Ess1878 midi out
Reply 20 of 27, by drastikterror
yawetaG wrote:
What happens if you start your DOS program from within Windows' DOS prompt (so not by restarting in MS-DOS)?
I start Fastracker 2 from win and audio works.
If I try midi out (a feature of ft2) It does not send it...
Reply 21 of 27, by drastikterror
I tried also Impulse Tracker in the "midi" mode, using the command "it /s19", and it automatically recognizes my mpu 330 port, and it sends midi messages.
So, at this point, it's a Fastracker 2 issue, in the sense that it does not properly recognize my ess1788, probably because tge 1788 is Soundblaster pro compatible, while Fastracker 2 preferes (I suppose) soundblaster 16 isa card.
Reply 22 of 27, by MAZter
I had similar issue with my integrated ESS1879.
Replacing Dos driver to ES1869 helps to fix "MPU-401 disabled" message.
Reply 23 of 27, by drastikterror
yawetaG wrote on 2019-09-19, 05:43:
Hi!
It starts, audio works, only midi doesn't, but I think that's because my card is SB Pro compatible, while, in order to properly work, FT2 need SB16, at least for midi
Reply 24 of 27, by drastikterror
MAZter wrote on 2021-07-07, 01:21:
do you know where to find them, please?
Reply 25 of 27, by drastikterror
Ok, found them in Vogoons database! 😀
Reply 26 of 27, by drastikterror
Please, can you help me configuring these settings?
Reply 27 of 27, by MAZter
drastikterror wrote on 2021-07-10, 13:51:
I just run one time ES1869 Dos driver and that's it, restarted laptop and sounds works fine.
