Reply 40 of 59, by ajacocks
- Member
The gameport to USB adapters that scorp designed are really cool. I have build 5 of them, so far, for myself, and for friends.
- Alex
- Alex
In case you guys are interested in some weird issue investigation on a 386 mainboard have fun with this one. I really enjoyed this repair, so I just have to share it with you 😀
https://youtu.be/koL3T5OAlIk
My Youtube channel Necroware
I was yelling at the screen to get you to check the Vcc on that clock buffer, but I see you got around to it 😀
scorp wrote on 2021-10-09, 20:08:In case you guys are interested in some weird issue investigation on a 386 mainboard have fun with this one. I really enjoyed this repair, so I just have to share it with you 😀
Watching now, good stuff as usual so far.
aka pete4237.5
I've already said it but I want to say it again, love your channel. Never miss a video, very educational.
Shagittarius wrote on 2021-10-11, 03:18:I've already said it but I want to say it again, love your channel. Never miss a video, very educational.
Thank you! Glad you like it.
maxtherabbit wrote on 2021-10-10, 02:46:I was yelling at the screen to get you to check the Vcc on that clock buffer, but I see you got around to it 😀
Yes, that was stupid, but fortunately it only cost me some time. Mistakes, where you do something stupid and make things worse are really annoying . I am planning to make a video as well about how I made such a really bad mistake with another mainboard 😁 I think, we have to stay honest and confess, that from time to time all of us do make stupid things.
Haven´ t seen it yet but hopefully I'll be able to watch it this week.
Thanks!
Just dropped in to say you have a great channel. Very interesting content and cool soldering skills 😉
Keep up the great work!
Bondi wrote on 2021-10-17, 12:58:Just dropped in to say you have a great channel. Very interesting content and cool soldering skills 😉
Thank you very much! Although I don't think, that my soldering skills are especially good. I'd say with a lot of luck I managed to solder the one thing or another, but there are many cases, where I have no clue how to make it...
I think many of you guys already have seen my last two videos about one of the projects I've been working on recently. But just in case someone missed it and is curious here is the link:
Part 1: https://youtu.be/CMiGVQbMC5U
Part 2: https://youtu.be/J0NLGfocviU
scorp wrote on 2021-11-28, 22:29:I think many of you guys already have seen my last two videos about one of the projects I've been working on recently. But just in case someone missed it and is curious here is the link:
Great set of videos, interested in seeing your update to the VRM and how that performs under load.
Yeah really enjoying it, great work!
Just got recommended your video about blowing open that old 430FX board with MMX and K6 CPUs. Hardcore. I like it.
The algorithm works sometimes! 😁
Never let them know when it works, that's how we'll spot the AIs trying to infiltrate.
Hi scorp,
Thanks for your great 2 parter about upgrading the Asus P/I-P55TP4XEG and your homemade VRM!
I noticed that the latest official #401A0-0302 BIOS had some limitations when you put the K6-2 CPU in. As I patched the P55TVP4 BIOS for the same limitations before, I can easily apply these same improvements to your TP4XE(G) BIOS. These are the changes I can make:
- Add detection of the K6-2+ and K6-III+ CPUs
- Expand the various K6 support routines to be K6-2+/K6-III+ aware
- Expand the K6 Write Allocation feature to work also on all K6-2/III CPUs with the CXT core and enable this feature for the K6-2+ and K6-III+ as well
- Expand the CPU Type display routine for correct display of the AMD-K6(tm)-2, K6(tm)-III, K6(tm)-2+, and K6(tm)-III+ strings
- Fix the 300MHz display limit bug on the BIOS boot screen
- Add 6.0 x 75 (450MHz) and 6.0 x 83.3 (500MHz) CPU speed indication support for FSB overclocking
- Fix the 32GB and 64GB limit bugs for HDD support up to 128GiB.
Let me know if you like to have this patched BIOS made.
Greetings, Jan
Chkcpu wrote on 2022-02-01, 16:43:Hi scorp, […]
Part 2: https://youtu.be/J0NLGfocviUHi scorp,
- Fix the 32GB and 64GB limit bugs for HDD support up to 128GiB.Let me know if you like to have this patched BIOS made.
Greetings, Jan
Hi sure! Then I can upload it to the Ultimate Retro project as well to make it available for everybody.
Okay, I will start working on it.
When tested, I will also put the patched BIOS on my Unoffical K6-2+ / K6-III+ page.
Jan
Hi,
Not sure if you would be interested, I have a set of VLB boards inc https://www.youtube.com/watch?v=Dd5vPt64XSQ this one, a VLB 386 and even a VLB Penium 60/66 board. I also own a Orcid local bus board (not working) I'm also after some other bits for example a gigabyte GA-400 scsi card, which user "eisapc" suggested he had, or sill may have? Or any "opti local bus" stuff may get my interest.
Unfortunately, while I can receive/read messages here, I can't yet send any! Frustrating!!
Also if anyone knows Colin from "this does not compute" I have 2x modified 300a celerons that I belive he would be interested in?
Hello, I saw your recent video on repairing a dual pentium® board. Nice work! For the most up-to-date linux I would suggest T2 (t2linux.com). This version still strives to support diverse hardware, and I've been able to use it on machines similar to yours. One of the developers, Rene Rebe, also does videos so perhaps you two could collaborate on this project? I think he is trying to get some publicity and wider interest for T2 linux. It would be neat to see modern firefox load the vogons web site on that board!
Are you limited to 128MB of RAM? Of course faster CPUs would be nice, but I think the main limitation with newer software is RAM. I needed 256MB to even get firefox to load. If you at least use a version of linux that has zram, I think you'll get further. Here is one thread about linux:
www.vogons.org/viewtopic.php?t=90695
I hope you continue the project; good luck!
