The Soundblaster DSP project
Reply 620 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 13:13:
sbcrack stage 2 for 4.12
For 4.12;
Stage 2, variant 05 ...passed
Stage 2, variant 07 ...passed
Stage 2, variant 18 ...passed
Stage 2, variant 44 ...passed
Reply 621 of 1147, by Maelgrum
sbcrack stage 3 for 4.12
Reply 622 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:04:
SB Reset: done
DSP version: 4.12
MPU-401 init: done
MPU-401 loopback check: done
Stage 3, variant 44 ...passed
Success!
Reply 623 of 1147, by Maelgrum
Stack structure for variant 44:
C0 ACC
BF R0
BE DPH
BD DPL
BC ACC
BB PCH
BA PCL
looks good for attack ))
Reply 624 of 1147, by Maelgrum
sbcrack stage 4 for 4.12
Reply 625 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:27:
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Stage 4, addr 1212 ...failed
Stage 4, addr 1213 ...failed
Stage 4, addr 1211 ...failed
Stage 4, addr 1214 ...failed
Stage 4, addr 1210 ...failed
Stage 4, addr 1215 ...failed
Stage 4, addr 120F ...Success!
Reply 627 of 1147, by Maelgrum
sb16dump V0.14 experimental support for 4.12
Reply 628 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:44:
Gives an error.
Added the mdump1 and 2.
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Internal memory dump: done
ERROR: Dump failed
Reply 629 of 1147, by Maelgrum
some more sbcrack scan Stage4
scans full possible range
Reply 630 of 1147, by georgel
You had the same problem yesterday with 4.16. Keep in mind that considering resetting of DSP and returning of AA as a proper result is on my opinion very wrong. Resets can be triggered by faulty code too. Wrap around to address 0 past program memory would result in reset too. But 120F looks very probable for an address of E3 comparing it to 4.13. Instead I propose you to look for the proper functioning of E3, e.g. returning of copyright $.
Reply 631 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:59:
Same result all failed apart from the one that already passed. (120F )
Reply 632 of 1147, by Maelgrum
sb16dump V0.15 experimental support for 4.12 (found error in previous version)
Reply 633 of 1147, by S95Sedan
Maelgrum wrote on 2023-10-05, 15:08:
Same as the other version.
Added Mdumps.
SB Reset: done
DSP version: 4.12
MPU-401 init: done
ERROR: Dump failed
Reply 634 of 1147, by maxtherabbit
This triggered an NMI for me on my AWE32
Reply 636 of 1147, by Gmlb256
maxtherabbit wrote on 2023-10-05, 15:27:
That happened to me when testing with SBCRACK and dumping the firmware for the AWE64 CT4520.
Just disable NMI to let it continue and do a cold boot afterwards.
Reply 637 of 1147, by maxtherabbit
I do not have the ability to disable NMIs on this board short of putting a piece of tape on the card edge or something
Apparently you can gate them by setting bit 7 at I/O port 0x70.
Now it's just ERROR: Dump failed
Reply 638 of 1147, by Gmlb256
Perhaps toggling the MFBEN jumper setting helps?
Reply 639 of 1147, by georgel
maxtherabbit wrote on 2023-10-05, 15:51:
Yes , tape would work perfectly. It is the rightmost pad on the XT edge connector but I guess you know that.
