dgVodooo 2.7.x and related WIP versions (2)
First post, by Dege
I closed the old thread for dgVoodoo 2.7.x because of growing too long, and also open this one to still provide place for announcements and short questions for the 2.7.x series.
Some fixings cumulated so I decided to release them in an incremental version:
dgVoodoo 2.75.1
- Improving the implementation of user clip planes in the DX backends
- Minor performance optimization in the D3D11 DX backend
- Fixing potential D3D12 cache overflow
- Fixing an incompatibility of GetDC/ReleaseDC on DDraw surfaces (The Secrects of Atlantis)
- Fixing a regression bug with GetDC/ReleaseDC on DDraw surfaces (Star Wars Galactic Battlegrounds)
- Fixing scaling of point sprites for upscaled resolutions (Falling Down)
- Changing the precision of certain visibility calcs to be more compatible with MS D3D (Alien Paranoia)
- Other minor code changes
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_75_1.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_75_1_dbg.zip
Newest MS Defender shouldn't detect it - detection removed.
Reply 1 of 237, by RaVeN-05
Hello
https://www.voodooalert.de/de/content/downloa … s/techdemos.php
Kitty Hawk (glide) (real voodoo2 ok) (missing ... no spatial antialiasing) dgVoodoo -> demo detects voodoo5 with 4x antialias, but there is no antialiasing at all , no matter what i choose
Museum (glide) (real voodoo2 ok) (missing ... no spatial antialiasing, no soft reflectance) maybe voodoo3 can handle =)? dgVoodoo -> all effects doesnot work
RocketBurger (glide) (real voodoo2 ok) (missing ... no spatial antialiasing, no motion blur, no depth of field) dgVoodoo -> only depth of field work
https://demozoo.org/productions/43296/
Radio Activity (glide) (real voodoo2 ok) dgvoodoo-> transparency error , megenta background
P.S. Have big hopes that ATI TruForm coming to wrapper
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 2 of 237, by RaVeN-05
https://www.pouet.net/prod.php?which=119
if i use glide3x it crashes
https://soggi.org/files/video-cards/tech-demo … fx_Surf-Demo.7z
if i use glide2x it crashes, glide3x is ok
Reply 3 of 237, by KainXVIII
Tex Murphy: Overseer is kinda hard to run on modern system, of course dgvoodoo helps (with cursor flickers and maybe some other minor quirks), but i have strange problem - Animated Textures options always resets and only working if you enable it (every time) in main menu and then load save files..Is this game problem or dgvoodoo's? How does it behave on original hardware of its time?
Example of animated texture - this fireplace
1.33 MiB
Reply 4 of 237, by RaVeN-05
SceneTest (Demoscene Demo) http://www.mcmanis.com/chuck/graphics/index.html
works with nGlide, with dgVoodoo black screen
___________________________________
3dfx Benchmark "Wizmark" V3.0
http://falconfly.3dfx.pl/downloads/wizmark.zip
Produces hall of mirrors defect with dgvoodoo
Reply 5 of 237, by RaVeN-05
Dege wrote on 2021-07-28, 13:15:
Yes, I remember this one. Does it work on a real 3Dfx hw btw? When I checked it out last time, it didn't crash in Glide3 but in other demo code.
tried it on real voodoo2 all works ok.
p.s. maybe this can be helpful in ati truform
https://web.archive.org/web/20200124181241/ht … tutorial31.html
Reply 6 of 237, by Matsilagi
I know this is a weird request, but i would like to know if you could make dgVoodoo2 fix / compatible with those 2 programs:
First is an old puzzle game named Flux. The UI items are all offset and broken, transitions don't work (gameplay also don't work) and the game is super-laggy.
Flux has a trial version for it here: http://www.planetflux.com/
Second one is a Screensaver named Electric! I wanted to run it as a Wallpaper in Wallpaper Engine but it doesn't seem to inject on the 256 color mode, and when it does, its just a garbled palette (which i sadly don't have screenshots of), it also seems to suffer from the same perf problem as Flux does.
Closest i can get of showing the issue is this: 6xmNRhP.png
And this: Jsa6rVH.png
How it should look: https://youtu.be/pIAsauPKGqI
The screensaver can be downloaded here: https://web.archive.org/web/20050731023946/ht … 0/electric.html , to test it with dgVoodoo2, rename it to .exe and run it.
Reply 9 of 237, by Glurak
Still FPS capped in glide with Diablo 2.
But only when i say MAX ISF or Unforced Resolution. When i say go FULL HD with 144 HZ its uncapped.
sooo i guess when it try to keep the Aspect Ratio something breaks the uncap.
On DirecX or Draw with dg no matter which setting i use. Uncapped FPS in Multiplayer.
In Restricted Area when i activate the Mousewheel zoom and using it this Happens:
Color is vanished and broken Picture.
Only when zoomed in.
Reply 11 of 237, by Dege
No. It'd require to manipulate the projection matrix, but that can'be done when the game renders with vertex shaders or feeds DX with pre-transformed vertices.
And even if it could be, the game rendering engine still can do visibility calculations for 4:3 aspect ratio which may end up in missing polygons at the extended areas.
Not to mention, how to decide what polygons are HUD or 'normal' 3D meshes.
It's a problem that only can be solved on game side.
RaVeN-05 wrote on 2021-07-25, 16:39:
It doesn't crash for me (2.75.1).
RaVeN-05 wrote on 2021-07-27, 17:47:
And this one also seems to work (not black screen) (2.75.1).
Reply 12 of 237, by KainXVIII
Also alpha transparency problems with animated textures in Tex Murphy: Overseer
148.23 KiB
99.43 KiB
Reply 15 of 237, by Dege
WIP80
Changes compared to v2.75.1:
- Adaptive N-patch tesselation (ATI TruForm) support for D3D8/9
- Fixing the freezing video playback bug in Mega Man X6
- A lot of changes under the hood
http://dege.fw.hu/temp/dgVoodooWIP80.zip
http://dege.fw.hu/temp/dgVoodooWIP80_dbg.zip
TruForm is supported by the virtual internal card and ATI 8500.
Also, you need at least DX feature level 11.0 for that.
Sorry, but there are no other changes, fixes and requests implemented this time. I release this to let TruForm impl be tested while I can work on other reported things.
For more, see the ATI TruForm topic (and plz write there about TruForm things).
Reply 18 of 237, by Deffnator
Dege wrote on 2021-09-02, 11:24:
If I get it right, this is a game bug that's very similar to the WipeOut 2097 one. So, the patched game exe should work with dgVoodoo too. But I'll check it myself I think.
here is a more detailed post about this issue along with the fix
https://github.com/elishacloud/dxwrapper/wiki … r-Epic-40%2C000
it also has fixes for other games
