Reply 480 of 755, by jakethompson1
- Oldbie
feipoa wrote on 2021-08-06, 00:13:jakethompson1 wrote on 2021-08-05, 23:46:Chadti99 wrote on 2021-08-05, 23:42:Would these 12ns sram chips work on socket 3 boards for 256k cache?
https://www.ebay.com/itm/QTY-15-IS61LV256-12N … 1-127632-2357-0
Not sure what "low voltage" means but doesn't sound right. Should check the datasheet and see if they are 5 volts.
However, you can still get brand new 12ns 32KB chips. Like #71256SA12TPG at Digi-Key.
Have you ordered these? Could you share a photo? I recall someone here ordered them and wasn't impressed.
Yes, I did. Here was the thread with the picture: More 486 L2 cache troubles - timing sometimes so slow that cache isn't worth it?
I believe there is just a quirk with having the UM8672 VLB IDE controller on the bus and also using cache speeds any faster than 3-2-2-2. I have run into that issue with two different boards now. I don't think the Digi-Key chips were to blame.
In fact I'm using two of those chips as tag RAM chips on other boards and they work fine.
