Reply 20 of 30, by Mondodimotori
- Member
Archer57 wrote on 2025-10-23, 00:26:One caveat here - weirdly enough the fact that connector exists does not mean that CPU VRM uses 12V. There are examples of boards with the connector and 5V VRM. So to be certain take a look at VRM input caps - they should be 16V or something like that.
As for different opinions - well, if CPU is powered by 12V then there is nothing else in whole PC which can use 125W (5V 25A) at all. Claiming that it is needed is simply illogical.
Systems with 12V CPU VRM have very similar consumption to modern systems and do not require anything special from power supply. Even worse - if you use old PSU intended mainly for 5V it will have the same issues as it would on any modern system and will not work well.
I was finally able to take a picture on the other side of the capacitors and, LUCKY ME, they appear to be 16V (at least, the top one is, the others are well hidden behing the I/O, and I can't be hassle in pulling the MOBO out of the case, but they also appear to have the number "16" on that side)
AlexZ wrote on 2025-10-23, 16:50:A high-end copper Socket A cooler was needed back in the day in case of OC above 2.2Ghz. It was possible to run Athlon XP at 2.4Ghz. High-end coolers are also not quiet by today's standards as they use ball bearings and have very high airflow compared to Noctua fans. Back in the day cases had poor airflow so a good cooler was needed. It may not be necessary with a modern mesh case. An alternative excellent cooler is Thermaltake Volcano 7. TTC-CU5 TB is not bad either. There are very few of them surviving and owners do not want to part with them.
Well, then lucky me (again) that I got two of them, both with the fan speed tuner accessory! And got them for 10€ the first, and 20€ the second!
Volcanos and zalmans are, unfortunately, both rare and EXPENSIVE. Like, it would be cheaper to MacGyver your way around the mouning holes some 462 mobo have and adapt a modern tower cooler. I would love to see my Noctua NH-D15 G2 on a 462 mobo, but I guess it's beyond the 300g limit for the socket. But I believe there are plenty of good modern tower coolers that are under 300g, even the original AMD Zen cooler "wraith stealth" could be MacGyver'd on a 462 mobo. Considering it was provided even for 80+ watts CPUs, I guess it shouldn't cause heat problems on an old Athlon.
Of course, being those old fans noisi as hell, I replaced it on my first Titan with an 80mm noctua one, loosing 5° of cooling on my Athlon 1.4 due to lower CFM. I was able to recover those 5° by installing better airflow to the case. It's an OEM Pentium II style case, so I consider it a miracle to be able to keep that CPU below 50° under load.
This one case is a cooler master from 2013/14, it has a pretty big front fan (even if a bit obstructed), but it gives some airflow. But, most importantly, as seen from the pictures, right over the CPU cooler I have space for two fans! So, I bet, even installing a noctua fan on this unit too (or keeping it at the lowest RPM possible, which I bet has less airflow than a maxed out noctua 80mm fan), by stacking another bigger fan right on top of it, and a second one below it, I should get plenty of fresh air inside the case. I can even install an exhaust fan so that the PSU doesn't have to do all the work.
So, TBH, cooling isn't the bigger issue here. It was the VRM. And, as the above picture shows, while they still are electrolytic, they are 16V capacitors, wich should mean the MOBO will use that sweet, sweet 12V rail for the CPU. But I'll still get myself a 25A PSU, since I found one that costs 80€ and can be used in other builds I plan for the future.
