Reply 2040 of 3552, by BEEN_Nath_58
robertmo3 wrote on 2024-10-08, 16:17:
there is no wrapper and tuxality who makes it, doesn't even have the card, and the guys he asked for help - one said his card got broken, the other didn't understood the instructions how to make all the tests he wanted 😉
Wasn't Tuxality doing the PCX and PCX2 emulation too? I saw the updates have been stalled since 2023, anything you know on it.
Reply 2041 of 3552, by RaVeN-05
yes soft edges are perfect .
Tuxality doing PowerVR SGL API (PCX&PCX2) but no releases . Hope he will release something at least. its good to touch something by own hands rather than knowing it exist.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 2042 of 3552, by sharangad
Rebel Moon chroma keying fix, there are other changes so, stability may be an issue. I hope to resolve all that before the next release:
https://nirvtek.com/downloads/RReady.Alpha.20241010.001.7z
MD5: 96d43c483bd5a50e68dd198aa4b38bd0
https://patreon.com/Rready
Reply 2043 of 3552, by sharangad
Eurofighter 2000+ (Rendition Renderer) stable in FIFO mode:
[EDIT2]
One final tweak, thick lines:
https://youtu.be/1tv574bxoM4
[/EDIT2]
[EDIT] All rendering defects fixed:
https://youtu.be/ZSwOFEeIq14
[/EDIT]
https://youtu.be/eIFL1FQfe-Q
Reply 2046 of 3552, by sharangad
@Raven-05, my Speedy3D API test, the latest version I've tried fills up the fifo buffer, the fifo in queue free slots decrease and hit 0, but the Verité doesn't seem to be actually executing the commands. I'm missing a step somewhere, maybe even a single step.
Reply 2048 of 3552, by sharangad
And finally an obligatory vQuake performance improvement video:
https://youtu.be/1AqPS1_1qKs
The reason the now abandoned embedded codepath ran so well (for vQuake and everything else ran the same or slowed down) was because Dosclient was embedded into Dosbox, so the app had focus. It's explained in the video description.
Reply 2049 of 3552, by sharangad
Untested RReady Alpha October 20, 2024
https://nirvtek.com/downloads/RReady.Alpha.20241020.001.7z
MD5: 3eee5ef432ec73c43c2454719d7b710e
- Initial support for Eurofigher 2000+ in FIFO mode( DMA mode does not currently work reliably)
- Performance increases across the board by two new settings:
[rendition]
Highperformance=true
Picdma=true
And
[sdl]
Priority=normal, normal
(Previous DMA performance can be restored by setting both these to false. Threadsafe=true only has an effect if both these are set to false).
The new high-performance mode is extremely CPU intensive and might not work on older CPUs and might introduce audio static (random occasional pops).
- Custom car sets in ICR2 should be usable on most modern quad core or better systems.
- RebelMoon should sustain a solid 60 fps right throughout.
- RebelMoon chroma keying fixes: particle impact cloud sprites should render fully and not be clipped.
- FIFO mode memory write tweaks to support EF2000 in FIFO mode.
- Dosbox-Staging-Rendition has a full set of config settings under [rendition]. It also has performance improvements in ICR2. However it may have stability issues with Nascar Racing 1999R and possibly other apps. It does not currently support per-app config files.
This will be tested over the next 2 weeks and released to sourceforge and the Microsoft Store. Independent testing by a few other users would be useful. Just because it works for me doesn't mean it'll work for anyone else.
Reply 2051 of 3552, by sharangad
RReady Alpha October 23, 2024 (Fully tested release)
https://nirvtek.com/downloads/RReady.Alpha.20241023.001.7z
MD5: 4538bc2b544cc8aa42a0769bf2975ab0
19 October 2024
- Initial support for Eur*figher 2000+ in FIFO mode( DMA mode does not currently work reliably)
- Performance increases across the board with two new settings:
[rendition]
Picdma=true
And
[sdl]
- Compatible custom car sets in ICR2 should be usable on most modern quad core or better systems.
