First post, by thegenerallee86
for my IBM PC Series 350 P75 so I can see if the windows 1.0 disks work or not that I bought because I don't believe they'll work on my zenith 386 5.25 drive bay I don't beleive is working properly and I don't have any other 5.25 disks to try on it. On boot the zenith computer the 5.25 Drive light is always on and when I boot the machine I get drive not ready with no disk in it, also it does not have a Hard Drive.
Reply 1 of 33, by Deunan
Standard (modern) height? You need 360k or 1.2M drive? In general I recommend the TEAC FD55 -R series, can't go wrong with those, easy to service too. Those come with black and beige front covers as well so pick one that looks better.
Or, if it's just for testing, a floppy emulator might be better suited to your needs.
Reply 2 of 33, by thegenerallee86
Deunan wrote on 2021-06-04, 15:23:
I would guess standard Height and 1.2M cause I believe that is what's in the zenith and I want one for my IBM PC Series 300 P75 as well which I plan to get the same one.
Would this one work?https://www.ebay.com/itm/203483390103?hash=it … bUAAOSw6CpgukM2
Reply 3 of 33, by Deunan
thegenerallee86 wrote on 2021-06-04, 15:34:
The FD-55GFR will work, unless those systems have non-standard floppy cables. Even then it should be a matter of an adapter. Make sure there is a standard AMP/Molex power connector, if so and the ribbon cable is 34-pin then I see no reason it wouldn't work. I have several of these TEACs and none of them is giving me any trouble.
Reply 4 of 33, by thegenerallee86
Deunan wrote on 2021-06-04, 16:30:
Ok that is what I will do then and as far as I know the zenith has the correct slot cable but I believe I will need the adapter for the IBM PC Series cause I don't think it has slots on it.
Reply 5 of 33, by Caluser2000
What year and model is you Zenith 386? Also what do you mean by "slots" in the IBM? ISA slots or something else?
Zenith did some weird things. Like I can not just fit in a common 3.5" in to my Zenith 286LP Plus. The front plastic bezel needs to be altered to fit correctly.
Reply 7 of 33, by thegenerallee86
Caluser2000 wrote on 2021-06-04, 18:56:
It looks like this one: http://www.bitsavers.org/pdf/zenith/brochures … hSpeedZ-386.pdf
I don't know what you call them where the drives have the bus card slot like connection on the back and the ribbon cable slides onto it?
Reply 8 of 33, by Caluser2000
thegenerallee86 wrote on 2021-06-04, 19:12:
You can get adapters to go from a normal fdd ribben cable to 5.25" drive connectors/contacts. Older fdd cables have both types of connector on them . Maybe a Vogons member close by could supply you one for just postage. Those of us who have been using these ol systems for a while will have at least one box full of various fdd cables.
    619.8 KiB
Reply 9 of 33, by Caluser2000
AlessandroB wrote on 2021-06-04, 18:59:
it can be handled by a modern PC with mainboard floppy connector (SocketA) or need a old computer?
With this drive you can read/writhe every 5 1/4 format/capacity floppy?
tnks
It's not a good idea to format 360 floppies in 1.2meg 51/4" drives because of the way the drive sets up the disk. They will be hit and miss if trying to read in a 360k 51/4 drive. 1.2meg 51/2" fdds should be able to read 360k and 1.2meg 51/2" ok Just be aware t hat even some fdds wont read a floppy because of the fdds head alignment on the fdd that created the floppy is different than the fdd reading a floppy disk. Reading a 360k disk that was created on a 1.2meg fdd should be ok.
Folk go for fdd emulators and using disk images to make life easier. No head alignment or cleaning needed. But first you need a real fdd drive to create those disk images 😀
Reply 10 of 33, by thegenerallee86
Caluser2000 wrote on 2021-06-04, 19:29:
Yeah that would be nice and would be will to buy one too.
Reply 11 of 33, by Caluser2000
thegenerallee86 wrote on 2021-06-04, 20:35:
What is your location?
Reply 12 of 33, by thegenerallee86
Caluser2000 wrote on 2021-06-04, 20:51:
Orange, VT, USA
Reply 13 of 33, by thegenerallee86
I bought the one which I listed earlier this one: https://www.ebay.com/itm/203483390103 Which is the Teac which is the TEAC FD-55GFR 149-U5 5.25" Internal Floppy Disk Drive
Reply 14 of 33, by Caluser2000
Got your pm thegenerallee86. I live in Palmerston North New Zealand so the postage will most likely be more than the cable is worth;)
There must be a vogons member closer that can provide you with one.
Reply 15 of 33, by Brickpad
thegenerallee86 wrote on 2021-06-04, 21:13:
Orange, VT, USA
I'll PM you. I'm over in New Hampshire not too far from you. I don't mind mailing you a floppy cable. No charge.
Reply 16 of 33, by Caluser2000
Brickpad wrote on 2021-06-05, 01:58:
Orange, VT, USA
Well done Brickpad. This is what a community like this is all about.
Reply 17 of 33, by Brickpad
Caluser2000 wrote on 2021-06-05, 02:07:
Orange, VT, USA
Happy to help a fellow Vogoner out. 😀
Reply 18 of 33, by thegenerallee86
Orange, VT, USA
Thank You and it I need to have both Pin and the slot type for my IBM PC series 350 P75, also the distance between both connections has to be 5 or 6 inches because the 2.5 floppy sits on top of a cd drive and the 5.25 will put below the cd drive. Does anyone know what you call those type of connections on old floppy drives where it looks like a pci card type connection?
Reply 19 of 33, by Brickpad
thegenerallee86 wrote on 2021-06-05, 10:41:
Orange, VT, USA
I believe that is called a single edge connector.
