Reply 40 of 55, by JimWest
cyclone3d wrote on 2021-05-20, 06:53:
Soundwave 32 Pro (comes with QSound ld file (3DFM.LD) ) while the other cards you needed to buy it as an addon. I just happen to have the install files for the Soundwave 32 Pro so I will be testing this out.
I have the Orchid Soundwave 32 Pro here with me. Unfortunately not the drivers.
@cyclone3d Can you please upload the drivers? I have not yet found a source on the Internet.
Many Thanks!
Reply 41 of 55, by cyclone3d
Pierre32 wrote on 2021-05-20, 10:17:
Hmm this has my interest. Just went digging for some sound samples. […]
jesolo wrote on 2021-05-20, 09:30:
I have acquired two 512KB ROM chips in order for me to try out the Invision ROM images.
Orchid standard: http://kawai.spb.ru/files/sound/cards/orchid_sw32_std.html
Orchid w/ Invision: http://kawai.spb.ru/files/sound/cards/orchid_sw32_invis.html
What's the deal with having two ROMs on the Orchid? Does that mean you can install two banks, or do they combine to make one bank?
They combine to make one bank.
Yamaha YMF7x4 Guide
Reply 42 of 55, by cyclone3d
JimWest wrote on 2021-05-20, 13:33:
I have the Orchid Soundwave 32 Pro here with me. Unfortunately not the drivers. @cyclone3d Can you please upload the drivers? I […]
Many Thanks!
The driver set is available on driverguide.com. It is labeled as the Soundwave32 + SCSI but the files inside the .zip match what is described in the user manual for the Soundwave32 Pro. The install looks like it has to be run from within Windows 3.1. Not sure if the installer will work from Windows 95 or not.
https://www.driverguide.com/driver/deta ... rid=15632
And the manual:
soundwave_32pro_manual.zip
228.83 KiB
18 downloads
Yamaha YMF7x4 Guide
Reply 43 of 55, by jtchip
Speech is slower than normal with the Gamewave32 drivers - tried 1.4 and 2.3. Hilariously sounding voices in DUNE2. This is only when using the GENMID.LD from these sets. When using these drivers and the DSP001WA.LD from the Cardinal driver set, the speech is normal. This leads me to believe that the Cardinal cards and the Orchid cards are clocked differently.
That matches my experience of using Orchid's GENMID.LD with a Wearnes Beethoven ADSP-16, another card with the same ESC614/ADSP-2115/AD1848 chip combo, as well as MT32.LD producing no sound with MIDI output. That card is should be a reference design as it ships with reference drivers (driver identifies itself as "Analog Devices Personal Sound System (PSS) Driver") so perhaps Cardinal stuck closer to the reference design.
Reply 44 of 55, by JimWest
cyclone3d wrote on 2021-05-20, 14:28:
The driver set is available on driverguide.com. It is labeled as the Soundwave32 + SCSI but the files inside the .zip match what […]
Many Thanks!
And the manual:
Thank you for the links and the information! 😃
Reply 45 of 55, by cyclone3d
Bumping this since I have added some more information to my huge post about everything.
I am almost 100% sure I figured out why the speech is slower with the Orchid .ld files when used on other cards.
I'll probably compile everything and make a master thread for the ECHO based cards once I have finished looking into them.
Yamaha YMF7x4 Guide
Reply 46 of 55, by Pierre32
Sounds good. I've retrieved mine this weekend and I'll get the chance to reinstall again some time this week - to do some of the above tests, but more importantly test my driver package and make sure it's correct on Vogons Drivers.
Reply 47 of 55, by cyclone3d
Tested the SoundWave32 Pro driver set and have updated my huge post. Basically the digital sound is of course slow just like the other Orchid drivers.
Yamaha YMF7x4 Guide
Reply 48 of 55, by cyclone3d
I think I've gathered all the different driver sets that still exist on the web. Have the ones for Wearnes, Paradise, Cardinal, and Orchid.
Also have a bunch Analog Devices documentation and I picked up this (seller's pic):
242.81 KiB
I still need to see if Analog Devices has and is willing to give me a copy of the SDK for these type of cards:
http://web.archive.org/web/19980212183702/htt … oducts/pss.html
Yamaha YMF7x4 Guide
Reply 49 of 55, by jtchip
That devkit looks pristine.
