Hi everyone 😀 ! It has been almost 3 years since the last post in this thread. I have a similar problem and therefore I thought I should rather post it here than in a new thread.
My mainboard is a "Unichip 367C Rev 1.0" or "UNI-386WB". The following picture is from amoretro.de:
The attachment unichip_uni-386wb_386_dx_40_cache_motherboard.jpg is no longer available
My board is the same model and revision. It has an Am386DX-40 Revision D -PQFP-CPU. My board also came without the PGA 132 socket. I soldered in a PGA 132 socket. This is my board, PGA132 soldered in, 486DLC plugged in:
The attachment my board.png is no longer available
Without the 486DLC in the PGA 132 socket the board detects the 386DX CPU:
The attachment 386DX.png is no longer available
The 386DX gets mildy warm and everything seems stable.
When I plug in the 486DLC the board detects a 486SX CPU (see screenshot):
The attachment 486sx.png is no longer available
Now this is where the problems start: with the 486DLX plugged in, the board only boots sometimes. It takes a couple of tries (power on/ off).
In any case (whether it boots or not): The 386DX gets dangerously hot within seconds.
I did a quick measurement this morning. With the 486DLC plugged in I measured the 386DX FLT pin and it seems to be connected to GND (0 Ohms to mainboard power connector GND, mainboard off, AT- power-connector disconnected). I will repeat this tonight with more time, just to make sure that I didn't accidentally hit the adjacent GND-Pin. These tiny PQFP-Pins are hard to count with my vision 😉.
Keropi reported that his 386PQFP-CPU still got hot after the FLT-pin-mod.
So what should I do now? I dont really want to remove the 386DX entirely since Balthazor4ever destroyed his board that way.
Any ideas? At first I should probably repeat the measurement on pin 54 (FLT).
