First post, by Clickie
Hello,
I am looking for some advice on getting the signal on the midi output from my pc to my sc55.
My PC is a P4 running win98SE, I have a Audigy 2 zs sound card with the joystick/midi port connected. I only build the pc a few weeks ago and installed the drivers using Joseph_Joestar's guide [OUTDATED] Installing Windows 9x and DOS drivers on Audigy cards (version 3.1). and it sounded great with the soundfonts. But I wanted to use the actual hardware, so i bought a sc-55 mkii along with the 15 pin joystick to midi cable.
I connected the cables up using a joystick/midi cable to the input of the sc55, and I used a RCA to 3.5mm headphone cable from the output of the sc55 to the line in on the sound card. If I run the demo songs on the sc55 (pressing the two part buttons and the power button at the same time) I can hear them on my pc, but if I used the DUKE3D setup and select the "Sound Canvas" option there is nothing going to the sc55, the "EQ" display is flat, but the music is still playing using the soundfonts.
I cant quite work out how to force the pc to use the midi out on the sound card rather then to emulate the sound using the soundfonts.
Thanks.