I remember there was an MPEG Layer II (MP2) audio decoder for the ADSP-2115, it's dsp_mp2 for Linux from https://www.mpg123.de/download.shtml.
The code is mostly a kernel module that uploads the DSP code, which is only available as a hex dump so hopefully the devkit has a disassembler.
It only mentions the SoundWave32 with 20 MIPS so who knows if it works on the slower variants (nice find on the different clock speeds, BTW).
Reply 50 of 55, by Pierre32
cyclone3d wrote on 2021-05-19, 01:43:
Th files all look correct to me. I thought it may be something with my system but I've tried multiple floppies and it always has […]
cyclone3d wrote on 2021-05-19, 00:05:
Just as an FYI, the installer on the driver disk doesn't work for the package you put on vogonsdrivers. Says that it can't load the script.
I have another copy of the disks and the installer works fine.
Pierre32 wrote on 2021-05-19, 00:11:
Thanks for the heads up. They would have worked for me in the past of course. I'll test them on the impending install and see if I've done anything wrong when repackaging for upload.
Th files all look correct to me. I thought it may be something with my system but I've tried multiple floppies and it always has the same problem. Maybe the zip or upload got corrupted or something.
I noticed on my copy that it doesn't copy over all the .ld files so I may make a customized install script that does just so I don't have to copy them over manually.
I've confirmed that there was something wrong in the package I uploaded, but the original disks I made were working fine. The only difference I could see in the files was that INSTALL.BAT was 20 bytes (working) vs 19 bytes (not working). They both contain the same simple line "instalit dsp16.inf" so I can't explain why they would differ or how that happened. Anyway, thanks for reporting and I'll fix my uploads.
You're right about it not copying over all the .ld files too. I guess the stock installer only cares about copying over DSP001.ld - a detail I had missed after doing so much manual file wrangling at the time. I spent way too long tonight wondering why my card had installed fine but wasn't making any noise. It was because I'd loaded DSP001WA.ld in config.sys but the file wasn't there, d'oh! Perhaps I could also add "copy *.ld" to the install script before re-uploading.
cyclone3d wrote on 2021-05-17, 03:25:
What does your system report when you run DSP16ver ?
Mine currently reports 41.117
"DSP16ver Version 1.0......dsp firmware revision is 1.07"
(DSP001WA.ld loaded)
Reply 51 of 55, by Pierre32
Driver package has been updated. Changes:
  • Working install script on disk 1
  • Larger set of firmwares, which are now copied over by the install script
  • Wavetable ROM, with attribution to cyclone3d (thanks!)
  • Improved setup instructions in the readme under /docs
https://archive.org/details/cardinal_dsp16
http://www.vogonsdrivers.com/getfile.php?file … &menustate=38,0
Reply 52 of 55, by cyclone3d
I heard back from Analog Devices. They don't have the old SDK anymore. Bummer.
Yamaha YMF7x4 Guide
Reply 54 of 55, by BitWrangler
I did 20 rounds against teh interweb for one of these some time ago, the DSP chip intrigued me. At that time Cardtech dot com was owned by a clickfarm/redirector outfit, must have got it after Cardinal closed up, but they put a robots.txt on it meaning archive.org blocked access to previously archived content from Cardinal. (Policy changed now I think to stop that kind of stuff) I may have found my way to analog devices. When I remember even what machine I was using at the time of that quest, I'll try to find the hard disk and see if I harvested anything interesting. All I can think of at the moment, is that I must have had some want/need to learn about DSP chips, or play with one because I had a potential application.
Reply 55 of 55, by cyclone3d
Pierre32 wrote on 2021-06-03, 22:19:
Dang. So it obviously doesn't come in that dev kit you bought?
No, I don't see any mention of it anywhere. From what I could find, there was probably a special SDK just for these type of cards. The AD dev kits seem to just have the stuff for the AD developed DSPs and nothing for the ECHO gate array chips.
I wonder if there is good documentation in any of that HAM radio stuff that would help.
Yamaha YMF7x4 Guide