- R*belMoon should sustain a solid 60 fps right throughout.
- R*belMoon chroma keying fixes: particle impact cloud sprites should render fully and not be clipped.
- FIFO mode memory write tweaks to support EF2000+ in FIFO mode.
- Dosbox-Staging-Rendition has a full set of config settings under [rendition]. It also has performance improvements in ICR2. However it may have stability issues with N*scar Racing 1999R and possibly other apps. It does not currently support per-app config files.
- N*scar Racing 1999 improved stability with Dosbox-Rendition.
- Dosbox-Rendition vQ*ake performance parity with Dosbox-Staging-Rendition.
- T*am Apache may have compatibility issues with cutscenes with the October updates to Windows 11/nvidia drivers.
Reply 2052 of 3552, by sharangad
For ICR2 and Nascar
Frame interpolation test:
Try this:
[EDIT3] updated links
https://nirvtek.com/downloads/RReady.Alpha.20241024.002.7z
https://nirvtek.com/downloads/RReady.Alp...024.002.7z
MD5: 2d1314b5161dcab85ca3cb6969351aec
[ignore this one]
https://nirvtek.com/downloads/RReady.Alpha.20241024.001.7z
https://nirvtek.com/downloads/RReady.Alp...024.001.7z
MD5: 6ea2798dec38f18a517e4fe6d8ac04c0
[/Ignore]
[/EDIT3]
In the Dosbox folder rendition.cfg file add
interpolate=1
[EDIT]You may have to disable AA by hitting [ALT+A] in ICR2[/EDIT]
[EDIT2]
Nascar Racing 1999 60 fps:
https://youtu.be/XWPUictfR3w
ICR2 60 fps:
https://youtu.be/8FZCbh_tfS0
[/EDIT2]
[EDIT4]
OBS appears to be dropping even frames at 60 fps. Afterburner captured this intermediate frame:
Afterburner seems to capture only the even frames and not the odd ones.
Reply 2056 of 3552, by sharangad
Frame generation at 60 fps, better capture with ShadowPlay, the frame rate does dip below 60 fps with it at time:
https://youtu.be/PVKElUBSDL8
The intermediate frame should be visible in while advancing frame by frame.
Reply 2057 of 3552, by sharangad
Battle Arena Toshinden, is there any way to toggle between software and cgl rendering or is the 3db-pci version cgl only?
[EDIT]
Or some kind of command line switch. To select renderer. The intro runs in VGA mode 19 (320x200x256 colours)., then it switches to VESA mode 111h.
Reply 2058 of 3552, by RaVeN-05
did you applied http://www.mediafire.com/file/7t20118g56qadcg/TSDUPGRD.rar this patch for PCI version.
"2. After installing the patch, you must go to the Misc Options screen and manually select 3D Blaster under the 3D Accleration Option. The Auto Detect feature does not function properly."
    -h  -help   -?  USAGE: TSD [-switches]
-novesa : disable high resolution modes
-no3d : disable hardware 3D acceleration
-cgl : force 3D Blaster detection
-nocd : no CD present
-demofreq : demo every 5 seconds
-demonone : no demos
-h : display this help message
-64 -biospalette -profile -nocheckspeed -nocd -nomusic -nomidi -midi -cgl -no3d -no3dhardware -demonone -demofreq -master -slave -netperfect -novesa -vesa2 -nosmooth -d -r ERROR: expecting filename -p -nosound -owl
Reply 2059 of 3552, by sharangad
RaVeN-05 wrote on 2024-11-09, 10:15:
did you applied http://www.mediafire.com/file/7t20118g56qadcg/TSDUPGRD.rar this patch for PCI version. […]
I think that's on the cd, there's a tsdupgrade folder . Will try it. Many, many thanks to my friend who supplied a 3db pci and Stealth II S220!
Having real hardware on hand is very very useful.
