Reply 80 of 139, by igna78
Oerg866 wrote on 2025-07-09, 04:23:
Hello, […]
Hello,
I've just released v1.2 of K6INIT.
Some of the points raised earlier in this thread and also your issue @mockingbird should be addressed now.
https://github.com/oerg866/k6init/releases/tag/v1.2
- Write Allocate no longer fails when the 15MB hole is specified
- Reworked behavior of /auto with other parameters, it is now seamless
- Introduced new skip parameters that help change /auto's behaviors
- Running in V86 mode no longer crashes (fixes #2) but gives a helpful message
- added /quiet parameter for reduced print output
- PCI / LFB scan warns instead of errors when the MTRR list is full (i.e. too many locations found)
Absoluty fantastic new!
Thank you very much for your job!
Reply 81 of 139, by nickles rust
Thanks for your work on this! Do you have a download link or could you post it here please? That github URL is a big steaming pile of javascript. I found the previous version here:
www.infania.net/misc/cpuutils/K6INIT/
Reply 82 of 139, by marxveix
nickles rust wrote on 2025-07-09, 13:15:
https://github.com/oerg866/k6init/releases/do … v1.2/K6INIT.EXE
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 83 of 139, by Oerg866
RoberMC wrote on 2025-01-26, 07:05:
I remember years ago I managed to trace what the bios in this MB is doing with chipset registers and used pciset tool to replica […]
I remember years ago I managed to trace what the bios in this MB is doing with chipset registers and used pciset tool to replicate the behavior in order to transfer this tweaks to motherboards lacking this bios options, it is flipping some bits in 3 southbridge registers 84 85 and 86. South Bridge is Ali M1541, Vendor 10B9, Device 5243
Bios configuration by default (wc fb off in bios):
PCISET 5243 10B9 84 1111 0000
PCISET 5243 10B9 85 1111.1111 0000.0000
PCISET 5243 10B9 86 1111 000
Bios tweaked configuration (wc fb enabled):
PCISET 5243 10B9 84 1111 1111
PCISET 5243 10B9 85 1110.0000 1110.0000
PCISET 5243 10B9 85 0000.1111 110
PCISET 5243 10B9 86 1111 111
FYI- I'm working on adding support for chipset specific tweaks, starting with this one, for version 1.3
Reply 84 of 139, by Oerg866
Here is a test version for the chipset features.
So far I attempted to implement some sort of functionality for these:
ALI Aladdin III
ALI Aladdin IV
ALI Aladdin V
SiS 5571
SiS 5581/5582
SiS 5591/5592
SiS 530/540
No clue at all if any of them work. But they should!
Run with
/auto /chipset
For VIA chipsets i could not find any specific frame buffer bursting features in the datasheets.
Reply 85 of 139, by mockingbird
Oerg866 wrote on 2025-07-10, 03:24:
Run with […]
Run with
/auto /chipset
Can I have some love for my Sis 5597/5598 please?
BTW, the new version fixes my previous issue, thanks! With "/auto" now I get about 150 points less (in Chris' 3D Benchmark) than with the "/vga" switch, but I guess it is unsafe to use "/vga", correct?
(Decommissioned:)
Reply 86 of 139, by Oerg866
Yes, the setting may cause problems, but if you don't have any then you can keep it
Reply 87 of 139, by analog_programmer
https://i.imgur.com/JVNMr51.png […]
ALI Aladdin III
ALI Aladdin IV
ALI Aladdin V
SiS 5571
SiS 5581/5582
SiS 5591/5592
SiS 530/540
Run with
/auto /chipset
Very good job, Oerg866! K6INIT tool turns into "a swiss army knife" for AMD K6 CPU systems 😀
P.S. By the way, your AnbUI C library is also pretty cool project and has potential to become a good substitute for the complicated Turbo Vision - at least for C. I hope you will add more new features to it soon.
mockingbird wrote on 2025-07-11, 02:58:
I have a s.7 motherboard with SiS5598 chipset. What can be tweaked in it?
