Gotek FlashFloppy Confusion
Reply 20 of 27, by DustyShinigami
Oh. One thing I am confused about are the pins. I'm struggling to decipher where each placement is. Especially as I've read that if I'm using a twist floppy cable, it needs to be set to MO...? There are currently two jumpers. One, I'm guessing, is set to SO by default...? The other looks to be at JA and JB, but I'm guessing those are set to Ground...?
The attachment IMG_4529.JPG is no longer available
I just want to make sure things are set correctly. Especially as I'll be getting a physical floppy drive to go with it and that I would like as the Master and the Gotek as the Slave.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 21 of 27, by jtchip
DustyShinigami wrote on 2025-08-31, 00:16:
No, and no. The lower jumper in your picture is set to S1. Per the wiki, this is correct for the IBM PC and sets it to drive ID 1, the same as a real floppy drive for use with PCs. The twist in the floppy cable essentially changes the ID of each floppy drive along the cable. With a straight-through cable, you'd have to set the ID jumpers of each floppy drive correctly (similar to IDE drives) and this is common practice on other platforms.
The wiki also says you need to set JC, not sure why your upper jumper is across J5 and JA. That could be why it didn't work until you copied an FF.CFG that probably contains the relevant interface = ibmpc line.
Reply 22 of 27, by DustyShinigami
jtchip wrote on 2025-08-31, 01:46:
Ahhh, okay. Thanks. That clears it up some. Yeah, no idea why it's set across J5 and A. I don't believe I've touched these jumpers; had no reason to. So I get now where S0, S1, S2, and MO are, though I'm not sure about MOR.
I'm guessing I would need to move it to S2...? If it's at ID1 at the moment. So it'll be at ID2 when I hook up my physical floppy drive. Thanks.
OS: Windows 98 SE
Reply 23 of 27, by Jo22
Hi! Maybe the Gotek was meant to be used by users of electronic keyboards, Amigas or Atari STs?
https://www.retrosix.wiki/gotek-flashfloppy-amiga
Reply 24 of 27, by jtchip
DustyShinigami wrote on 2025-08-31, 11:52:
No. I'll rephrase my original reply: all PC floppy drives are set to ID1 so leave the Gotek (with FlashFloppy firmware) set to S1. This is exactly what the wiki says to do.
Jo22 wrote on 2025-08-31, 12:19:
Amigas and STs (and some keyboards, according to the wiki) require the jumper to be set to S0 though. Hence it's important to check the documentation.
Reply 25 of 27, by DustyShinigami
jtchip wrote on 2025-08-31, 22:31:
No. I'll rephrase my original reply: all PC floppy drives are set to ID1 so leave the Gotek (with FlashFloppy firmware) set to S […]
Right, okay. Thanks.
OS: Windows 98 SE
Reply 26 of 27, by Jo22
+1
I was more thinking of the sample picture on that Amiga page.
If my eyes don't play tricks on me, then there's too a jumper set between J5 and JA?
Reply 27 of 27, by jtchip
Jo22 wrote on 2025-08-31, 22:47:
Ah, yes, indeed there is. The wiki doesn't mention such a setting, might be something specific to Retrosix.
Elsewhere on the wiki page, setting J5 (on its own) causes the ready signal (pin 34) to be permanently asserted (IBM 3174 section). JA is mentioned here as "Button: Select" and 3 times on the hardware mods page for connecting a button. So not sure what strapping a jumper across JA and J5 actually does, probably nothing in this case.
