This week I've been messing with the socket AM3+ system with the phenom CPU. I was hoping to sell it on since I don't need another late XP machine, to help fund other projects!
The motherboard is a GA-970A-UDP3. I've installed 12Gb RAM (2 x 2GB + 2 x 4Gb) Corsair XMS DDR3-1600 RAM (6Gb per channel) I've run this configuration in the i7 for a few years (before it went XP), and I think before that it was in another phenom X6 setup. I know the RAM is good.
It started out OK, I installed windows 10 and ran a few benchmarks and stability tests. the GPU I'm using is a quadro 600, this GPU for some reason won't work in my other AM3 motherboard but seems to work fine in this one.
I then took this ram out to test some other ram - a 4 x 4GB corsair 1866MHz kit, it won't fit in the i7 as the heatspreader is too tall and catches the CPU fan in the first memory slot. I had never tried it in another system before.
The machine would not boot, I Assume some of the ram is faulty. Eventually I get it to POST with 2 sticks, but then a horrendous noise starts coming from the PC speaker and the screen displays the dualbios backup utility and flashes the bios from the backup to the main bios. All the while there is this horrendous sound coming from the pc speaker. I end up unplugging the speaker. Around this time the system seems to hang with the flash only 34% complete.
I reboot, leaving the speaker unplugged. The bios backup process restarts, completes and the machine boots. I go into the bios and then turn it off.
I try plugging the speaker back in. It still makes the noise when the machine is powered. Even now the bios is working. I try pulling the battery. This solves the issue.
I try booting into windows, but it hangs during loading. after more restarts. The bios says its corrupted again (And I get the horrendous noise from the PC speaker again)
I try reverting to the 1600MHz kit, but the same issue. Hangs during windows loading process and the bios corrupts after few crashes.**
**What I discovered is the bios isn't corrupted. If I pull the battery at this point, The BIOS seems to be functioning again when power is restored.
I did eventually get the machine to boot into windows, but after a few minutes the computer either completely locks up or resets. I have tried using a different HDD (originally I was using a 120Gb SSD that came with the system, then I switched to a 500Gb Mechanical) and a few different SATA cables, reinstalled windows, no change.
Had the CPU out, all the ram out multiple times, tried different CPU coolers, Bios revisions. Ram configurations, but it keeps misbehaving.
I have seen a few threads online about people having problems with the dualbios backup, one person seemed to believe it was hard drive related, but I think I've ruled this out.
I have tried flashing the bios to the latest version, it was running the latest version when it corrupted the first time, the backup is the initial bios release, so every time it "restores" the bios, I then have to reflash the new version. I am wondering how many flash cycles the bios will tolerate, and if it's previous owner had similar issues with it. Perhaps the bios chip itself is toast.
I plan on trying another flash of the latest bios over the top of the current flash to see if that helps. Or perhaps I need to run a different utility other than the built-in one?
One other thing. If I boot into Memtest 86 - I can test the RAM and it will run for the full test (which takes 7-8hours!) without any errors or crashes, but booting into Windows will almost always fail.
System 1: K6-3 400, MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP 3000+, A7V333, 512MB DDR333, FX5900XT, Audigy 2 ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