If I'm not mistaken, there are slow memory issues with some VIA chipsets, which can be fixed through register's settings.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 88 of 139, by marxveix
Memory interleave enabler and pci latency patches:
https://www.georgebreese.com/net/software/
https://www.deinmeister.de/mvp3_zlt_e.htm
Reply 89 of 139, by analog_programmer
marxveix wrote on 2025-07-11, 18:20:
I was not mistaken about the VIA chipsets memory latency settings issues. This WPCREDIT.EXE tool is a windows thing, so it will be very nice if K6INIT can do the same job in DOS. From the first link here are the files with VIA VP3, MVP3 and MVP4 chipsets settings for WPCREDIT.
Reply 90 of 139, by marxveix
analog_programmer wrote on 2025-07-11, 18:57:
Also about PCI latency patch (from deinmeister site).
Is there a DOS version?
No, but since hardware acceleration is usually not used under DOS the problem does not occur. However, if you really need a DOS version of the tool feel free to contact me and you´ll get it.
I have not used it, but with this tool it should be possible to tweak also pci latency in dos
http://web.archive.org/web/20141225075538/www … .com/tweakbios/
Reply 91 of 139, by analog_programmer
marxveix wrote on 2025-07-11, 19:12:
Also about PCI latency patch (from deinmeister site). […]
Right now I'm browsing through deinmeister site. Yep, there are some DOS tools, but I meant - why using more than one tool for fixing the issues, if one (K6INIT) will do the job (hopefully) 😉
Thanks for the archived link, but Isn't VIA's PCI latency issue different from the memory latency issue?
Reply 92 of 139, by marxveix
analog_programmer wrote on 2025-07-11, 19:36:
I have VIA MVP3 and K6-2+, of course it would be good to have one good tool for it.
Speed gives memory interleave, pci latency issues also good to fix@dos if possible. 😀
Reply 93 of 139, by Oerg866
Run with […]
Run with
/auto /chipset
Hi yes I looked at the datasheet and the mechanism and registers are the same, so I added it.
New release v1.3a is here: https://github.com/oerg866/k6init/releases/tag/v1.3a
Reply 94 of 139, by nickles rust
nickles rust wrote on 2025-04-22, 15:37:
If I run "k6init /auto" after booting, it will hang the system. However, if I first enable the caches with "setmul l1e", then I can use k6init to enable the other features.
I tried the latest version, on a different mainboard, and I can replicate this behavior if I disable the CPU cache in the BIOS settings, then try to enable it after booting with K6INIT.
I don't know if SETMUL source code is open, but if the author would collaborate with you on this project perhaps both utilities could be improved?
Thanks for your continued efforts!
Reply 95 of 139, by Oerg866
Can you try with this debug version please? Ideally in 50 line mode (mode con lines=50 cols=80)
Reply 96 of 139, by nickles rust
I couldn't get the mode option to work, but here is the regular screen output. Procedure, disable CPU cache in bios, then boot and run K6INIT /AUTO:
The attachment k6initDebug1.jpg is no longer available
Same, but run SETMUL L1E, and then run K6INIT /AUTO
The attachment k6initDebug2.jpg is no longer available
I hope this helps.
Reply 97 of 139, by Oerg866
Ok so looking at your debug output there's an extra bit set I wasn't aware of, and after checking the datasheet of the CPU, the crash makes sense...
Didn't realize this, will patch later today
Reply 98 of 139, by Oerg866
nickles rust wrote on 2025-07-14, 22:30:
I couldn't get the mode option to work, but here is the regular screen output. Procedure, disable CPU cache in bios, then boot […]
I hope this helps.
Fixed now, bugfix release v1.3b here: https://github.com/oerg866/k6init/releases/tag/v1.3b
Reply 99 of 139, by Disruptor
Thank you oerg666.
Which substitute program can you recommend for a K6 (-300, 26031) and a K6-2 (-333, 26050, non CXT)?
Or do you have interest in adding support yourself?
Or do you like a helping coding hand to add that support?
However, my other K6-2 (-400, 26351) is supported.
And if I run K6INIT without parameter it recommends /help for help screen but requires /? instead.
