Corosion or Oxidisation
Reply 20 of 34, by AppleSauce
Should I check the voltage regulator?
Reply 21 of 34, by canthearu
AppleSauce wrote on 2021-10-04, 11:02:
Turn it on and check voltage to at the power pins of the jellybean chips. Probably should be 5V or close to.
It it is good, then the regulator is fine.
If it isn't good, then you can start digging into the PSU circuit.
Reply 22 of 34, by weedeewee
AppleSauce wrote on 2021-10-04, 10:52:
I guess I'll have to test other components, any idea on what would cause the power to cut off just after switching something on?
a short somewhere further down the line.
Do not ask Why !
Reply 23 of 34, by AppleSauce
Hey I cleaned off alot of the glue and it turned on properly but when I went back to clean some more glue off and tried it again it had the same issue.
Reply 24 of 34, by AppleSauce
At this point I'm not sure if the power switch is dodgy or its still the glue, the glue doesn't seem conductive according to the continuity checker
Reply 25 of 34, by AppleSauce
Okay so I opened the alps power switch, replaced the rails and cleaned it no dice , if I wanted to swap the voltage regulator which is a 7805A with a 7805CV would that be okay as a replacement?
Reply 26 of 34, by weedeewee
probably.
as long as the max current stays under 1A...
though
What are the voltages on the regulator pins now ?
Should be one pin with the incoming voltage on, or slightly less
one pin should have nothing
and one pin should have 5v.
Do not ask Why !
Reply 27 of 34, by AppleSauce
i got a 6 i think , but then i saw some sparks come out , crap i hope i havent fried anything 😒
Reply 28 of 34, by AppleSauce
weedeewee wrote on 2021-10-09, 09:24:
probably. as long as the max current stays under 1A... […]
probably.
though
well its staying on now but i dunno if ive damaged anything , maybe i should replace the vrm at least?
Reply 29 of 34, by AppleSauce
probably.
though
it sparked on the black stuff
The attachment 20211009_205224.jpg is no longer available
Reply 30 of 34, by AppleSauce
Maybe its some kind of oxide?
Reply 31 of 34, by weedeewee
AppleSauce wrote on 2021-10-09, 09:37:
probably the tips of your multimeter probes and the legs of the vrm got a little scorched. nothing to worry about.
AppleSauce wrote on 2021-10-09, 09:42:
now it stays on you say.
Does the vrm get hot? might be it's just a bad solder joint on the vrm.
leave it on for a while and check. replace if you feel like replacing it.
giving your photo addition, yeah check the connector and vrm pins for oxidation/corrosion
Do not ask Why !
Reply 32 of 34, by AppleSauce
weedeewee wrote on 2021-10-09, 09:59:
probably the tips of your multimeter probes and the legs of the vrm got a little scorched. nothing to worry about. […]
To be on the safe side I've decided to replace the vrm , I ordered the exact same model same brand , I noticed there was some white paste under the vrm , I'm guessing its some kind of thermal grease , when I put the new vrm in can I just use cpu thermal paste?
Reply 34 of 34, by AppleSauce
Okay so it was the voltage regulator, I swapped it with a an exact replacement , unit seems hunky dory now
