Have a look at strapInfo0 VMI_HD2, my reading is that it would like to run @ 66 MHz rather than it is running @ 66 MHz. Does it change if you set things to run @ 33 MHz?
red-raywrote on 2026-02-26, 14:20:I just don't get it, I have made it abundantly clear I don't wish Disruptor's disruptive posts to be made any threads I start so […] Show full quote
I am bored with Disruptor asking questions and not providing the information I need to sensibly answer them so have muted Disruptor.
I just don't get it, I have made it abundantly clear I don't wish Disruptor's disruptive posts to be made any threads I start so why do they keep happening?
Nothing has changed, he still asks questions and fails to attach the SIV save files that I would need were I inclined to answer them.
The [Machine] screenshot shows that internal L2 is not shown on this screen but the external cache is declared as L2 although it is a L3 here in fact.
As for [Machine] not reporting the L3 cache then clearly this is a bug in the motherboard BIOS so the BIOS needs to be fixed as it's the BIOS that set's up the SMBIOS data that SIV and other utilities report.
I am sorry again, but I include your requested debug files here. I just did not know how to generate them, I just had to scan 9 pages of the thread until I got the idea to crawl in your change logs.
I saved them from command line now. And now I see that what you call Menu has to be called by pressing Alt + Space. I haven't seen that, perhaps it is documented because it is smart.
I usually scan first and last page before I add comments.
These old boards were created long before K6-3 existed at all. So original BIOS did not care at all about a secondary internal cache of the CPU. Chkcpu's (Jan Steunebrink) J.3 BIOS patch just modifies the BIOS in that way that these processors would be initialized at all. Please don't expect too much from these old legacy machines. On some other parts your great (non-ironic!) programme gets L3 information at all.
And my comment on the memory allocation was not disruptive at all. It just was a hint to look on or change a malloc() or similar call.
Edit: SMBIOS outputs are from bad quality. I don't trust them on old machines. It is probably not your fault then. HWinfo is not better at all.
[*]Assuming SIV starts OK I would like the save files generated do doing Menu->File->Save Local so I can check things in detail. I am happy for these to be posted, PMed or emailed.
Disruptorwrote on 2026-02-26, 16:53:I am sorry again, but I include your requested debug files here. I just did not know how to generate them, I just had to scan 9 […] Show full quote
I saved them from command line now. And now I see that what you call Menu has to be called by pressing Alt + Space. I haven't seen that, perhaps it is documented.
Given the very first post in this thread clearly specifies how to generate SIV files I am at a loss as to why why you specified "I just had to scan 9 pages of the thread until I got the idea to crawl in your change logs". All I can assume is that you are trying to be disruptive by posting misleading information. Please stop posting to threads I have started.
The K6-3 was launched on 22-Feb-1999, the BIOS date is 01/07/00 so you statement is incorrect. Please stop posting this incorrect disruptive information to threads I start.
Why don't you do as I asked and stop posting to threads I have started?
Given "Chkcpu's (Jan Steunebrink) " does all you wish for then I suggest you stop using SIV and use it.
I get the impression you feel you could develop a far better utility than SIV is and suggest you stop harassing me and do so.
I am hoping I won't have to reply to any more of your disruptive posts, but I won't be holding my breath.
I now have great additional informations for you.
It seems I've been wrong with the Windows 98 run. I am surprised! It does not show any significant difference in the 384 and 512 kB output too on the tests with 256 MB of RAM.
But!
I have done further tests that took me 3 hours of time:
1) Windows 98 native (256 MB RAM, 64 of it inside cacheable area of onboard L3 cache)
2) Windows 98 with MaxPhysPage=4000 in [386Enh] of system.ini (limits to 64 MB RAM)
3) Windows 2000 native (256 MB RAM, 64 of it inside cacheable area of onboard L3 cache)
4) Windows 2000 with /maxmem:64 in boot .ini (limits to 64 MB RAM)
5) Included all save files. DMI files could not be created on Windows 98.
Do you have your testing area below 64 MB of RAM or above?
Edit: Added the word "significant" and reordered tests to match the order of the pictures.
red-raywrote on 2026-02-26, 17:49:Given the very first post in this thread clearly specifies how to generate SIV files I am at a loss as to why why you specified […] Show full quote
Oh, I'm reading your post now.
Sorry for me not finding the menu in your program. There is no button called "menu". As I have written, it took me a while to find out it can be activated by pressing Alt - Spacebar.
Sorry for testing your program.
It shows me that my L3 cache is working - but only when I limit my operating sytem to not use more memory than the cacheable area.
It is incorrect that Chkcpu (Jan Steunebrink)'s BIOS patch does all I wish. It does not care about external cache at all. It is not a measuring tool like yours.
Please don't call every post from me disrupting. Even when a surprise for you may be disrupting in fact.
Some of the information is quite interesting - if not for you then for other vogons, I'm sure.
And about the BIOS date. The BIOS date does not matter here because the original BIOS from that date did not support K6-3, K6-2+ and K6-3+ at all.
It is Jan "Chkcpu" Steunebrink's BIOS project which adds support for newer processors to BIOSes. BIOSes from manufacturers are considered complete when being released for the first time. There are just minor patches for errors and newer CPU releases but not updates you await or expect. That board is from 1997! It is a wonder that a K6-3 is running there at all.
