Reply 100 of 112, by DustyShinigami
- l33t
NeoG_ wrote on 2025-12-20, 01:07:DustyShinigami wrote on 2025-12-19, 14:02:I think the final piece of the puzzle would be a sound mixer, but at the moment, I need to have my speakers plugged into the Sound Blaster primarily. Especially if I want to use the SB's limited MT-32 capabilities. Otherwise with the Yamaha, I won't get music in those games.
You were extremely close to getting EK1M working as the mixer, the config file was just edited in the wrong way. I think you changed "-as line" to "-as line mix" when it should have been "-as mix"
Ohhh, okay. I can give that a try much later on, but again - unlike a physical mixer, how exactly would you control the mixing? I take it with an actual mixer you can specify the chosen card at any given time at the press of a button? With this method though, would I not still be specifying on a game-by-game basis via a BAT file? Or is there some other kind of shortcut?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
