Anomalies in the Intel® Processor Specification Updates
Reply 160 of 176, by PARKE
Thank you for the check.
The SLACQS comes from Intel, the QS part is printed in >red< in the pdf. The processor number is x3230.
There are two Westmere-2133 in the last overview, is that right ?
I don't want to add more at the moment, first fill in some gaps, like f.e. some first release dates.
Reply 161 of 176, by red-ray
PARKE wrote on 2025-06-12, 15:52:
OK, it's 6 letters so clearly incorrect. I feel it would be good if you posted a file that should have zero issues, further for the 3rd time would you like to me check that GHz is correct?
Reply 162 of 176, by PARKE
Sorry for that ' 3rd time' but I was still fixing the formats of the GHz; thus yes please, but with this latest version.
The attachment SIV13-6.txt is no longer available
Reply 163 of 176, by red-ray
PARKE wrote on Yesterday, 07:42:
OK, with this latest version I get as below so the GHz is still wonky.
file.php?id=221560
Looking at the raw data there is such as:
SLBVY B1 0206C2 3.60/6.40/1333/1333 Xeon 5600 Westmere-3600 4 x 256KB/12MB L3 LGA 1366 feb 2011 130 3600.00 27 AT80614005919AB Intel Spec Update / WIKI 32337217US.pdf 21
SLBV3 B1 0206C2 2.667GHz/6.40/1333MHz Xeon 5600 Westmere-EP 6 x 256KB/12MB L3 LGA 1366 mar 2010 95 2666.00 20 AT80614004320AD Intel Spec Update / WIKI 32337201.pdf 6
so for SLBVY you changed Westmere-EP to Westmere-3600 when you should have changed 3.60/6.40/1333/1333 to 3.600GHz/6.40/1333MHz
I suspect 2666.00 should be 2666.67.
There are also still 5 incorrect CPUIDs and 2 incorrect Steppings.
red-ray wrote on 2025-06-12, 14:37:
  1. CPUID 010676 is stepping [C0]
  2. CPUID 01067A is stepping [E0]
  3. Stepping [C1] is CPUID 010677
  4. Stepping [E0] is CPUID 01067A
I expect SL5RR came from https://www.pchardwarelinks.com/remark.htm and is a SL55R typo on that site.
Reply 164 of 176, by PARKE
Ok, thanks again.
The 7 steppings/CPUID's are now corrected.
SL5RR is deleted - must be the same as SL55R from the Intel sheet.
But not all SL5xx celerons are stepping D0. For example this one:
https://www.cpu-world.com/sspec/SL/SL5GA.html … google_vignette
is stepping C0 with 1.7v. All D0's have 1.75 volt.
SL533 can go either way hence no stepping/CPUID can be established.
The Westmere GHz was not done yet because I wanted to trim the content to just core + bus and wanted your opinion.
Reply 165 of 176, by red-ray
PARKE wrote on Yesterday, 09:31:
https://www.cpu-world.com/sspec/SL/SL55R.html
I found that out the instant I looked at [Celeron CPU S-Specs] and removed the statement. It's only the case for for Pentium III.
At the moment SIV just uses the core speed. Were it my file I would leave all 3.
Reply 166 of 176, by PARKE
red-ray wrote on Yesterday, 09:42:
With the Coppermines the overlap situation is somewhat similar, there are some SL4xx with cD0 stepping while the majority is SL5xx.
The Westmere QuickPath info is in another column now - didn't like the look.
Here is for the time being the last version:
The attachment SIV13-6-2.txt is no longer available
Reply 167 of 176, by red-ray
PARKE wrote on Yesterday, 10:43:
Thank you and almost, just the one issue you should fix.
file.php?id=221568
I edited your file so there were no issues.
file.php?id=221569
I feel it would be wise to add the ones that are missing when you have most of those CPUs, basically all of the above.
For proof of QAK9 see Re: Anybody have some 900Mhz 2.8v Pentium III Xeons?
Reply 168 of 176, by PARKE
Nice !, thank you. The last one is fixed. The 4 question marks at the top got provisional stepping/CPUID based on logic + reference note in other column.
Reply 169 of 176, by red-ray
The CPUID of the following is wonky, please may I have 30030340.pdf + 32012108.pdf?