Peace.
Edit: Added information about Jan Steunebrink's BIOS project.
If you're going to issue a fix later this week, just tag me back when you do. I'll see if I can find some time over the weekend or early next week to re-run the test if you like.
Thank you again, I have just released SIV V5.86 Beta-07 which should fix the BIOS R1.6\r\n 01/15/99 to be BIOS R1.6 01/15/99, it would be good if you generated new save files to confirm the fix is correct, I will be very surprised if it isn't.
No problem at all. It may be MOnday before I can get to it, but I'll get it done. 😀
If you tolerate this, then your children will be next.
red-raywrote on 2026-02-27, 19:25:Thank you again, I have just released SIV V5.86 Beta-07 which should fix the BIOS R1.6\r\n 01/15/99 to be BIOS R1.6 01/15/99, it […] Show full quote
The full list of changes is:
1)
First of all, I'd like to say that I have gotten a kind of arrangement with red-ray.
He feels harassed if he gets any technical help or suggestion - from anyone. So we'd like to avoid that in future.
Don't try to ask your question again in another way when you have not understood his first answer.
2)
Then he has answered my issue with the cacheable area on motherboards that have external cache (he calls them "FSB speed caches").
In short, he feels SIV's [Cache Latency] should reflect what a typical user mode program would see. Please accept that SIV therefore neither will care about cacheable area nor it will tell you about it.
3)
We did came in contact because I have reported him by eMail how my EISA 486-50 is handled by SIV.
I did get 2 other executables from SIV to give him further logfiles so he could improve EISA support, especially under NT4.
He told me: "Again, thank you for your help with testing SIV, yours is only the 5th EISA system it’s been run on that I am aware of, the 1st W95 and the 2nd NT4." I can tell him: My system is the only EISA system where he has gotten logfiles from 2 different operating systems (Win95C and NT4).
Here ya go.
No problem. I have a lot of weird & rare dual CPU retro rigs....if one of mine shows up and you need the dumps, just sing out.
Thank you, I will look out for your posts. I still recall when I got a SIV save file from a mixed AMD Athlon + Duron MP system on 22-Feb-2006, at the time I had not realised such a setup would work, I sill have the save file and running SIV in test mode it reports as below, unfortunately a lot of what SIV would now report is absent from the file, such as the disk drive temperatures and DIMM SPD data.
Over the years I have been fortunate enough to be sent SIV save files from many uncommon MP systems, but never one from a Dual i486 or Dual PowerPC.
When I tried and run my Compaq W8000 with an Intel Xeon MP (Gallatin) 4MB 3.00GHz [C0] @ SL79V + Xeon MP (Gallatin) 2MB 2.70GHz [C0] @ SL79Z it failed to post, have you ever come across an asymmetric P4 Xeon?
I have just released SIV V5.86, the full list of changes is:
Thank you, Mr. Hinchliffe.
It seems like this version of SIV has dropped the support for Windows 95C and Windows NT 4.0 SP6a too.
On both operating systems I get the message that SIV does not support this system.
In your betas everything was fine. Edit: It is not a general drop for Windows 95C and Windows NT 4.0 SP6a. It just were misleading popups from SIV 5.86, thank you red-ray. Their aim is to discriminate Vogons users he does not like.
It works like the well known AARD code that has been implemented in a beta version of Windows 3.1.
My pal has tested a call to EISA BIOS on a Windows 95 command prompt using DEBUG command.
It also pops out the compressed EISA ID for the ELSA Winner 1000, while SIV in Windows 95C does not report it yet.
It seems your used HalGetBusDataByOffset used in Windows NT does provide the EISA ID for the ELSA Winner 1000 too but it is likely it will gather that information already before NT bootstrap switches into protected mode.
debug code:
1-a100 2-1b60:0100 mov ax, d800 3-1b60:0103 mov dl, 4 <- card id 4-1b60:0105 int 15 5-1b60:0107 int 3 6-1b60:0108 7-g 8 9AX=0040 BX=014B CX=A3C2 DX=0317 SP=FFEE BP=0000 SI=71F2 DI=9315
In SI + DI you have the compressed EISA ID
AX=0040 <- virtual device <- probably manually entered by ECU into EISA BIOS <- so probably do not put ELSF271 into your PNPDEVS.txt until verified by other users
Edit: further investigation results added
I dislike incorrect information being posted to this this thread and needing to correct it, fortunately only one **** ***** does this.
SIV V5.86 does support almost all Windows 95 + Windows NT V4.00 systems, if I had dropped support then obviously I would have specified this in the release information.
I got a 2 lined message that looked like this:
This System is Not Supported by SIV32L
2nd line: Operating system name
I dislike incorrect information being displayed by SIV.
But I can give more informations now.
A simple reinstall of Windows helped me out of that issue.
I can confirm that SIV is running on my Windows 95C again, probably a reinstall of NT4 will help too.
And: The string "This System is Not Supported by" has been added between last beta of SIV 5.86 and release of SIV 5.86 It very looks like this has been added to discriminate special Vogons users.
Can you confirm that please?
I'm locking this topic now. I've had enough of this.
red-ray if you are targeting select members of Vogons to not be able to use your software, please take it elsewhere. It's your right to do with your software whatever you want but then do it elsewhere.
