Reply 40 of 42, by PalMusicFan
LSS10999 wrote on Yesterday, 16:51:The game no longer hangs with hardware OPL3 enabled. Music now plays correctly. Some minor caveats: - After starting a new game […]
- After starting a new game from the main menu, the music hangs during intro scene. Not sure if there's another music track to be played during the intro, or it should stop. After the intro finishes the next music track will play correctly. So far this is the only spot where the music would hang.
- The music switch in the System menu (pressing ESC) has no effect. Don't know if in-game Music/Sound switches have been implemented.Exiting the game still results in a hang, however.
Thank you so much!
It looks like now we have found the correct way to play FM music.
About the issues:
1. I think STOP FM MUSIC is not yet inplemented correctly, and fade in / fade out, either. The intro has its owns audio track that could not be played yet, and after that we have a scene with no music (Li weaks up from his dream), so I think this is what you found.
2. Exiting game error is weired. Do you have a crash log? Also, did you get the game from the web cache? Could we have your cfg file? We would like to try to reproduce the bug.
In addition, could we know how your dISAppointment v0.2 with real Sound Blaster 16's DMA sound compatibility is? Is it consistent with the compatibility of those native ISA motherboard? Thank you!