SL9WN A1 010011b 1.6GHz/533MHz Celeron M 1MB Micro-FCPGA 1.30-0.95 533 1600.00 Intel Spec Update 30030340.pdf
Below should all have Penryn and all the 3MB ones are Core 2 Solo, not Celeron M, see https://www.cpu-world.com/sspec/Core%202%20Solo.html
QJNW R0 01067Ah 1.2GHz/800MHz Celeron M 1MB m-FCBGA 10 800 1200.00 Intel Spec Update 32012108.pdf 35,13
QJPT R0 01067Ah 1.2GHz/800MHz Celeron M 3MB m-FCBGA 5.5 800 1200.00 Intel Spec Update 32012108.pdf 34,13
QJRU R0 01067Ah 1.3GHz/800MHz Celeron M 1MB m-FCBGA 10 800 1300.00 Intel Spec Update 32012108.pdf 35,13
QKUS R0 01067Ah 1.4GHz/800MHz Celeron M 3MB m-FCBGA 5.5 800 1400.00 Intel Spec Update 32012108.pdf 34,13
SLGAJ R0 01067Ah 1.2GHz/800MHz Celeron M 3MB m-FCBGA 5.5 800 1200.00 Intel Spec Update 32012108.pdf 34,13
SLGAM R0 01067Ah 1.2GHz/800MHz Celeron M 1MB m-FCBGA 10 800 1200.00 Intel Spec Update 32012108.pdf 35,13
SLGAS M0 010676h 1.2GHz/800MHz Celeron M 1MB m-FCBGA 10 800 1200.00 Intel Spec Update 32012108.pdf 25,13
SLGEV R0 01067Ah 1.3GHz/800MHz Celeron M 1MB m-FCBGA 10 800 1300.00 Intel Spec Update 32012108.pdf 35,13
SLGAR M0 010676h 1.2GHz/800MHz Celeron M Penryn 3MB m-FCBGA 5.5 800 1200.00 Intel Spec Update 32012108.pdf Core 2 Solo 24,13
SLGQQ R0 01067Ah 1.4GHz/800MHz Celeron M Penryn 3MB m-FCBGA 5.5 800 1400.00 Intel Spec Update 32012108.pdf Core 2 Solo 34,13
Reply 170 of 176, by PARKE
Here you go. It may well be that I misinterpreted the classification.
The attachment 30030340.pdf is no longer available
The attachment 32012108.pdf is no longer available
Reply 171 of 176, by red-ray
PARKE wrote on Yesterday, 15:10:
Here you go.
Thank you, for SL9WN it says 10011b (13h) which is clearly wrong, I suspect it should be 06F3h so will use that in SIV.
Reply 172 of 176, by PARKE
I will add a note. For what concerns the Celeron M classification: the note nr. 13 denominates Celeron and there are 3MB cache examples in there like QJPT. But if you have more correct interpretation just tell.
Reply 173 of 176, by red-ray
PARKE wrote on Yesterday, 15:52:
QJPT seems to be Core 2 Solo, see https://www.cpu-world.com/sspec/QJ/QJPT.html
SL9VA(1 ) double B2 06F6h 1.73GHz/533MHz Celeron M 1MB Micro-FCPGA 1.30-0.95 533 1733.00 Intel Spec Update 30030340.pdf
I just spotted the (1 ) in the above and suspect it should be (2).
Reply 174 of 176, by smtkr
red-ray wrote on 2025-05-02, 08:24:
That's a shame, at the moment SIV reports [cC0] but it might be [cA2] and the only way I can think of to know for sure is to use […]
smtkr wrote on 2025-05-02, 01:09:
I don't want to set up a rig to look at it.
That's a shame, at the moment SIV reports [cC0] but it might be [cA2] and the only way I can think of to know for sure is to use a CPUID instruction to read the stepping. What date is printed on it?
Hot links are good so I added one. If I had one I would post a screen shot similar to as below to CPU World
file.php?id=218312
Hi. I still don't have a test bench setup, but since I came across the CPU while I was digging through my stash for something else.
Here's what's printed on the side of the CPU:
800EB/256/133/1.65V S1
10340106-0322 Philippines
i(m)(c) '00 SL4G7
Reply 175 of 176, by red-ray
smtkr wrote on Yesterday, 22:40:
800EB/256/133/1.65V S1 10340106-0322 Philippines i(m)(c) '00 SL4G7
Thank you, but it does not really help. Looking in the S-Spec update there is:
SL4G7 cA2 0681h 800EB/133 256 N/A ECC B SECC2 8,10
SL4G7 cC0 0686h 800EB/133 256 N/A ECC B SECC2 8, 10
So both could have those numbers, the only way I can think of is to check the reported CPUID/Stepping.
Reply 176 of 176, by PARKE
red-ray wrote on Yesterday, 20:30:
QJPT seems to be Core 2 Solo, see https://www.cpu-world.com/sspec/QJ/QJPT.html […]
Either Intel is right or CPUW is right.
The SL9VA(1) and SL9VA(2) is to distinguish them.
