A high end Multi Core (775 or AM3+) Windows XP build
Reply 20 of 100, by fosterwj03
XP could play 4 games at the same time on a Quad Core! Just kidding.
Some XP compatible games like Crysis can use resources from all available CPU cores. Multiple CPU cores can also off-load additional background tasks from the primary core.
I think the QX family uses a Socket 771 vice Socket 775. The Quad Core models for Socket 775 run at lower clock speeds stock compared to the Duo Core models (you could overclock them though). They also run with higher power consumption.
Reply 21 of 100, by SPBHM
Lazar81 wrote on 2021-02-27, 19:31:
cyclone3d wrote on 2021-02-27, 18:41:
Why limit to dual core when you for have quad core?
Intel QX9770 or QX9775.
AM3+ will have way higher RAM throughput due to the on-die RAM controller and CPU will be a bit faster as well... Around 1st gen i7 speeds if you go with a Bulldozer CPU.
As I understood, most XP games run on one core. So using the other one for background tasks will justify dual core... I don't think that XP would profit that much from 2 more cores.. but maybe I'm wrong.
XP was viable for gaming (new big budget games) until 2011/2012, plenty of games are going to use at least 2 cores, many will have some benefit from 3-4 cores,
it really depends on which games and which performance level you are targeting in the end...
Reply 22 of 100, by Lazar81
fosterwj03 wrote on 2021-02-27, 18:44:
My Geforce GTX 750 Ti works with XP. You can go up to a GTX 980 Ti with XP drivers (good luck finding one for a decent price right now 😀 ).
I used a Radeon HD 5570 with my E8500 back in the day.
I have a sapphire 5770 lying around here.. that should do a great job...
Ryzen 9 5900X - ASUS ROG Crosshair VIII Dark Hero - 32GB RAM - Nvidia GeForce GTX 1080 Ti
Reply 23 of 100, by Miphee
Because they cost $250 and $800 while a E8600 costs $15.
Reply 24 of 100, by Lazar81
Well if Quad core would really be an overall improvement... Then maybe a core 2 quad q9650 would be a good pick
Reply 25 of 100, by texterted
Lazar81 wrote on 2021-02-27, 18:35:
Nice... What graphics card do you use?
It's in my sig!
Oh, I have a Q9550 too and the dual core seems much better for the games I play. Runs much cooler too.
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 26 of 100, by Lazar81
First idea:
An ASUS P5E3 PRO with a Q9650 and a Radeon HD 5770..
Reply 27 of 100, by texterted
I just don't like the x48 chipset. In fact that's the only Asus board that's failed on me, but that was a Rampage Formula.
Cheers
Ted
Reply 28 of 100, by Lazar81
Another idea:
AMD FX-4350 - Mainboard ???? - Radeon HD 5770
Reply 29 of 100, by cyclone3d
fosterwj03 wrote on 2021-02-27, 19:38:
QX9770 is LGA775 and QX9775 is LGA771. Super easy to convert a 771 CPU to 775 though. Just a sticker and trim the socket plastic so you can rotate the CPU.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30 of 100, by SPBHM
Lazar81 wrote on 2021-02-27, 22:08:
Another idea:
any particular reason for that and not something like the i5 2500?
that's a faster and older CPU than the FX 4350, perhaps even cheaper to get.
XP support should be as good.
Reply 31 of 100, by Lazar81
Ya... Both ideas no dual but quad cores .. 🤔.. rejecting later intels is hard to justify... Have to sleep a night and then think again...
Reply 32 of 100, by Warlord
Used a X3380 in my X38 Rig. But it's a rare CPU now. You can pin mod a 771 and get the same performance.
I build it in 2009 on a supermicro C2SBX and it still works.
Not a speed demon but at the time it was pretty fast.
However 100% stable and has never crashed on me once.
Reply 33 of 100, by Repo Man11
My XP build is an EP43-DS3L with a Xeon X5460 and an HD 7800.
Reply 34 of 100, by SPBHM
if you are going the Xeon route,
AFAIK X38 and X48 can't run the Xeons, p45/p35 and such can,
and the E5450 for example would have a 80W TDP, the X varian a higher TDP
Reply 35 of 100, by CwF
A few years ago I couldn't help myself. I recycled my super hypervisor server into an ultimate XP machine. My favorite Q6600/C2SBC blew up, so I thought I should build a 'last one'.
SuperMicro X8DTi with dual X5687's
AMD Sky 500 4GB ECC Pitcairn
>4GB, much more 21.9GB something odd pae ramdrive. More handy downs to come, 48GB likely max. ?
It actually works....really really good.
Always threads OFF, often restricted to 2 duals, or totally wasted 2 single cores.
Actually runs cool too.
That Q35 was a favorite...
I used to know what I was doing...
Reply 36 of 100, by Warlord
SPBHM wrote on 2021-02-28, 02:55:
x38 and x48 were made to run the highest clocked 1333 FSB xeons. These were also the 1st platforms to run DDR3. The X38 and x48 were marketed as workstation chipsets. P45 is just a desktop chipset in the eyes of intel so Its the other way around.
Reply 38 of 100, by Shagittarius
My XP machine is an X5960 with a 780Ti. I consider it complete overkill for anything I would choose to run on XP.
