Sound Blaster: From best to worst
Reply 120 of 184, by Burrito78
perhenden wrote on 2021-03-22, 09:01:
I found a model not mentioned in the list, and thought I would contribute.
The CT3630. I've just seen a picture of it (attachment). Hopefully chips and versions can be identified from this single image.
Thanks! Great list.
Thank you! If there is a photo, i will gladly add cards to the list.
Member of DOSBox Staging
Reply 121 of 184, by Burrito78
zoinknoise wrote on 2021-03-21, 22:22:
nice work on the latest update. i really have to say though, i am uneasy with the "Self Noise" column and how it's purely based […]
nice work on the latest update. i really have to say though, i am uneasy with the "Self Noise" column and how it's purely based on the DAC. it's uncomfortably close to those endless arguments in audiophile forums comparing two CD players, one with 64x oversampling DACs, and the other with 128x oversampling DACs, and how the latter has to sound far better. (in reality of course, nobody can actually tell the difference under blind, controlled ABX testing.)
i own many Sound Blasters, including a CT2760, CT3900 and CT3980. i cannot honestly say that the CT2760 has "high" self noise, compared to a CT3900 or CT3980, just because it has a slightly older DAC. i just think it's a misleading way to put it. the DAC is one of the least important factors for determining noise on an old sound card, just look at this thread. these cards are full of strange DSP issues, mixer issues, clipping, etc... all of these cause much more noise and distortion than the DAC. the PCB design of a sound card has far more impact on noise than the DAC. noise can leech into the card from a busy ISA bus with lots of cards, and the DAC won't help you at all there.
quite frankly, i would argue the #1 source of self-noise on an old sound card is the high number of old, dried-out electrolytic capacitors. i learned that lesson when i replaced all the electrolytic capacitors on my CT1350B. it instantly went from being borderline unusable, to being a decent sounding card. that showed me where the noise is really coming from on these old cards, not the DAC.
i would like to suggest that the "Self Noise" column be retitled "DAC," and it should simply list the model of the DAC. that way, if someone believes that the DAC on their card affects the noise floor, they will already know which part numbers to look for, and which to avoid. plus, the chart will be providing more good information, because right now it doesn't actually list the DACs being used on each card, besides CT1703.
Thanks for the feedback, always appreciated!
The source of the information in the self noise column is basically the info from this thread: Sound Blaster 16 Bugs and Deficiencies Summary
JamesF is a very informed and proven source for Soundblaster information, not just on Vogons. And he is one of the few people who actually went so far and did measurements on some cards. Since he wrote about the self noise in this thread as "facts" and no one challenged him on that for years i included it in this list as "facts". I know that its still a VERY broad generalisation of actual performance of these cards for numerous reasons (as you described).
I think someone should start a new thread "Sound Blaster measurements" and define a measurement practice and setup. Then actual data could be collected and if enough data comes together we will get a complete picture slowly.
I can add some more information to the Self-Noise description to make it more clear what it means and how the information there is to be interpreted.
Thanks again for your input.
Reply 122 of 184, by perhenden
Burrito78 wrote on 2021-03-22, 09:14:
I found a model not mentioned in the list, the CT3630.
Looking at the photo (attached to my post), I see it's a
CT3630 AWE32 Value, no Yamaha/OPL3, CT2502 chip, no wavetable header (and revision 01, 1995, week 48). Can't spot any CT1703 chip on the board.
Reply 123 of 184, by Rawit
I've just tested the ASUS I-A16C revision 1.2 which is sort of a CT2960. I can confirm the bugs are the same as the CT2960. Hanging notes in Doom, delays in Duke 3D with 44khz mixing and hard clipping in Skyroads. It has a wavetable header with I think is reversed stereo (tested with the Yucatan FX revision B, will test with another daughterboard soon).
Edit: just noticed that this card makes Mortal Kombat II hang when the MPU (wavetable header) is used. In Attract mode it lasts a couple of rounds before it hangs and sustains the last note played. This issue is not present when using FM. Jazz Jackrabbit has lots of crackle, probably the hard clipping.
YouTube
Reply 125 of 184, by Burrito78
CHANGELOG 2021-04-19
-We are now on Google Docs
Filters and sorting!
Always up-to-date
XLSX export of latest edit also available
-Added CT3630 thanks @perhenden
-Lowered SB16 Self-Noise „traffic light“ from red to yellow, changed text from „High“ to „Noisy“
-Revised and expanded all the descriptions of the different bugs and deficiencies
Reply 127 of 184, by appiah4
Well that saves me from having to update my own Excel everytime you made a revision :lol
Reply 128 of 184, by Metalliferous
Just registered to thank you for this nice overview 😁
If you ever want me to do any measurements on noise, I've got the following:
CT3980 AWE32 with CT1703-A
CT2770 SB 16 with CT1703-TBS
CT4520 AWE64
Reply 129 of 184, by Burrito78
Welcome @Metalliferous! Very much appreciated!
