Reply 80 of 100, by douglar
LSS10999 wrote on 2026-03-18, 12:10:
A question. I wonder if this will work properly with an IDE-SATA adapter on new motherboards that only have SATA ports.
Interesting question.
I think it should work if you force things to run in PIO mode, since all the PATA-SATA bridges I've seen are willing and able to fall back to support PIO in some way or another.
All the PATA-SATA bridges I've seen also support UDMA modes pretty reliably too. But PICOIDE doesn't do UDMA, it tops out at MWDMA.
My experience is that getting MWDMA to work with IDE-SATA adapters can be very difficult. Depends on your IDE controller, IDE driver, & motherboard firmware. It will likely be easier if you start with a Marvell based PATA SATA bridge. People have had better luck with those.
Might just be cheaper & less time consuming to buy a PCI Pata controller if you feel like you have to use a DMA mode.
Reply 81 of 100, by Jo22
crusher wrote on 2025-11-21, 08:04:
+1 vote for a 5.25" front panel because what it replaces is a CD-ROM drive and I'm lack of 3.5" slots.
I think same. I really appreciate the idea of PicoIDE, but I want to see a full-size chassis in the future! 😁
Also because of extra space for bigger buttons and a larger screen, I'd be nice to users of big hands. 😃👋
In principle, that's also the case for floppy emulators.
But since they started out to replace/substitute 3,5" 1,44 MB floppy drives, their 3,5" form factor made sense.
PS: Sorry, I'm a bit late to the party! Please everyone go on! 😅
Reply 82 of 100, by Yoghoo
Jo22 wrote on 2026-03-18, 20:19:
I asked about that on Discord. But it's not in the planning unfortunately. Seems that injection molding a 5.25" frame is quitte expensive.
For me the reason not to buy one atm as I don't like those 5.25" to 3.5" frames and I would also like to have bigger buttons and a larger screen. 😀
Reply 83 of 100, by douglar
Yoghoo wrote on 2026-03-18, 21:50:
I like the idea too. Might be easier if you didn't have buttons.
Does anyone sell a 140mm x 35mm touch screen ?
Maybe this would work?
http://www.lamptron.com/Products/HardwareMonitor/137.html
The attachment image004 (1).jpg is no longer available
Edit: That screen takes HDMI. PICOIDE as it is takes I2C.
If we stick with I2C, there's this for a 1/2 height: https://www.amazon.com/2-42inch-OLED-Display- … B0DLG6MGMH?th=1
Or this could fit in a full height with some tweaking-- https://www.tindie.com/products/displaymodule … module-ssd1322/
Reply 84 of 100, by crusher
I think same. I really appreciate the idea of PicoIDE, but I want to see a full-size chassis in the future! 😁 Also because of ex […]
Thanks for the info from Discord. What a pity a 5.25" is not on the plan 🙁
Me personally can live with a 3.5" -> 5.25" adapter frame.
Can anyone recommend one in beige color?
They seem hard to find.
Reply 85 of 100, by Yoghoo
crusher wrote on 2026-03-19, 07:10:
Thanks for the info from Discord. What a pity a 5.25" is not on the plan :( Me personally can live with a 3.5" -> 5.25" adapter […]
Polpo did search for them as well and also discovered that they are not easy to get. 3D printing or spray painting a black one (which are available) could be an option. I still got a couple of beige ones but I'm not using them (because of exact color match etc).
Reply 86 of 100, by crusher
Yoghoo wrote on 2026-03-19, 07:35:
Spray painting a black frame is a very good idea!
Reply 87 of 100, by tabm0de
sangokushi wrote on 2026-03-09, 23:08:
tabm0de wrote on 2026-02-24, 11:25:
Only reason why i bought a small desktop chassi with two 3.5" bays for PicoIDE and Gotek ;) https://i.imgur.com/PtKCz6N.png […]
Only reason why i bought a small desktop chassi with two 3.5" bays for PicoIDE and Gotek 😉
Does it have an ISA slot?
Its a case only, adding motherboard with isa riser, so yes.
naa, nothing yet...
Reply 88 of 100, by JuddSandage
I 3d Printed up my own, they look pretty good too.
Reply 89 of 100, by Lostdotfish
In case you missed it on Bluesky or Discord...
The attachment Screenshot 2026-06-03 191655.png is no longer available
Dual device support. 1 PicoIDE 2 IDE devices presented to the system.
This device is going to be super awesome!
