Reply 60 of 61, by Saekita <3
The Solutor wrote on 2026-10-06, 15:31:what about the good old RTFM?
6. Dos Mode A. Restarting the computer in MS-DOS mode. Shutting down to MS-DOS mode from the Shutdown Win95 Menu will automatic […]
6. Dos Mode
Shutting down to MS-DOS mode from the Shutdown Win95 Menu will automatically run the CWBINIT.EXE /A in dosstart.bat. Therefore, shutting down to MS-DOS mode will automatically have the audio card configured for Dos games.B. Enabling Dos support in Dos prompt icon.
To enable real DOS mode with CS4232/36/36b/37b/38b support:
1.Select a DOS prompt icon.
2.Select Properties.
3.Go to the Program tab.
4.Select the Advanced... button.
5.Click MS-DOS Mode.
6.Click "Specify a new MS-DOS configuration."
7.The following line will be automatically placed into the new MS-DOS configuration (with right path):
DEVICE=C:\WIN95\CWBINIT.EXE /A
I already did, i'm not blind besides using CRTs daily, IRTFM. But I dont get it, as CWBINIT does nothing. It just says crystal card is not detected or can't be run on dos mode.
I see myself installing cheapy PCI soundblasters CT4810 ... It probably will be more compatible and easy to make work, they sound horrible, but crystal does not perform much better...
