Reply 80 of 84, by DesktopDynamite
Hello, stumbled onto this since I cannot get working 2x gravis gamepad and the gravis gamepad pro with the Logilink Gameport to Usb adapter.. On a YouTube video I found that switch has to be set on 3 for gravis gamepads, however only left and right directions work..
I have a Win 10 PC... Would this work?
If so I'm interested in purchasing.. As for soldering I am good at it 😀
Reply 81 of 84, by 1541
The "Logilink Gameport to Usb adapter" is the same as the original "Rockfire Gameport Adapter".
It supports only analogue gameport joysticks whereas the "Necroware gameport adapter" implements own logic to also support Joysticks & gamepads in digital mode.
It is also OS independent, so you can even plug it into the USB connectior of your phone and play with a Gravis Gameport gamepad like this
https://m.youtube.com/watch?v=bDuXLQjaocE
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 82 of 84, by DesktopDynamite
1541 wrote on 2025-03-24, 20:38:
The "Logilink Gameport to Usb adapter" is the same as the original "Rockfire Gameport Adapter". It supports only analogue gamepo […]
Thanks for the detailed reply. Will check out the videos.
As for buying the kit, do I need to preorder from here?
I'm from Malta EU.
