Reply 39660 of 57048, by dinth
Not really "bought" as it was a giveaway on this forum but still I'm so excited and grateful.
Currently I'm struggling to get refresh rates over 75Hz but that's maybe my Radeon 9250
Reply 39661 of 57048, by debs3759
cyclone3d wrote on 2021-06-30, 15:59:
debs3759 wrote on 2021-06-30, 15:24:
Intel486dx33 wrote on 2021-06-30, 15:22:
I have my AMD K6-3+ 450 over clocked to 500mhz and 550mhz running stable. You can probably get 600mhz out of yours. […]
Link:
AMD K6-III+@550mhz., Voodoo-3 / 3DFX / MMX / 3D Now (tower)
AMD K6-lll+@500mhz., Voodoo 3000 (desktop)
I might source a waterblock and hook it up to my chiller. See if I can get even higher (guessing 660 is possible with the right cooling)
You're going to have issues with condensation with a chiller. Might even get condensation under the heat spreader.
When I used the water chiller before, I found that I only got condensation if I set it lower than 10C, so that's where I'll set it.
Reply 39662 of 57048, by mkarcher
debs3759 wrote on 2021-06-30, 20:19:
The temperature you start getting condensation at is called the "dew point". It depends on the temperature of your room and the relative humidity. A dew point of 10 °C is common in climate environments humans feel comfortable in (50%r.h., 20°C room temperature), but if you have hot days with high humidity in the summer, you might have 80%r.h. at 30°C, which would result in a dew point around 26°C.
The only thing you can know for sure: Unless you are in an extremely wet room, the dew point always is below room temperature, so you don't risk condensation with the chiller set to keep the water at room temperature (or just a couple of degrees below room temperature).
Reply 39663 of 57048, by Intel486dx33
I used the default voltage settings. What ever is printed on the CPU is what I used.
No need to up the voltage. Over clocking works fine at default voltage settings.
I would start with the default settings and if needed slowly up the voltage from there.
Reply 39664 of 57048, by debs3759
Intel486dx33 wrote on 2021-06-30, 23:37:
I used the default voltage settings. What ever is printed on the CPU is what I used. No need to up the voltage. Over clocking wo […]
I'm pretty cautious about voltages when overclocking. Don't want to kill a chip that might be worth a relative fortune to someone when I start selling my collection in the future 😀 Will raise the voltage by a small amount though, as long as I can keep it cool. Never know, I might break a record for non extreme cooling on hwbot 😀
Reply 39665 of 57048, by BitWrangler
Thrift haul... there's still stuff in the thrifts... well not this one now... okay, I left a couple of modems... yes I am supposed to be rationalising and clearing out, but I am missing a lot of bits and pieces to make things whole or make balanced keepers...
Top left SMC 16bit ISA 10bT NIC, top right, Rage 128 all in wonder? Bottom left 3c905B, bottom right, 2 assorted bags of RAM. 1 bag seems to have 1GB DDR-400, 512MB DDR-400, 256MB PC133, 8MB 72 pin, 4Mb 72 pin. The other, 256MB PC133, the twins of the 8 and 4 in the other bag, and possibly a pair of 16MB 72, gotta look up the chips. Happy about pretty much all of those but the 4MBs 🤣 SMC has a chip inside the ROM socket, between it's legs, not inserted, dunno yet if that's cache or flash or what.
Edit: Yisss, 16MB 60ns EDO two of.
Edit2: Ohhhhkay, it's an 8kilobyte by 8 SRAM on the SMC, it's an EtherEZ, what does EZ stand for but everyone's favorite friend (Next to Clippy) Plug'n'Play.
Reply 39666 of 57048, by appiah4
I received a small package from a fellow vogoner who is letting go of some of his collection. Fantastic items in great condition, thanks mate. I hope you don't miss these too much a few years down the line. Drop me a line in case you ever need any hardware 😀
The CT1740 pretty much completes my SB collection (I have like 30 ISA SB cards now..), I just need a Pro and a Pro 2.0 at this point.
