Regressive bugs - report them here
Reply 160 of 172, by mitradis
In Space Rangers 2 (not HD) planet battles not loading. This game use botch ddraw.dll for space and d3d9.dll for planets. Possible fix it?
In Battle for Middle-earth 1\2\addon have bug (green screen border) with Antialiasing.
Reply 161 of 172, by Simbiont
Hello everyone! I found bugs when trying to use ddraw wrapper in Terminus (2000) game.
1) In the menu there are sliders for volume, quality level, mouse sensitivity, etc. With this wrapper, the sliders become transparent in the middle and the bar on which the slider moves disappears.
2) In the game itself, the effect of glare from the sun on the lens. With the wrapper, these sprites lose their transparency and turn into white squares with colored circles inside.
In other wrappers, such as dxwrapper or dxgl, everything works fine. In DdrawCompat I could reproduce the bug after enabling the PalettizedTextures parameter - I assume dgvoodoo2 does the same.
Reply 162 of 172, by mitradis
Why window mode completely NOT work for some games? This mode completely useless.
https://youtu.be/F8YDLy6Q-4Y
And CnC Tiberium Wars crash on minimize with wrapper, but without can. It needed for LosslessScaling set fps 30>60. Battle for Middle-earth 1\2\addon cant be minimize with wrapper, but without can. Pls can you check all this games with same engine?
Reply 163 of 172, by Ringtail
LEGO Rock Raiders: version 2.86 introduces a lighting bug where the direction is inverted on certain objects, especially noticable with the advisor model (seen in the lower right corner in the images)
lighting bug in 2.86
how it looked in 2.85
It also brings back an issue where pausing while in first person view would cause all the models in the world to disappear; they remain invisible after unpausing until returning to overhead view.
models disappearing when paused
Reply 164 of 172, by Dege
Ringtail wrote on 2025-04-16, 09:45:
LEGO Rock Raiders: version 2.86 introduces a lighting bug where the direction is inverted on certain objects, especially noticab […]
The lighting is ok, I've already run into it with other stuffs and fixed it. But the menu thing... It does not work for me with any dgv version. NaN values in the projection matrix coming from the game through D3DRm. It can even occur natively, but I don't know, because the rendering is broken as hell natively.
Reply 165 of 172, by rex0
There is a regression in the current version 2.86 when using Classic Rebirth patch with Resident Evil 1. The game crashes upon start. Last working version that I have is 2.74.1
Reply 167 of 172, by xeuvoodoo
Hello, I would like to report something about the using dx12 API issue i'm having. There some glitches showing using dx12 while it works fine with dx11.
file.php?mode=view&id=217367
Reply 168 of 172, by Helco
Hi Dege,
I think I found a regression starting with 2.85 regarding Direct3D7 with the game Zanzarah where a IDirectDraw7::GetGDISurface call returns a null pointer causing a consistent crash on startup.
I have tested with 2.84.1, 2.85 and 2.86.2 spec versions where only 2.84.1 works (also previous versions known to be working are 2.82.3 and 2.54).
I have attached a complete trace from a Visual Studio Debugger. The trace was recorded with another, custom program attached (WindowedZanzarah) but the crash is reproducible with only the original executables as well.
Could this be a regression in dgVoodoo?
Thanks and best regards,
Helco
Reply 169 of 172, by Dege
Helco wrote on 2025-05-13, 18:00:
Hi Dege, […]
Hi Dege,
Helco
Hi,
Is there anything special about reproducing this case (given location on some level, entering a certain menu item or sg like that)?
I gave it a quick go (vanilla game install) with 2.86.2 but it did not crash.
It's weird becaue GetGDISurface shouldn't return null, except if you have no primary surface allocated but it's obviously not the case here.
Reply 170 of 172, by lowenz
Lock an unlockable surface error in Splinter Cell Conviction (D3D9->11) so the game crashes @start
Reply 171 of 172, by CabralViny
Wallace & Gromit in Project Zoo crashes during startup with 2.86.2. I read that it did work on previous versions so I downloaded some from github and it worked on 2.55 but crashed on 2.63, though since the binaries for most versions there are missing I can't tell if this may have started at another point inbetween them. Here's a log from the latest version.
