Reply 80 of 163, by Joseph_Joestar
Warlord wrote on 2021-07-09, 16:19:Try actually running the game the cofig screen always looks like that I don't think u actually tested it just looked at the config 🤣
You assume too much. As if I would go through the trouble of installing a game and then not actually start it.
For the record, I loaded a save, played through a few battles and it all worked fine. And bloodem already stated that he played FF7 several times on his FX5900 using 45.23 drivers.
Also, I specifically asked you for a FF7 test case, and you said it would only use software rendering unless older drivers are installed. That is clearly wrong, which is why I posted that screenshot, as it shows that Direct3D Hardware Acceleration is enabled.
