6x86s were faster than Pentiums. The FPU performance was no were near as good though.
The DLC range was fairly popular for those with 386DX mobos. 5x86 upgade packages with interposer from the likes of Kingston and Hypertec were useful for your 486. These had AMD or Cyrix cpus.
Reply 15 of 18, by douglar
6x86 CPU’s were pretty exciting at first from a price performace ratio. But the extra heat and early compatability issues put a damper on things pretty quickly. And it didn’tplay quake very well either, which wasn’t so awesome.
I always though the last generation of the M2 packaging had sophisticated aesthetic .
Reply 16 of 18, by The Serpent Rider
On the contrary. It's simplified design, with heatspreader just crudely glued directly on FCBGA style crystal with no additional support.
Reply 17 of 18, by douglar
The Serpent Rider wrote on 2021-01-01, 13:55:
There are lots of different sources of nostalgia and aspiration that serve as the lenses through which we view and value computer history.
Reply 18 of 18, by amadeus777999
douglar wrote on 2021-01-01, 13:44:
6x86 CPU’s were pretty exciting at first from a price performace ratio. But the extra heat and early compatability issues put a […]
Awesome looking.
