DOSBox Game Launcher (DOSBox Frontend)
Reply 1680 of 2217, by rcblanke
Here's another beta build with a few small changes:
  • Automatic reload of main window when certain settings are changed, negating the requirement to restart DBGL;
  • Improved default template for 'Tandy 2500SX' to use machine=vgaonly and tandy=on instead of machine=tandy (Neville)
All the latest files. To upgrade, just update dbgl.jar.
Ronald
Reply 1681 of 2217, by PerryRhodan
Hello rcblanke. Thanks for such a great program. 😀 It's been a while since I've added new games to DBGL and it's no longer letting me access Mobygames. Is Mobygames still accessible or is it now being blocked?
Thanks!
Reply 1682 of 2217, by rcblanke
Hi PerryRhodan, just make sure you're using the latest DBGL version, should work fine.
Reply 1683 of 2217, by rcblanke
The DBGL server will be down for a while for scheduled maintenance. Should be back up again.
Reply 1684 of 2217, by DOStopic
rcblanke wrote on 2021-05-12, 12:45:
Here's another beta build with a few small changes: […]
Ronald
Hi, Ronald!
I've the 0.93 beta 9 version (Windows 10) but when I update the dbgl.jar (0.94 beta 2) the program won't start. Double-clicking the icon, nothing happens!
My fault?
Reply 1685 of 2217, by rcblanke
DOStopic, please try updating all .jars in the lib folder using the complete windows package.
Reply 1686 of 2217, by Deffnator
I was thinking here, it would be possible to make a Icon pack for Most DOS games like Absolute Zero and so on?
Reply 1688 of 2217, by mirko182
Hi Roland
Downloaded dbgl094beta2.tar.gz from https://dbgl.org/beta/ for my linux machine and got error on start. Jar from win version?
The attachment 2021-06-24_16-32.png is no longer available
Reply 1689 of 2217, by rcblanke
Thanks for the heads up mirko182, I was already aware -- beta5:
  • Fixed startup crash on Linux and MacOS systems (regression in beta1);
  • Fixed setting focus on tab in case of field validation error (regression in beta1);
  • Fixed 'conflicting values'-detection when multi-editing (regression in 0.93);
  • Fixed possible nullpointerexception when using dosbox.conf with unexpected configuration values (Peter);
  • Implemented eXo importer, improvements to converter.
Ronald
Reply 1690 of 2217, by mirko182
Thanks for the quick response and first-class "customer" support. 😀
Downloaded a new build and of course everything works properly
Reply 1691 of 2217, by Arklay
Hi, can be fix the lag when you move the window profile setting?
Reply 1692 of 2217, by rcblanke
What do you mean Arklay, I do not understand your question?
Just a quick heads-up to inform you guys and girls that I have updated the main website at dbgl.org to provide for a better browsing experience on mobile devices. Expect more updates in the coming days.
Reply 1693 of 2217, by Arklay
rcblanke wrote on 2021-07-14, 16:30:
pm sent
Reply 1694 of 2217, by BitWrangler
Hi Ronald, just wanted to say thank you very much for all your hard work on DBGL, it's great to just drop on my modern boxes and have an instant DOS game fix, no hassle. I particularly appreciate that it has the same interface between multi versions of windows and linux, so it's all works the same on multiple platforms.
Reply 1695 of 2217, by rcblanke
Thanks for the PM arklay, unfortunately there is nothing I can do to improve this.
And thank you BitWrangler for your kind words, glad you like it!
Reply 1696 of 2217, by rotaxt
hi there!
the last couple of months i was quite busy and had no time to play good old dos games via dbgl. but now i want to start over again. i have an older installation of dbgl v0.93 on my drive which i combined with dosbox ece last year. it's running great, shaders and roland sound are working perfectly. but now i decided to start over again from scratch and downloaded the newest versions of dbgl & dosbox ece.
and here i need to ask for your help please - to use roland sound (or mt32 or cm32l roms) in the older 0.93 version of dbgl i click "edit profile" of any compatible game, after that i click "audio" and under "midi device" i have many choices: alsa - default - coreaudio - coremidi - none - oss - win32 - fluidsynth - mt32 - synth - timidity -> 11 options in total. so i choose "mt32" for wing commander for example and it works.
when i now want to do the same with newest dbgl 0.94.5 and newest dosbox ece under "audio" i can see: alsa - default - coreaudio - coremidi - none - oss - win32 -> only 7 options in total.
how do i add / activate the missing options like mt32 & fluidsynth in that audio dropbox? did i forget something in the general configuration of dgbl?
EDIT: Found it. In the EDIT-Tab of DOSBox ECE i manually added "mt32" in "device"-field. it is working now 😀
Reply 1697 of 2217, by LewisWoolridge
Hi Ronald - I'm upgrading from .82 to .93 on MacOS and I've run into the loss of portability issue.
To resolve you suggested to "edit the startup script ./dbgl, and simply remove -Ddbgl.data.userhome=true on the last line."
The problem is I can't seem to locate the startup script. A folder called "dbgl" was created in my ~/Library folder, but this script doesn't appear to be in there, nor can I locate a ./dbgl hidden folder in my home folder's root or the system root.
Please advise. Thanks!
Reply 1698 of 2217, by rcblanke
Hi LewisWoolridge,
What do you mean exactly? If you're only using DBGL on your Mac, you should be good (and safe with regards to your DBGL data) using the default settings.
To answer your question about the startup script:
Open Finder and browse to Applications. Right click on DBGL.app and choose 'Show Package Contents'. You will find the dbgl startup script in the subdirectory
Contents/MacOS
But please take note that updating older DBGL versions on MacOS can be a bit tricky. Older DBGL versions stored (game) data inside the DBGL.app directory structure. This could mean that whenever you trashed DBGL.app from your Applications list to install a newer version, you could accidentally also have trashed all its (game) data. That's why I opted to use ~/Library/dbgl for data instead (since DBGL version 0.93). That way, you can safely trash DBGL.app to put a new version in place without touching your data.
You can find more details about the upgrade process on the DBGL website, section 'Upgrading from an earlier version'.
Please let me know if you have any further questions, or need more help.
Reply 1699 of 2217, by LewisWoolridge
Thanks for the quick reply!
I need my installation to be portable for two reasons 1) My dosroot is more than 1TB and will not fit on my system drive, and 2) I use DBGL on more than one Mac (and also through a Windows VM with some minor tweaks). Additionally, I also want it to be portable because 1) that frees DBGL from my OS and future upgrades and new computers, etc., and 2) portable is tidier in general.
I found the script and edited the home folders to false on both lines. DBGL launches fine with no games in it and doesn't spawn a DBGL folder into my ~/Library folder.
I then copied /captures /profiles /dosroot /template /xsl from my .82 install into the DBGL package. And then copied my database.properties and database.script from my .82 install in the /db folder.
When I launch I get this error:
There was a problem initializing the database connection!
Technical information:
Database query "create initial tables" failed!
Please advise. Thanks again for your help!