Reply 90 of 100, by weedeewee
Lostdotfish wrote on 2026-06-03, 18:18:
In case you missed it on Bluesky or Discord... […]
Thanks ! I did miss it.
Any benchmark results yet ?
Do not ask Why !
Reply 91 of 100, by douglar
Looks totally legit to me. Can't wait to get mine.
Reply 92 of 100, by douglar
douglar wrote on 2026-06-05, 15:25:
PicoIDE Deluxe (Black) - qty 1
Originally estimated to ship on Jun 14, 2026
Currently estimated to ship on Aug 14, 2026
Looks like I have to wait.
https://www.crowdsupply.com/polpotronics/pico … oduction-update
PicoIDE is being manufactured in Croatia by Soldered Electronics, that does open a few interesting options: for example the OLED screens were shipped by rail, a shipping option from China I’ve never used before!
The piece that had the longest lead time was the injection mold for PicoIDE’s case, so as soon as the campaign closed I made sure it’d be able to go into production as quickly as possible. After a round of final tweaks and approvals with the injection mold manufacturer with regards to draft angles, feeding gate locations, shrinkage and surface treatments, I was finally able to approve a final design for manufacture.
They estimate that the first samples from the mold will be ready by the end of this month. I can’t wait to see them, and fingers crossed that they come out looking good and fitting well! A lot of work went into the design so I have good confidence they will. As soon as the samples are ready I’ll post an update showing them off. Once the samples are approved with no changes needed to the mold, there shouldn’t be any further delays to starting production.
Of course, there’s lots to do on the project while I wait for parts to arrive and molds to be manufactured. That includes packaging design, paperwork for certification, and documenting assembly and testing processes. In a future update I’ll go into detail on assembly and testing, and the hardware and software tools I’ve developed to help those processes along.
I also haven’t stopped developing the firmware for PicoIDE, and I’m pleased to announce that it will ship with dual device support! That means a single PicoIDE can emulate two devices at once, and any combination of hard drive and optical drive is possible.
I’ve also included some fun things in the firmware. I added screensavers with the classic flying toasters and bouncing DVD logo
https://www.crowdsupply.com/teardown/portland … ut-of-date-tech
Reply 93 of 100, by douglar
douglar wrote on 2026-06-25, 00:46:
PicoIDE Deluxe (Black) - qty 1 Originally estimated to ship on Jun 14, 2026 Currently estimated to ship on Aug 14, 2026 Looks l […]
Anyone get any updates ?
Reply 94 of 100, by zami555
douglar wrote on 2026-08-21, 00:34:
Last update I got was on July 20th and it was about enclosure.
I've just checked my emails and in my case estimated shipment is September 13th. However in my case I placed order quite late.
Reply 95 of 100, by JuddSandage
Checked my order page for it, said the expected ship date was August 15, now September 15th, ugh, I will be traveling for work then.
Reply 96 of 100, by douglar
I just got an update. October 29th is the new delivery date.
Full production is imminent!
I gave the go-ahead to begin production of the PicoIDE cases last week and the rest of the process for Soldered Electronics to get started on full production is complete: plans approved, international wires sent, safety manuals written, box labels designed, and so on. It’s the tail end of the summer holiday season in Europe so I hope to see things moving quickly soon to get production started and finally get PicoIDEs shipping!
Recent firmware improvements
As per usual, I’ve kept on working on the PicoIDE firmware to add features and fix compatibility with niche systems. Here are some recent highlights:
Fixed issues and validated compatibility with some interesting systems: SGI Visual Workstation 320, TF1260 accelerator for Amiga 1200
Dual device mode now only carries a 3% penalty in sustained transfer speed
Finally added user-facing logging to SD card, so if things do go wrong, log files can be included in bug reports or requests for help
Implemented lots of small tweaks and improvements to the front panel and web interface for PicoIDE Deluxe
Made the firmware update process even more resilient
Reply 97 of 100, by zami555
In my eyes such delay in finalization of production of a new design is not surprising. There's always a risk that something is not OK at first shot. The most important is that root causes are found and improvements are defined.
Reply 98 of 100, by ldeveraux
douglar wrote on 2026-08-26, 03:46:
Until it's inevitably delayed again 😉. This is the nature of the beast with crowdfunding, but I appreciate the constant updates and transparency.
Reply 99 of 100, by NeoG_
ldeveraux wrote on 2026-08-26, 13:59:
Yep, crowdfunding almost always happens before tooling and contracts so you are exposed to the variability and uncertainty of getting the manufacturing pipeline setup to even start production.