Reply 39667 of 57048, by mpe
Got Buslogic VL-Bus SCSI card:
Boxed with manuals and everything.
Blog|NexGen 586|S4
Reply 39668 of 57048, by LuckyPiquel
Got this Cyrix 486dlc recently, just because the packaging was different from what I usually see in case of these CPUs. Is this packaging actually anything special?
Reply 39669 of 57048, by BitWrangler
Maybe an early one, since it's more like how they packed their Fasmath chips?
Got tracking on my three pieces of new in box GF 6200 PCI from eBay ... I had limited pieces of 3D PCI cards, and wanna put them in close to period systems, rather than in stuff that can only take PCI, like an Atom board I've got, and a duron and s370 board with onboard gfx and no AGP. So being a later low end card, I'm kinda moving it a generation earlier to use in place of something hard to get or $$$. I'd call these notional builds "trans-millennial" I guess, a year or two either side, DX7, DX8 lower res, DX9 for less action more casual titles like SIMs or something. Should be a'ight on quake 3 engine stuff, which there was a lot of around at about then. The atom, I might use in a compact form factor table top arcade unit build, or a kind of console unit I can stand a monitor/TV on top of. (With a bit of backward angle maybe, to make it more arcadey) ... hmmm... maybe coulda bought another 2 for +2 monitors each for desktoppy stuffs (Because everyone really wants to run 6 monitors off one beast, that's why 🤣 )
edit: just remembered I had this weird hutchy bit with a hinged lid, that was on a computer desk I got years back, it was a PITA because it put your mouse space higher, dunno whether it was an owner add on or what, but I took that off, I bet it's still lurking around somewhere. That I think might make a good base for a table top console/cab with some surgery ... if I can remember where the friggin' thing is.
Reply 39670 of 57048, by BitWrangler
Well you know the expression "It's either feast or famine", I was expecting these the other side of the weekend but here they are with bonuses. 2 Slotkets, one is MS6905 1.1 the other is CPU Card Ver 1.0, which I think is the Startech one. Then there's a powerleap PL370/T with a celly 1.1A in it, and a Lin-Lin convertor socket. CPU in the slotket is a coppermine celly 700, the loose one is a bonus 866 PIII. Then I got a powerleap HSF, Cooler Master HSF, two socket 7ish looking HSF, loose sink, loose fans, a lifetime supply of heatsink clips, and the other sockety looking thing appears to be a backside thermistor for CPU temp reading.
Reply 39671 of 57048, by TheMobRules
appiah4 wrote on 2021-07-01, 06:36:
If I'm not mistaken that CT1740 seems to have a v4.05 DSP? In that case, it should be free of any MIDI hanging note bug!
Reply 39672 of 57048, by chrismeyer6
BitWrangler wrote on 2021-07-01, 20:14:
Wow that's awesome haul!!
Reply 39673 of 57048, by appiah4
TheMobRules wrote on 2021-07-01, 20:23:
Yes, it does have a CT1705 V405
It is just about as annoyingly noisy as I remember it from my 486 PC though.
Reply 39674 of 57048, by Miphee
The usual stuff: Core 2 Quad Q6700 from China. Interesting to see how C2Q and C2E prices have doubled and tripled in the past 2 years as Chinese stockpiles started to run out.
Reply 39675 of 57048, by HanJammer
Those 3 machines with some goodies inside...
1/2
Reply 39676 of 57048, by HanJammer
Reply 39677 of 57048, by Miphee
And yet another random job lot.
Reply 39678 of 57048, by appiah4
HanJammer wrote on 2021-07-02, 10:03:
2/2
The rest, I have. But this makes me jealous as fuck..
Reply 39679 of 57048, by BitWrangler
Miphee wrote on 2021-07-02, 10:11:
Hey, you've got some Pentium Ds in there, for make benefit glorious forums of Vogons.
Spoiler
The Pentium D 995: A study into a world without Conroe for make benefit glorious forums of VOGONS
What are you doing with all these anyway, got enough to tile the bathroom yet?
