First post, by qwweee
is it possible to create a shortcut that will start a game with dosbox instead of start the game everytime through dosbox and do all the process of mounting that can be long and annoying ?
if yes, how to create that shortcut ?
Reply 1 of 3, by eL_PuSHeR
I advise you getting a front-end.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by qwweee
a what?
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you can do what you want to do.
most information for that can be found on this forum or in a file called readme.
A frontend can be found on the download part of the dosbox website.
It's a utility that keeps tracks of all settings of all games and makes running the game a simple click.
if you download
D-Fend or DBGL then the frontend can make shortcuts for you.
Water flows down the stream