Also thanks to this awesome community (and probably Google), this thread reached well over 10.000 views by now!
Regarding noise measurements: Its a different topic but results should absolutely be merged into this document, yes.
I hope that someone with audio measurement experience and a lot of time on their hands will create a new topic for this and collect hundreds of results to get a "good enough" dataset.
Reply 130 of 184, by matze79
CT4170 rocks for headphone usage
Reply 131 of 184, by appiah4
matze79 wrote on 2021-06-14, 08:21:
What makes it better than the others? Cleaner amplification? I suppose it is one of the most integrated SB16s.
Reply 132 of 184, by Burrito78
If you don't mind CQM (or actually prefer it because you had it back in the day and that was how your games sounded), then yes. Also if you don't need a WT header and can live with the other Vibra limitations...but Vibra cards have a wonderfully clear sound (maybe too clean 😀) and have no DMA clicking!
Most important is that you enjoy what you have and like!!
Reply 133 of 184, by matze79
appiah4 wrote on 2021-06-14, 08:33:
Full integration makes it less noisy. It sounds very clean.
Well.. i prefer CQM without Static Noise and Bus Sounds over OPL3 with Noise.
Reply 134 of 184, by appiah4
matze79 wrote on 2021-11-30, 18:22:
I can't fault you for that.
Reply 135 of 184, by aitotat
I just tested three Vibras with Skyroads since it is very easy and fast to test the clipping bug with Skyroads.
I tested CT3930 with Vibra 2501, CT2800 with Vibra 2504 and CT2940 with "Vibra pro" 2502. I used CT2770 and CT3670 (the AWE64 with SIMMs) as a reference.
No surprises with Vibra 2501 and 2504. Clipping can be easily heard and mixer settings do not affect it. But I was surprised that CT2770 also clips. Not as bad and it can be fixed with mixer settings. But I had to set master and voice to one less than half to get rid of it completely. No clipping at all with CT3670, not even with maximum volume settings (just like there shouldn't be any clipping).
But the CT2940 with Vibra 2502 was very pleasant surprise! No clipping at all, not even with maximum volume settings. So it behaves just like the CT3670. And since my CT2940 has real OPL3, I prefer it over the AWE64 models. But the spreadsheet says CT2940 has the clipping bug but my card does not! Is it an error in the spreadsheet or are there broken and fixed revisions of Vibra 2502?
Reply 136 of 184, by Burrito78
The problems on your CT2770 are surprising indeed. Maybe there is a version of the Creative Mixer that can set the main amplification (1x, 2x, 4x) on inputs and outputs? I remember i had these on some cards/driver versions. Should be always set to 1x, if clipping occurs.
Also there could be jumpers for Line or Speaker level output that should be set to line level if possible. Check these too. Third, the card could be faulty or have a revision that produces clipping because of a design/parts issue.
The clipping reported for the CT2940 is no error in the spreadsheet as i own that card myself and tested it. See results here: My journey to a bearable Sound Blaster 16 model
What is your board revision? This is a number in the lower left of the card in the form of revision/year/week.
You could open a new thread with your findings, maybe other CT2940 owners will chime in with their results.
Reply 137 of 184, by aitotat
Here are pictures from the good CT2940.
I tested three more cards, CT1770, CT2290 and CT3900. No clipping and there should not be. So the CT2770 is the only non-vibra that clips. Here are some pictures from it. It has no jumpers for amplification. As for the mixerset.exe, I used version 2.18 (I think that is the last version). All the gains were set to 1x and AGC and 3D was disabled when supported by the cards. So mixer values should be the same for all tested cards.
I don't know if the CT2770 is broken or not. Maybe it could be since it was the only non-vibra to do that. But it is also the only card with CT1745-S mixer. The others have CT1745A, CT1745A-S or CT1745A-TBP. But it is also the only one with CT1703-T DAC so maybe just a bad mix of chips.
From the pictures you might notice that the CT2770 does not have a bracket. Actually the CT2940 came without bracket. It was sold as untested and for parts only on ebay but it actually works perfectly. So I then got the CT2770 to be bracket donor since it is not interesting or good card. I tried to find broken or at least a bad card and it seems it was even worse than expected so a good donor for a bracket.
Reply 138 of 184, by appiah4
I have a CT2770[A] in my 5x86 PC and don't remember experiencing clipping, please tell me which game does this for you? Maybe the amplifier on your card is defective?
