Reply 840 of 1132, by vsharun
myne wrote on 2025-05-30, 02:07:Lpc is a bus though. […]
You can't hardwire data selectively to one device and not the other.
Control pins like ldrq are obviously different.Chatgpt, talking with the confidence of an expert, and the understanding of a parrot.
I'd check the soldering again.
You don't need LDRQ at all for unisound to init card - proven on Asus P5Q (attached).
ChatGPT while not being Kant's knowledge-class wisdom reveals some breadcrumbs/clues.
Like you right, imagine MultiIO was connected in some way and also requires init with proper address windows (several) set. Where, is there override method ? And it's also on LPC. Then imagine there's good old days where you have two devices listening on the same ISA port and both responding on port read. Also there's PCIe-PCI bridge.
I have another one mobo with the same issue - Asus Z87-C, with the same PCIe to PCI bridge as Z97M-Plus
Maybe there's some substractive decoding routed here ?
I also have Gryphon Z87 which maybe considered as a copy of Maximus VI Gene, will check nearby hours is UNISOUND works here.
Friend of mine will check P5Q multiplexing ability of LDRQ1/GPIO23 - will it work (by soldering directly, without port programming), because GPIO23 connected down the road to the raid logic within ICH.
