Corosion or Oxidisation
First post, by AppleSauce
I was inspecting the motherboard of the CM32L I just got and noticed there were some discoloured parts.
Is it from flux and the glue oxidising or are the caps leaking?
Just wanna make sure before I test power it on.
1.25 MiB
1.38 MiB
1.5 MiB
Reply 3 of 34, by vstrakh
Not a leakage. It should be a factory glue.
https://youtu.be/BeDKwi-GJRI?t=39
Similar glue blobs are visible on a photo of presumably working board here: http://vgmpf.com/Wiki/images/1/1d/CM-32L_-_Internal.jpg
though it didn't degrade as much.
Reply 7 of 34, by AppleSauce
Ah wait that pics kinda blurred , my bad
    871.15 KiB
Reply 9 of 34, by AppleSauce
I've been using this with a stepdown , works fine for my other stuff
1.56 MiB
Reply 11 of 34, by Tetrium
AppleSauce wrote on 2021-10-03, 07:36:
More pics
It does seem like glue, especially this cap here which is mounted sideways to the PCB.
The corrosion on the connector does look kinda bad though.
My retro rigs (old topic)
Report spammers here!
Reply 12 of 34, by weedeewee
the first photo shows some white that doesn't look kosher. the brown stuff near the solder pads is, I'm guessing, Flux residue.
The other photos where there's lots of brown stuff under the capacitors, is glue.
That barrel socket definitely has seen better days, makes one wonder what the inside contacts look like.
Anyway, plug it in, turn it on, and measure the voltages.
Do not ask Why !
Reply 13 of 34, by AppleSauce
Funnily enough my soldering iron got here today , its still pretty cheap but it has adjustable temp unlike my older ones , I'm going to try swapping the corroded jack since it seems to be the simplest thing to start with , any reccomendations on soldering temp?
Also I bought some of these jacks for fixing some other roland gear , would these be a good bet for the cm32L?
19.39 KiB
891.23 KiB
Reply 14 of 34, by canthearu
400 degrees C is a good starting point.
Use solder braid/wick to clear joints of solder.
Work quickly if possible. Hanging around the board with lots of heat is a good way to damage pads.
Use 60/40 leaded solder to help you rapidly install new plug. Add extra 60/40 solder to the joints if you have difficulty melting the old solder.
Reply 16 of 34, by AppleSauce
Okay after inspecting the board it turns out one of the caps has burst , I didn't notice it because one of the original factory workers drew an A on it , after cleaning the marker off its definitely got a cut.
724.96 KiB
1.4 MiB
Reply 17 of 34, by AppleSauce
So that's 3 recap jobs i need to do now, one for a abit bf6 mobo project , one for a Aopen psu and now one for a cm32L.
I'm sick of seeing burst caps at this point.
I suppose I'll just do one big bulk order from mouser and get it all out of the way. 🙁
