MCGA Games (PC/DOS) - LCD vs CRT
Reply 40 of 193, by Jo22
.. continued
    326.95 KiB
    357.53 KiB
    689.44 KiB
    243.44 KiB
Reply 41 of 193, by Jo22
.. two more
    241.92 KiB
    238.36 KiB
Reply 42 of 193, by Jo22
^To what I can say, both MCGA and EGA modes look pretty similar on that TV tube.
Makes me wonder, what could have been done with SVGA or VBE. Could it still have improved picture quality on a late 80s era monitor?
Both 800x600 16c and 640x400 256c were at least possible with early ISA VGAs having 256KB.
800x600 had the advantage of being both SVGA (direct support in game) and VBE compatible (proto-VBE of 1989 supported 800x600 16c mode, as mode 6Ah and 101h).
In popular SVGA implementations, it used same memory layout as VGA/EGA in 16c, making it easy to support.
The old 6Ah mode number has same lenght as a VGA mode number, ideal for patching executables without a recompile.
640x400 by comparison wasn't known until VESA VBE 1.x (mode 100h).
It uses a multiple of 320x200 and supports the same colour count (256c) as mode 13h.
This makes downscaling (integer) to 320x200 possible, thus allowing for using a single set of graphics (640x400 256c).
Also, it works with all basic VGA monitors, with TVs and internal LCDs or gas plasma screens of notebooks/portables of the time.
There are indeed a few 640x400 DOS games in 256c..
I know of two, at least. "Die Höhlenwelt Saga" (the cave world saga) and a platformer..
Reply 43 of 193, by Jo22
Zeliard
MCGA mode.
Information:
https://www.mobygames.com/game/189/zeliard/
    450.37 KiB
    280.03 KiB
    432.14 KiB
    222.24 KiB
Reply 44 of 193, by Jo22
.. continued
    227.08 KiB
    164.7 KiB
    256.42 KiB
    207.59 KiB
Reply 45 of 193, by Jo22
.. continued
    225.85 KiB
    224.03 KiB
    203.37 KiB
    182.87 KiB
Reply 46 of 193, by Jo22
.. continued
    351.88 KiB
    229.29 KiB
    308.08 KiB
    156.73 KiB
Reply 47 of 193, by Jo22
.. continued (almost done)
    407.95 KiB
    220.75 KiB
    463.64 KiB
    329.5 KiB
Reply 48 of 193, by Jo22
.. two more
I've taken a few more screenshots of this game due to its art style and age (1987).
Hope you don't mind.
    246.43 KiB
    340.18 KiB
Reply 49 of 193, by Jo22
EcoQuest demo
Information:
https://www.mobygames.com/game/584/ecoquest-t … arch-for-cetus/
    372.79 KiB
    565.28 KiB
    395.28 KiB
    526.18 KiB
    1.08 MiB
Reply 50 of 193, by Jo22
Cobra Mission: Panic in Cobra City
MCGA mode.
Information:
https://www.mobygames.com/game/3404/cobra-mission/
https://www.mobygames.com/game/47426/cobra-mission/
    804.98 KiB
    668.22 KiB
    764.22 KiB
    496.78 KiB
    1.1 MiB
Reply 51 of 193, by Jo22
.. and VGA mode (for comparison).
    798.07 KiB
    674.08 KiB
    984.09 KiB
    888.25 KiB
    1.14 MiB
Reply 52 of 193, by Jo22
Sam & Max demo
Information:
https://www.mobygames.com/game/745/sam-max-hit-the-road/
    1.1 MiB
    478.33 KiB
    1.09 MiB
    388.06 KiB
    193.72 KiB
Reply 53 of 193, by Jo22
X-Men: Children of the Atom demo
"Cross-Men"? Some game about crossdressers? 🤷‍♂️
486 required. 😭
    729.63 KiB
    618.18 KiB
    154.09 KiB
Reply 54 of 193, by Jo22
Meteor-Mission
Information:
https://www.mobygames.com/game/48182/meteor-mission/
    235.13 KiB
    139.32 KiB
Reply 55 of 193, by Jo22
Vinyl Goddess from Mars
Information:
https://www.mobygames.com/game/1381/vinyl-goddess-from-mars/
    929.77 KiB
    362.59 KiB
    857.78 KiB
    203.46 KiB
    215.25 KiB
Reply 56 of 193, by Jo22
Windoze
A Windows 3.1 themed Tetris game. Uses Standard VGA.
I consider including a few Windows 3.1 screenshots here, since that video about the Tandy VGM-225 monitor has footage of it, too.
Using Windows 3.1 GUI as a reference for old VGA (and MCGA) monitors in general seems plausible to me..
Most YT videos contain it anyway, and it gives an idea how things may relate to each other. 🙂
    446.8 KiB
    417.77 KiB
Reply 57 of 193, by Jo22
xTetris
Tetris game with interesting shaped blocks.
Uses CGA, rather than MCGA. I know, in principle it doesn't belong here. But it has an image of Albert!
You simply can't ignore/exclude such a game. It's Albert, man!
    331.99 KiB
    740.39 KiB
Reply 58 of 193, by Jo22
Hexxagon
Information:
https://www.mobygames.com/game/1039/hexxagon/
    498.58 KiB
    256.76 KiB
    450.52 KiB
    592.53 KiB
    578.03 KiB
Reply 59 of 193, by Jo22
688 Attack Sub
One of the earliest games using PS/2 graphics / MCGA.
Not very good, though. Looks mostly EGA-ish.
Digitized images do benefit the most, I think.
Information:
https://www.mobygames.com/game/2099/688-attack-sub/
Edit: It likely is displaying EGA graphics here.
The game will only use MCGA if no EGA mode can be set (which can be set on VGA cards, usually).
Source : https://trixter.oldskool.org/2017/10/01/the-f … -on-the-ibm-pc/
So for a workaround, the VGA card must either be forced into EGA mode (via MODE utility on ISA VGAs) or by overwriting some EGA files.
My apologies for this mistake here. 😔
    904.02 KiB
    433.47 KiB
    1 MiB
    487.08 KiB
    436.4 KiB
