Reply 17 of 53, by geordiepingu
My CPU blocks have arrived in one piece, which I am happy with. I will demount the board later this week and work out how they are going to fit.
In the meantime, I am trying to plan some of the bits for "Phase 2" of this build, while thinking about "Phase 3"...
Next up on the list are PSU cables. Quite frankly, I am surprised the GPU has run as stably as it has, overclocked, with the spaghetti junction of SATA to Molex adapters. I have started getting the occasional "low power" beep during black screens in 3DMark01 and 3DMark05. I've done the calculations, measured at source with a meter, and still reckon the NZXT C750 Gold Gen1 is a great PSU for what I am using the system for. The wildcard is the motherboard CPU VRMs, which get power from the 12V rail, so that does a lot of heavy lifting.
Clearly, the answer here is that I should make my own modular cables, suitable for the system, especially if I am going to watercool it so that I can keep the pump on its own circuit. At the moment, I am thinking of making "traditional" cables - yellow, black, and red, so the system feels a bit more period-correct. I did think briefly about paracord sleeving the cables, but I don't recall many people doing that in 2002.
In rough handfuls, this is what I think I'll do, "loom-wise"
- Dedicated 7800GS power feed (16AWG, overkill!)
- ODD + Floppy (4x Molex, 2x FDD - 18AWG)
- HDD (3x SATA + long feed with 1 more SATA for the SSD - 18AWG)
- Cooling (1x Molex for fan controller, 1x Molex for pump - 18AWG)
I did start putting together a bit of a BOM @ CPC
Molex 39-01-2060 - Mini-Fit Jr 6 way connector
Molex 39-00-0077 - Contact, Mini-Fit Jr. 5556 16AWG
Molex 39-00-0038 - Contact, Mini-Fit Jr. 5556 18AWG
TE 1-480424-0 - Socket Housing 4 Way
TE 163307-2 - 18-14AWG Crimp Terminal Pins
SATA power and FDD Berg connectors I've found on eBay so far, at least. Just not yet sure if I want to do punchdowns for the SATA, or an inline with IDC crimps.
I think while I'm in there, I'll remove the IDE HDDs. They won't be used as I am using the SATA card to achieve my stable 150MHz FSB. I have a pretty low 5V and 3.3V combined limit, so they are surplus to requirements and more likely to cause bother. It also begs the question whether I want to use the IDE Pioneer long-term, and swap that for SATA...
I've also measured the side panel so I can size it up for a window. The total dimensions are 430mmx620mm. Internally, I've got 417mmx602mm to play with. At the moment I am playing with the idea of a 30mm border and exposing the whole side of the case, including the cavity above the PSU. I could do some sort of feature to show off the tubes coming out from the bay reservoir, and bend some 0.8mm steel going spare to make a "cable management" flap to hide some of the excess cabling, mounted with some M3 screws.
I anticipate the window would look a bit like this, although without the fan cutouts.
My case is more the size of this - https://www.reddit.com/r/pcmasterrace/comment … _best/#lightbox
The OP on this thread has a window that just shows the motherboard. Personally, I think it would look better or at least more proportionate if the window was more like the original window case, even if there is a lot of space. I'll just have to take it up with watercooling tubes somehow!
geordiepingu wrote on 2026-07-05, 17:19:All for the benchmarks!
Petrol head and serial PC tweaker
